Six-color LED light engine
Incorporating red, green, blue, amber, cyan, and lime LEDs, the ARRI Spectra six-color light engine provides a wider color gamut, more accurate colors, and most importantly, higher color rendition across the entire CCT range.
Wide gamut
Hues are precisely reproduced and the increased gamut allows for 15% more color possibilities than previous ARRI light engines.
Ultra-high color rendition
Orbiter has a larger CCT range of 2,000 to 20,000 K with ultra-high color rendering across all color temperatures. Skin tones look natural and flattering.
Compact light engine
Orbiter's light engine uses innovative LEDs to create a completely homogeneous color beam field. This light engine delivers a unique and unprecedented amount of brightness, which is achieved through the precise arrangement of the light-emitting diodes.
Color sensor
The Orbiter color sensor mode reads the ambient color surrounding the fixture and reproduces the color with great accuracy and quality.
This way you have fast and accurate color matching for location work. Just daisy-chain to more Orbiters, or use measured xy coordinates on other fixtures.
