CS_M20_sup_alexa_sxt_2
ALEXA SXT SUP 2.1
September 15, 2021
Software Update Package (SUP) 2.1 for ALEXA SXT cameras contains:
New Features Overview
Note: there are no feature changes between SXT SUP 2.0 and SXT SUP 2.1.
Support for new Hardware Component
  • A hardware component on an electronic board has been discontinued by its manufacturer and this SUP supports the original component as well as the replacement component.
Update Information
There is no need to update existing ALEXA SXT and SXT W cameras to SXT SUP 2.1. The only time the update is needed is when service has to install a new board in your camera, and then they will perform the update.
ALEXA SXT SUPs should only be installed on ALEXA SXT cameras, and are not compatible with ALEXA Classic, ALEXA Classic cameras with the XR Module upgrade and ALEXA XT cameras. Make sure not to power off the camera during a SUP update. Detailed instructions for the update process can be found at the end of this document.
Warning: Do not install the SXT SUP onto a camera model it is not made for! Do not attempt to install these SUPs on ALEXA HD, ALEXA HD Plus, ALEXA Fiber Remote, ALEXA Fiber Remote Plus, ALEXA Classic, ALEXA Classic with the XR Module upgrade, ALEXA XT, ALEXA LF, AMIRA, ALEXA Mini or ALEXA Mini LF cameras! Doing so may cause the camera to malfunction and become inaccessible. If that happens, the camera can only be made accessible with the support of an ARRI Service Center. Similarly, SUPs for older ALEXA cameras should not be installed on ALEXA SXT cameras.
Downgrading
Please note that, once SXT SUP 2.1 is installed, it is not possible to revert back to any previous release version prior to SXT SUP 2.1.
Software Update Package (SUP) 2.0 for ALEXA SXT cameras contains:
A more detailed description of each feature is given in the section 'New Features and Changes'.
Support for Wireless video (ALEXA SXT W only)
Support for WiFi (ALEXA SXT W only)
Faster frame grabs (ALEXA SXT W only)
Improved HDR monitoring (all ALEXA SXT cameras)
  • Default look files for PQ and HLG
  • Automatically matched status brightness for HDR
  • HDR metadata
False Color Mode (all ALEXA SXT cameras)
  • Monitoring-based or Log C-based
Support for SxS PRO+ 128 and 256 GB cards (all ALEXA SXT cameras)
Expanded ARRI Electronic Control System support (all ALEXA SXT cameras)
  • Live camera information (warnings & errors) on WCU‑4
  • Separate control of MON OUT 1, 2 and 3
  • Faster Controlled Lens Motor (CLM) response
  • Lens motor auto teeth detection for accurate WCU‑4 lens data display
Update Information
Cameras should always run the latest SUP so you can benefit from the latest improvements, features and bug fixes. We do not, however, recommend installing a new SUP in the middle of a production.
ALEXA SXT SUPs should only be installed on ALEXA SXT cameras, and are not compatible with ALEXA Classic, ALEXA Classic cameras with the XR Module upgrade and ALEXA XT cameras. Detailed instructions for the update process can be found at the end of this document.
Downgrading
Please note that, once SXT SUP 2.0 is installed, it is not possible to revert back to any previous release version prior to SXT SUP 2.0 (ALEXA SXT W cameras only work with SUP 2.0 or later, anyway).
