Enso_Lens_Range_Teaser_Image
Ensō lens range
14 lenses, 2 extenders, 16 focal lengths
ENSO-001_ENSO_02_0000 Kopie
Uniform lens housings
Gear rings are in the same position on all 14 of the Ensō focal lengths, most of which have a front diameter of 95 mm, so they can be swapped on the camera without disruption. The focal lengths in the core sales set of six lenses will be the most frequently used, but the wide-angle 10.5 and 14 mm, as well as the telephoto 250 mm (350/500 mm with its included 1.4x/2x Extenders) allow Ensō shooters to meet even the most extreme visual demands.
Explore the Ensō lens range
Ensō_10.5
10.5 mm
Ensō_14
14 mm
Ensō_18
18 mm
Ensō_21
21 mm
Ensō_24
24 mm
Ensō_28
28 mm
Ensō_32
32 mm
Ensō_40
40 mm
Ensō_47
47 mm
Ensō_58
58 mm
Ensō_75
75 mm
Ensō_105
105 mm
Ensō_150
150 mm
Ensō_250
250 mm
