ALEXA_Mini_LF_SUP_7-3_M20_Headerimage@2x
ALEXA Mini LF SUP 7.3
October 18, 2023
The latest software release for ALEXA Mini LF is all about control and interface enhancements, opening up compatibility with the Camera Control Monitor CCM-1 and enabling touchscreen operation of the MVF-2 flip-out monitor, among other improvements.
Headlining the new features of ALEXA Mini LF SUP 7.3 is support for ARRI’s new Camera Control Monitor CCM-1. The CCM-1 provides full camera control and menu access, combining ARRI color accuracy and a bright display with customizable controls, rugged build quality, and well-thought-out accessories.
To guarantee stable functionality of the CCM-1 with the new SUP 7.3 for ALEXA Mini LF, please make sure your CCM-1 is also running the latest software version: SUP 5.5.1. More information about the CCM-1 can be found in the CCM-1 release notes on the CCM-1 software download page here.
Additionally, the new software update enables touchscreen operation of the flip-out monitor on the MVF-2 viewfinder. While the hardware has always had this capability, it is only now that the user interface has been developed to a point where touchscreen functionality can speed up workflows on set and in prep.
ALEXA Mini LF SUP 7.3 also introduces other benefits such as support for WPA-3 client mode, an extended erase media warning, support for LAN static gateway settings, and a lot of stability improvements. For a full list of all new features, please refer to the release notes. Updates to the online Camera Simulator are in progress and should be completed soon.
Updating 
ALEXA Mini LF SUP 7.3 can be installed on all previously shipped ALEXA Mini LF cameras, and we recommend updating from ALEXA Mini LF SUP 7.2 to SUP 7.3. However, we do not recommend updating to a new SUP in the middle of a production.
Important note: no device should be connected to the LPL mount during an update, otherwise the update will fail and must be executed again.
Please read through the release notes, which contain detailed update instructions, before you update your camera.
Downdating 
It is possible to downdate from ALEXA Mini LF SUP 7.3 to an older SUP. However, MVF-2 viewfinders with serial numbers above 6849 and Compact Drive 2TB units with serial numbers starting with 273xxxxx are not compatible with older ALEXA Mini LF SUPs.
Registration  
If you have not done so already, please make sure you register your camera using our online customer registration. Your registration ensures that you receive information about future software updates as soon as they become available. If you register your new camera within one month of purchase, you will get a one-year extended warranty for free.
You can find registration details here
End User License Agreement
    1. Definitions. "Software" means (a) all of the contents of the files provided under this Agreement, including but not limited to (i) Software as provided together with this licence agreement for download at the ARRI website, or provided to you whether on disk, in read only memory or any other media or in any other form (ii) any related files to the Software and (iii) related explanatory written materials or files or oral information ("Documentation"); and (b) upgrades, modified versions, updates, bug fixes, additions, and copies of the Software, if any, licensed to you by ARRI, unless they are accompanied by a separate licence or licence agreement (collectively, "Updates"). "Use" or "Using" means to access, install, download, copy, use or otherwise benefit from using the functionality of the Software in accordance with the Documentation. "Free Functionality" means any free functionality which the Software provides automatically without the need for a License Key; "Paid for Functionality" means any functionality of the Software other than Free Functionality, which must be paid for or otherwise requires a License Key; "Licence Key" means a license key which activates and enables use of the Software or any Paid-For Functionality within the Software, for a defined period of time. The scope of the rights and permissions granted by any License Key and its duration will be as specified by ARRI at the time you order and purchase the same from ARRI or are otherwise supplied with the same; "Permitted Number" means one (1) unless otherwise indicated under a valid license (e.g. volume license) granted by ARRI. "Device" means a camera system, accessories and/or any other product manufactured by ARRI, identified by a specific ARRI serial number and internal product code, that is intended, prepared or dedicated for use with the Software and specified in the Software or the order form. "ARRI" means Arnold & Richter Cine Technik GmbH & Co Betriebs KG, Herbert-Bayer-Str. 10, 80807 München.
    2. Software License.
    4. Restrictions.
    5. NO WARRANTY. The Software is being delivered to you "AS IS" and ARRI makes no warranty as to its use, capabilities or performance. ARRI AND ITS SUPPLIERS DO NOT AND CANNOT WARRANT THE PERFORMANCE OR RESULTS YOU MAY OBTAIN BY USING THE SOFTWARE. EXCEPT FOR ANY WARRANTY, CONDITION, REPRESENTATION OR TERM TO THE EXTENT TO WHICH THE SAME CANNOT OR MAY NOT BE EXCLUDED OR LIMITED BY LAW APPLICABLE TO YOU IN YOUR JURISDICTION, ARRI AND ITS SUPPLIERS MAKE NO WARRANTIES CONDITIONS, REPRESENTATIONS, OR TERMS (EXPRESS OR IMPLIED WHETHER BY STATUTE, COMMON LAW, CUSTOM, USAGE OR OTHERWISE) AS TO ANY MATTER INCLUDING WITHOUT LIMITATION NONINFRINGEMENT OF THIRD PARTY RIGHTS, MERCHANTABILITY, INTEGRATION, SATISFACTORY QUALITY, OR FITNESS FOR ANY PARTICULAR PURPOSE. IF APPLICABLE LAW REQUIRES ANY WARRANTIES WITH RESPECT TO THE FREE FUNCTIONALITY OF THE SOFTWARE, ALL SUCH WARRANTIES ARE LIMITED IN DURATION TO NINETY (90) DAYS FROM THE DATE OF DELIVERY. IF APPLICABLE LAW REQUIRES ANY WARRANTIES WITH RESPECT TO THE PAID FOR FUNCTIONALITY OF THE SOFTWARE, ALL SUCH WARRANTIES ARE LIMITED IN DURATION TO ONE YEAR FROM THE DATE OF DELIVERY. NO ORAL OR WRITTEN INFORMATION OR ADVICE GIVEN BY ARRI OR ITS EMPLOYEES SHALL CREATE A WARRANTY OR IN ANY WAY INCREASE THE SCOPE OF ANY WARRANTY PROVIDED HEREIN. You must inspect the Software immediately upon its receipt and must notify ARRI in writing of any apparent defects within one week. ARRI must be notified of hidden defects in writing within two weeks of their emergence. In the event that the customer has notified ARRI of defects in a timely manner and is thus eligible to make a claim for re-performance, ARRI shall have the right, at its own cost, either to remedy the defect or to redeliver. Any warranty explicit given by ARRI or constructed under any law theory does not apply if the Software (i) has been altered, except by ARRI, (ii) has been subject to abnormal physical or electrical stress, misuse, negligence or accident or (iii) is used in hazardous activities. The provisions of Section 5 and Section 6 shall survive the termination of this Agreement, howsoever caused, but this shall not imply or create any continued right to Use the Software after termination of this Agreement.
SUP Download Archive
