Application possibilities
Mounting and accessory application
Orbiter’s unique Quick Lighting Mount (QLM) system allows the Orbiter Fresnel lens to be mounted safely and quickly. ARRI accessories like the 4 and 8-leaf barndoors can be added to the new Orbiter Fresnel lens to enable a perfect cut. Physical gels can also be used in addition to the more than 300 already pre-programmed gels available for Orbiter.
Learn more about working with the Orbiter Fresnel Lens
Orbiter Fresnel Set
Elevate Cinematic, Broadcast, and Live Productions with Cutting-Edge Fresnel Lens and ARRI Spectra Light Engine!
Click through the set L0.0050673 here.
ARRI accessories like the 4- (L2.40950.0) and 8-leaf (L2.40960.0) barndoors can be added to the new Orbiter Fresnel Lens to enable a perfect cut. Physical gels can also be used in addition to the more than 300 already pre-programmed gels available for Orbiter.
The Orbiter Fresnel Lens has a zoom range of 15 to 65°. Also, it is fully motorized and can be precisely positioned while being controlled locally via Orbiter’s Control Panel or remotely by DMX/RDM or IP based (ArtNet or sACN).
Your ARRI Sales representative will be happy to give you a demo—live or remotely. Please contact your local dealer at www.arri.com/en/contact to see when they have the Orbiter Fresnel Lens in stock.
The Orbiter Fresnel Lens will be available in black.
Use of the Fresnel Lens requires LiOS2.0.
No, the Fresnel Lens can be mounted and unmounted while the Orbiter is switched on.
Order information
If you would like to receive an offer or have a specific request regarding the Orbiter Fresnel Lens, fill in the form and we will get in touch with you.
