cPRO© used by Martin Larsen.
cPRO & cPRO One
cPro (1)
cmotions advanced lens control system
The cPRO hand unit is a feature packed work horse offering ultimate control in a balanced and ergonomic design.
cPRO
  • 3-axis wireless cPRO hand unit with integrated lens data display
  • Intuitive thumb wheel provides quick and easy access to the menu settings and can be assigned as a 4th axis controller
  • User-friendly interface for lens and camera control.
  • Re-designed focus knob with a non-slip concave fingertip moulding and mechanical hard stops
  • “Panic” button allows to overrule mechanical hard stops
  • Power and update through USB
  • Compatible with cmotion's Cinefade VariND through either a cPRO motor or cPRO camin. It can also be assigned for dynamic variable ND / RotaPola control or the Cinefade effect.
  • Includes red-coded radio modules. Not compatible with ARRI white-coded radio modules.
cPRO one
  • 1-axis wireless cPRO ONE hand unit
  • Integrated lens data display
  • Optional 2nd axis control through thumbwheel,
  • Mechanical limits and a "panic button"
cPRO motor
  • Lens motor with a built-in wireless receiver
  • Designed for weight and size-critical setups
  • Provides a versatile interface for power, run/stop and camera control/feedback for the most popular cameras
  • Can be expanded with up to 2 additional cforce motors
cPRO camin
  • cmotion’s smallest motor controller
  • Provides a versatile interface for power, run/stop and camera control/feedback for the most popular cameras and wireless control on EF lenses for an ultra-lightweight configuration
  • Can be expanded with up to 3 additional cforce motors
cPRO
cPRO one
cPRO motor
cPRO camin
cPRO
cPRO one
cPRO motor
cPRO camin
Quotes
I would never claim focus pulling to be easy.  But my life got a lot easier with the cPro from cmotion. The superfast responsive motor and the camera control for ARRI, Red and Sony are the most impressive features for me.
1st AC Rozemarijn Stokkel, Netherlands (Known for: De Piraten van Hiernaast, De Grote Slijmfilm, Onze Jongens in Miami, The Last Vermeer, Hunter Street, Divorce and many more)
The shooting environments nowadays are getting more and more challenging for 1st ACs. cPro gives you those extra features to adapt ourselves to the new times. It is reliable, fast and responsive, accurate and very customizable for every focus puller needs.
1st AC Carlos Cañal, Spain (Known for: La peste, Terminator: Dark Fate, Salir del ropero, Élite, Lejos de ti, Lo nunca visto and many more)
One of the things I love of the cPro system is that with all its assignable buttons it’s like a custom-tailored suit, that fits like a glove to my shooting needs.
1st AC Fabio Giolitti, Spain (Known for:Por H o por B, Criminal: France, Criminal: Germany, Criminal: Spain, Lejos de ti, La peste and many more)
The cPro gives me the freedom and flexibility to achieve control over 4 axis. In the modern era of digital cameras the possibility to have camera control makes adjusting certain camera parameters a breeze. Because of the daily high-pressure on set you need a hand-unit you can trust, day in and day out in every situation. The cPro is the perfect companion to keep me calm and makes me “focus” on the job as it should be.
1st AC Vincent Aaron Segers, Belgium (Known for: Blackout, Calibro 9, De zonen van Van As, De Twaalf, The kidnapping of Phil Frisco, Grenslanders and many more)
Compatibility
Functionality
Recommended Products cPro
Recommended Products cPro One
cPRO on set © Andrew Bradford
cPRO © Andrew Bradford
cPRO on set_2
cPRO and 1st AC Martin Larsen
cPRO hand unit and cPRO motor (2)
cPRO on set_2
cPRO on set_2
