L1.41015.B TRUE BLUE ST5 Theater-1
True Blue ST5 Theater
Black, Bright, TRUE BLUE
The ARRI Studio Fresnel series is the ideal choice for theaters requiring tungsten lampheads that can handle high temperatures and are free of spill light. The large, short focal length lenses provide an even and optimum light output. ARRI's elegant modular construction, using corrosion-free aluminium extrusions and lightweight die castings, offers great structural strength.
  • High efficiency wide-angle lenses
  • Corrosion-resistant aluminium construction
  • Extremely even light distribution
  • No spill light
  • Stirrup centre adjustment
  • Focus position indicator
  • Focus knob on front and rear
  • Easy service access
Category
Series
Model
Mains Plug
Bare Ends
Lamphead Type
Fresnel, 5,000 W
Reflector
Spherical specular high purity aluminium
Lamp Type
CP85 5,000 W / 230 V; CP29 5,000 W / 230 V
Power Consumption
5,000 W
Voltage Range
230 V
Lamp Base
G38
Dimming
yes, 0 to 100 % via external dimming system
Correlated Color Temperature
3,200 K
Beam Angle
9° to 58°
Weight in kg net*
approx. 22 kg
Weight in kg packed*
approx. 25 kg
Weight in lbs. net*
approx. 49 lbs
Weight in lbs. Packed*
approx. 55 lbs
838 x 534 x 427 mm
705 x 534x 427 mm
32.9 x 21.0 x 16.8"
27.8 x 21.0 x 16.8"
600 x 600 x 750 mm
23.6 x 23.6 x 29.5"
300 mm
11.8"
Accessory Diameter in mm
400 mm
Accessory Diameter in inch
15.8" (Filter Insertion)
Barndoor in mm
413 mm
Barndoor in inch
16.3"
Mounting
Spigot 28 mm / 1 1/8" (1.1")
Housing Color
Black
Protection Class / IP Rating
I / IP23
Certifications
CE, UKCA, CB, ENEC, cNRTLus
