data
ALEXA LF SUP 4.3
September 15, 2021
ALEXA LF SUP 4.3
This update includes useful enhancements to the usability of the monitoring overlays and the use of the ALEXA LF camera with ARRI Rental DNA and Cooke /i lenses. This includes a fix for the orange line bug and the replacement of the MAGNIFICATION indication orange line/outline by MAGNIFICATION icons in the status area to the right of the image.
LF SUP 4.3 requires LF SUP 3.0 Software & Hardware Upgrade
LF SUP 4.3 should only be installed on ALEXA LF cameras that have previously undergone the "ALEXA LF 3.0 Software & Hardware Upgrade", which can be performed free-of-charge by ARRI service. The ALEXA LF 3.0 upgrade includes the upgrade of an electronics board (ACDA3 gets exchanged for ACDA4), and LF SUP 4.0, 4.1, 4.2 and 4.3 require the ACDA4 board. LF SUP 4.3 will not run on ALEXA LF cameras with the older ACDA3 board installed (any camera running LF SUP 2.0 or LF SUP 2.1).
Upgrade Paths
  • If your ALEXA LF has LF SUP 2.0 or 2.1: contact ARRI Service to schedule your free upgrade to "ALEXA LF 3.0 Software and Hardware". ARRI service will then also install LF SUP 4.3. More information about the "ALEXA LF 3.0 Software and Hardware Upgrade" can be found in the SUP Download Archive below.
  • If your ALEXA LF has LF SUP 3.0, 4.0, 4.1 or 4.2: Download LF SUP 4.3 and install.
Downdating
Once LF SUP 4.3 is installed, it is possible to revert back to LF SUP 4.0, LF SUP 4.1 and LF SUP 4.2, but not to LF SUP 3.0 or older. However, we do not recommend to downgrade to SUP versions prior to LF SUP 4.3.
End User License Agreement
    1. Definitions. "Software" means (a) all of the contents of the files provided under this Agreement, including but not limited to (i) Software as provided together with this licence agreement for download at the ARRI website, or provided to you whether on disk, in read only memory or any other media or in any other form (ii) any related files to the Software and (iii) related explanatory written materials or files or oral information ("Documentation"); and (b) upgrades, modified versions, updates, bug fixes, additions, and copies of the Software, if any, licensed to you by ARRI, unless they are accompanied by a separate licence or licence agreement (collectively, "Updates"). "Use" or "Using" means to access, install, download, copy, use or otherwise benefit from using the functionality of the Software in accordance with the Documentation. "Free Functionality" means any free functionality which the Software provides automatically without the need for a License Key; "Paid for Functionality" means any functionality of the Software other than Free Functionality, which must be paid for or otherwise requires a License Key; "Licence Key" means a license key which activates and enables use of the Software or any Paid-For Functionality within the Software, for a defined period of time. The scope of the rights and permissions granted by any License Key and its duration will be as specified by ARRI at the time you order and purchase the same from ARRI or are otherwise supplied with the same; "Permitted Number" means one (1) unless otherwise indicated under a valid license (e.g. volume license) granted by ARRI. "Device" means a camera system, accessories and/or any other product manufactured by ARRI, identified by a specific ARRI serial number and internal product code, that is intended, prepared or dedicated for use with the Software and specified in the Software or the order form. "ARRI" means Arnold & Richter Cine Technik GmbH & Co Betriebs KG, Herbert-Bayer-Str. 10, 80807 München.
    2. Software License.
    4. Restrictions.
    5. NO WARRANTY. The Software is being delivered to you "AS IS" and ARRI makes no warranty as to its use, capabilities or performance. ARRI AND ITS SUPPLIERS DO NOT AND CANNOT WARRANT THE PERFORMANCE OR RESULTS YOU MAY OBTAIN BY USING THE SOFTWARE. EXCEPT FOR ANY WARRANTY, CONDITION, REPRESENTATION OR TERM TO THE EXTENT TO WHICH THE SAME CANNOT OR MAY NOT BE EXCLUDED OR LIMITED BY LAW APPLICABLE TO YOU IN YOUR JURISDICTION, ARRI AND ITS SUPPLIERS MAKE NO WARRANTIES CONDITIONS, REPRESENTATIONS, OR TERMS (EXPRESS OR IMPLIED WHETHER BY STATUTE, COMMON LAW, CUSTOM, USAGE OR OTHERWISE) AS TO ANY MATTER INCLUDING WITHOUT LIMITATION NONINFRINGEMENT OF THIRD PARTY RIGHTS, MERCHANTABILITY, INTEGRATION, SATISFACTORY QUALITY, OR FITNESS FOR ANY PARTICULAR PURPOSE. IF APPLICABLE LAW REQUIRES ANY WARRANTIES WITH RESPECT TO THE FREE FUNCTIONALITY OF THE SOFTWARE, ALL SUCH WARRANTIES ARE LIMITED IN DURATION TO NINETY (90) DAYS FROM THE DATE OF DELIVERY. IF APPLICABLE LAW REQUIRES ANY WARRANTIES WITH RESPECT TO THE PAID FOR FUNCTIONALITY OF THE SOFTWARE, ALL SUCH WARRANTIES ARE LIMITED IN DURATION TO ONE YEAR FROM THE DATE OF DELIVERY. NO ORAL OR WRITTEN INFORMATION OR ADVICE GIVEN BY ARRI OR ITS EMPLOYEES SHALL CREATE A WARRANTY OR IN ANY WAY INCREASE THE SCOPE OF ANY WARRANTY PROVIDED HEREIN. You must inspect the Software immediately upon its receipt and must notify ARRI in writing of any apparent defects within one week. ARRI must be notified of hidden defects in writing within two weeks of their emergence. In the event that the customer has notified ARRI of defects in a timely manner and is thus eligible to make a claim for re-performance, ARRI shall have the right, at its own cost, either to remedy the defect or to redeliver. Any warranty explicit given by ARRI or constructed under any law theory does not apply if the Software (i) has been altered, except by ARRI, (ii) has been subject to abnormal physical or electrical stress, misuse, negligence or accident or (iii) is used in hazardous activities. The provisions of Section 5 and Section 6 shall survive the termination of this Agreement, howsoever caused, but this shall not imply or create any continued right to Use the Software after termination of this Agreement.
