L3.36700.D 750 plus-1
ARRILITE 750 Plus
MAX Technology in action
The ARRILITE 750 Plus is a new and improved incarnation of ARRI’s traditional, open-faced light, the ARRILITE 800/1000. By optimizing the ARRIMAX reflector for usage with an HPL* 750 W lamp, the ARRILITE 750 Plus offers 21 % higher light efficiency than the previous ARRILITE 800 W, while the ARRIMAX optical system improves distribution of the light. A detachable and fully rotatable accessory holder accommodates scrims and barndoors, and incorporates fittings that permit the Chimera Video Pro Plus S to be fitted directly, without an additional speedring.
The one-arm stirrup allows for plenty of pan-and-tilt options and a heat-proof handle at the rear of the lamphead enables easy maneuvering. No tools are required for changing bulbs as the housing consists simply of two detachable parts that open and close through bayonet cap locks. The smaller and lighter aluminum housing of the ARRILITE 750 Plus makes it an ideal lamphead for lighting kits and therefore also suitable for electronic newsgathering, field production and fast turnaround location use.
*HPL lamp invented by and licensed from David Cunningham
  • MAX Technology reflector enables better light distribution
  • Compatible with 375 W, 573 W and 750 W HPL* bulbs
  • 21 % increase in light efficiency compared to the previous ARRILITE 800 model
  • New accessory holder permits the Chimera Video Pro Plus to be fitted directly,
  • One-arm stirrup allows a variety of pan-and-tilt possibilities
  • No tools required to change the bulb
  • Compact design; smaller and lighter housing than the previous ARRILITE 800 model
  • Aluminum housing enables heat dissipation
  • Heat-proof handle at rear of housing enables easy maneuvering
  • Compatible with ARRI 650 Plus accessories
Category
Series
Model
ARRILITE 750 Plus
Mains Plug
Schuko, Bare Ends
Lamphead Type
Open Face with parabolic facetted reflector, 750 W
Reflector
MAX reflector made of high purity aluminium
Lamp Type
HPL** 750 W, 575 W, 375 W; GKV*** 600 W, FKR 650 W, HX 800 W
Power Consumption
800 W, 750 W, 650 W, 600 W, 575 W, 375 W
Voltage Range
100 to 240 V
Lamp Base
G9.5
Dimming
yes, 0 to 100 % via external dimming system
Correlated Color Temperature
3,200 K
Beam Angle
21° to 73°
Weight in kg net*
approx. 2 kg
Weight in kg packed*
approx. 3 kg
Weight in lbs. net*
approx. 4 lbs
Weight in lbs. Packed*
approx. 7 lbs
226 x 230 x 224 mm
8.9 x 9.1 x 8.8"
260 x 230 x 290 mm
10.2 x 9.1 x 11.4"
150 mm
5.9"
Accessory Diameter in mm
168 mm
Accessory Diameter in inch
6.6" (Scrim)
Barndoor in mm
168 mm
Barndoor in inch
6.6"
Mounting
Socket 16 mm / 5/8" (0.6")
Housing Color
Blue
Protection Class / IP Rating
I / IP20
Certifications
CE, UKCA, CB, ENEC, cNRTLus
Note *Weight and dimensions are rounded values. <br/> **HPL lamp invented by and licensed from David Cunningham <br/> *** in combination with lamp cooling adapter L2.36770.0
