ARRI Ensō Primes | 10.5 mm / T2.8 | 14 mm / T2.5 | 18 mm / T2.1 | 21 mm / T2.1 |
Optical Parameters | ||||
Focal length | 10.5 mm | 14 mm | 18 mm | 21 mm |
Magnification ratio at MOD | 1:10 | 1:8 | 1:4 | 1:4 |
Entrance pupil position (related to image plane, in direction to object plane) | 160.3 mm / 6.3" | 151.9 mm / 6" | 134.3 mm / 5.3" | 131.6 mm / 5.2" |
Angle of view H-V-D for LF Open Gate | 60.40° / 50.67° / 65.00° | 52.61° / 42.29° / 58.05° | 46.13° / 35.68° / 51.77° | 41.62° / 31.65° / 47.21° |
Physical Dimensions | ||||
Lens barrel | Aluminum | Aluminum | Aluminum | Aluminum |
Focus barrel rotation | 318° | 318° | 318° | 318° |
Iris barrel rotation | 48° | 48° | 48° | 48° |
Gear | Module 0.8 | Module 0.8 | Module 0.8 | Module 0.8 |
Interfaces | ||||
Lens mount | LPL | LPL | LPL | LPL |
Lens data system | LDS-2 | LDS-2 | LDS-2 | LDS-2 |
Electronic magnetic rear filter interface | yes | yes | yes | yes |
ARRI Ensō Primes | 24 mm / T2.1 | 28 mm / T2.1 | 32 mm / T2.1 | 40 mm / T2.1 |
Focal length | 24 mm | 28 mm | 32 mm | 40 mm |
Magnification ratio at MOD | 1:4 | 1:4 | 1:4 | 1:4 |
Entrance pupil position (related to image plane, in direction to object plane) | 131.8 mm / 5.2" | 118.8 mm / 4.7" | 119.5 mm / 4.7" | 117.2 mm / 4.6" |
Angle of view H-V-D for LF Open Gate | 37.60° / 28.22° / 43.03° | 33.47° / 24.70° / 38.67° | 29.84° / 21.79° / 34.88° | 24.78° / 17.78° / 29.34° |
Interfaces | ||||
ARRI Ensō Primes | 47 mm / T2.1 | 58 mm / T2.1 | 75 mm / T2.1 | 105 mm / T2.1 |
Focal length | 47 mm | 58 mm | 75 mm | 105 mm |
Entrance pupil position (related to image plane, in direction to object plane) | 124.5 mm / 4.9" | 115.6 mm / 4.6" | 119.9 mm / 4.7" | 122.7 mm / 4.8" |
Angle of view H-V-D for LF Open Gate | 21.41° / 15.24° / 25.56° | 17.56° / 12.42° / 21.03° | 13.81° / 9.69° / 16.71° | 9.89° / 6.93° / 11.97° |
Interfaces | ||||
ARRI Ensō Primes | 150 mm / T2.1 | 250 mm / T2.1 | 250 mm / T2.1 + 1.4x Extender | 250 mm / T2.1 + 2.0x Extender |
Focal length | 150 mm | 250 mm | 350 mm | 500 mm |
Magnification ratio at MOD | 1:4 | 1:4 | 1:2.9 | 1:2 |
Entrance pupil position (related to image plane, in direction to object plane) | 131.5 mm / 5.2" | 128.3 mm / 5.1" | 161.0 mm / 6.3" | 172.8 mm / 6.8" |
Angle of view H-V-D for LF Open Gate | 6.96° / 4.86° / 8.44° | 4.18° / 2.93° / 5.09° | 3.01° / 2.09° / 3.67° | 2.11° / 1.46° / 2.57° |
Iris barrel rotation | 47.5° | 48° | 48° | 48° |
Interfaces | ||||