End User License Agreement
    1. Definitions. "Software" means (a) all of the contents of the files provided under this Agreement, including but not limited to (i) Software as provided together with this licence agreement for download at the ARRI website, or provided to you whether on disk, in read only memory or any other media or in any other form (ii) any related files to the Software and (iii) related explanatory written materials or files or oral information ("Documentation"); and (b) upgrades, modified versions, updates, bug fixes, additions, and copies of the Software, if any, licensed to you by ARRI, unless they are accompanied by a separate licence or licence agreement (collectively, "Updates"). "Use" or "Using" means to access, install, download, copy, use or otherwise benefit from using the functionality of the Software in accordance with the Documentation. "Free Functionality" means any free functionality which the Software provides automatically without the need for a License Key; "Paid for Functionality" means any functionality of the Software other than Free Functionality, which must be paid for or otherwise requires a License Key; "Licence Key" means a license key which activates and enables use of the Software or any Paid-For Functionality within the Software, for a defined period of time. The scope of the rights and permissions granted by any License Key and its duration will be as specified by ARRI at the time you order and purchase the same from ARRI or are otherwise supplied with the same; "Permitted Number" means one (1) unless otherwise indicated under a valid license (e.g. volume license) granted by ARRI. "Device" means a camera system, accessories and/or any other product manufactured by ARRI, identified by a specific ARRI serial number and internal product code, that is intended, prepared or dedicated for use with the Software and specified in the Software or the order form. "ARRI" means Arnold & Richter Cine Technik GmbH & Co Betriebs KG, Herbert-Bayer-Str. 10, 80807 München.
    2. Software License.
    4. Restrictions.
    5. NO WARRANTY. The Software is being delivered to you "AS IS" and ARRI makes no warranty as to its use, capabilities or performance. ARRI AND ITS SUPPLIERS DO NOT AND CANNOT WARRANT THE PERFORMANCE OR RESULTS YOU MAY OBTAIN BY USING THE SOFTWARE. EXCEPT FOR ANY WARRANTY, CONDITION, REPRESENTATION OR TERM TO THE EXTENT TO WHICH THE SAME CANNOT OR MAY NOT BE EXCLUDED OR LIMITED BY LAW APPLICABLE TO YOU IN YOUR JURISDICTION, ARRI AND ITS SUPPLIERS MAKE NO WARRANTIES CONDITIONS, REPRESENTATIONS, OR TERMS (EXPRESS OR IMPLIED WHETHER BY STATUTE, COMMON LAW, CUSTOM, USAGE OR OTHERWISE) AS TO ANY MATTER INCLUDING WITHOUT LIMITATION NONINFRINGEMENT OF THIRD PARTY RIGHTS, MERCHANTABILITY, INTEGRATION, SATISFACTORY QUALITY, OR FITNESS FOR ANY PARTICULAR PURPOSE. IF APPLICABLE LAW REQUIRES ANY WARRANTIES WITH RESPECT TO THE FREE FUNCTIONALITY OF THE SOFTWARE, ALL SUCH WARRANTIES ARE LIMITED IN DURATION TO NINETY (90) DAYS FROM THE DATE OF DELIVERY. IF APPLICABLE LAW REQUIRES ANY WARRANTIES WITH RESPECT TO THE PAID FOR FUNCTIONALITY OF THE SOFTWARE, ALL SUCH WARRANTIES ARE LIMITED IN DURATION TO ONE YEAR FROM THE DATE OF DELIVERY. NO ORAL OR WRITTEN INFORMATION OR ADVICE GIVEN BY ARRI OR ITS EMPLOYEES SHALL CREATE A WARRANTY OR IN ANY WAY INCREASE THE SCOPE OF ANY WARRANTY PROVIDED HEREIN. You must inspect the Software immediately upon its receipt and must notify ARRI in writing of any apparent defects within one week. ARRI must be notified of hidden defects in writing within two weeks of their emergence. In the event that the customer has notified ARRI of defects in a timely manner and is thus eligible to make a claim for re-performance, ARRI shall have the right, at its own cost, either to remedy the defect or to redeliver. Any warranty explicit given by ARRI or constructed under any law theory does not apply if the Software (i) has been altered, except by ARRI, (ii) has been subject to abnormal physical or electrical stress, misuse, negligence or accident or (iii) is used in hazardous activities. The provisions of Section 5 and Section 6 shall survive the termination of this Agreement, howsoever caused, but this shall not imply or create any continued right to Use the Software after termination of this Agreement.
SUP Download Archive
