Orbiter_Fresnel_M20_Headerimage
Orbiter Fresnel Lens 15-65°
Exploring yet another galaxy
Orbiter Fresnel Lens 15-65┬░ - White_BG
The Orbiter Fresnel Lens creates a precise light spot with a soft single shadow, and it delivers true Fresnel output with a real Gaussian field of light. The light output of Orbiter with the Fresnel lens is comparable to the ARRI L-Series L10 and True Blue ST2/3 with 2000 W Tungsten bulb.
Orbiter Fresnel Lens 15-65º
L2.0039436
Orbiter Black + Fresnel - Side - USP
Features:
  • Large and fully motorized zoom range of 15-65°
  • Zoom range can be controlled locally or remotely
  • A status LED display shows the current zoom angle
  • 4- and 8-leaf barndoors can be added
  • Effortless mounting thanks to Orbiters's QLM system
  • Can be attached to any Orbiter color version
Tech Specs
1920x804_Cinemascope_Orbiter_Fresnel_Lens_Loop_poster_frame
Application possibilities
Orbiter-Fresnel-Lens-in-use-1
Orbiter-Fresnel-Lens-in-use-2
hjSlide-16_9---2
Orbiter Fresnel status LED display
Equipped with a display, status LED, and a high-resolution encoder, the Orbiter Fresnel lens offers information that is easily accessible. The display backlight can be adjusted, and status information and zoom angle are available via the metadata for maintenance and postproduction needs.
Mounting and accessory application
Orbiter’s unique Quick Lighting Mount (QLM) system allows the Orbiter Fresnel lens to be mounted safely and quickly. ARRI accessories like the 4 and 8-leaf barndoors can be added to the new Orbiter Fresnel lens to enable a perfect cut. Physical gels can also be used in addition to the more than 300 already pre-programmed gels available for Orbiter.
Orbiter-CU---Quick-Lighting-Mount---01-slight-angle
Orbiter Fresnel Set
Elevate Cinematic, Broadcast, and Live Productions with Cutting-Edge Fresnel Lens and ARRI Spectra Light Engine!
Click through the set L0.0050673 here.
orbiter_sales_100y_image_map_fresnel
Orbiter Blue/Silver
1
Manual Yoke
2
Power Cable w. Switch Bare Ends
3
Orbiter Control Panel with Cable
4
5
Open Face Optics
6
  • Orbiter Blue/Silver
    1
    The ARRI Orbiter is a versatile, tuneable, and directional LED fixture including a six-color light engine. With its changeable optics, Orbiter can transform into many different types of lamphead.
    L1.0033520
  • Manual Yoke
    2
    The yokes for Orbiter come with a newly developed release system that allows for quick change from a manual version lamphead to a pole operated version. The 28 mm spigot (Junior pin) is already mounted on the yoke. No tools needed for setting up Orbiter.
    • Quick release system
    • No tools needed
    • Manual yoke made of high strength aluminum profile
    • Steel yoke for pole operation (pan, tilt)
    • Includes 28 mm spigot (Junior pin)
    L2.0034025
  • Power Cable w. Switch Bare Ends
    3
    The mains cables connect Orbiter to a mains power outlet (100-240 V~, 50/60 Hz).
    • powerCON TRUE1 TOP connector
    • Line switch
    • Lengths: 3 m / 9.8 ft.
    • Rubber insulated cable H07RN-F 3G1,5, EN
    L2.0024627
  • Orbiter Control Panel with Cable
    4
    Redesigned from the ground up, the Orbiter control panel is an evolutionary step in light fixture control. Including a 4" full-color display, quick navigation buttons, and integrated sensors, the Orbiter control panel allows for easy use with a graphic user interface. Simplified menu structure and reimagined user interfaces provide one-glance operational views and uncluttered screens.
    This intuitive design makes changing colors or finding a setting easier than ever before. In addition, the control panel is removable and can be used handheld with the aid of a control panel cable.
    • Quick navigation, advanced user interface, and simple menus
    • This set includes the Orbiter control panel cable 15 m / 49.2 ft. (L2.0033800)
    • Includes carrying pouch, lanyard & D-ring
    L2.0033732
  • Orbiter Fresnel Lens 15-65º
    5
    • compact housing (approx. 340 mm x 380 mm x 370 mm / 13.4 in x 15 in x 14.6 in)
    • lightweight (~ 4.5 kg / 9.5 lbs)
    • lens diameter of 285 mm / 11.2
    L2.0039436
  • Open Face Optics
    6
    On the occasion of our 100th anniversary of ARRI Lighting in 2024, we are giving you 3 Open Face Optics (15°, 30°, 60°) on top of every Orbiter Beam Set.
    The Open Face Optics produce a high-output, directional beam of light in several different beam angles including 15°, 30°, and 60°. They are perfect for throwing light long distances or providing a broad swath of light. The accessory slot can be used with modifiers such as barndoors or snoots.
    • Provides powerful, uniform beam of light
    • Attaches to the Quick Lighting Mount (QLM) on Orbiter
    • Contains digital optics identification
    • Fits 4-leaf & 8-leaf barndoors and snoots
    • Accessory slot size: 245 mm / 9.7"
    • Ships in foam insert that can be re-used for safe transportation and storage
    L2.0033540 (15°)
    L2.0033541 (30°)
    L2.0033542 (60°)
Get in touch
If you would like to receive an offer or have a specific request regarding the Orbiter Fresnel Lens, fill in the form and we will get in touch with you.
