L7-DT_Stage_Discontinued
L7-DT
Cut. Shape. Focus. Tune.
Daylight Tuneable allows for fine-tuning of the daylight color temperature from 5,000 K to 6,500 K with increased brightness over the L7-C, and is particularly suited to applications requiring precise matching to daylight balanced light sources.
STAND-MOUNT
versions include the following base configuration: 28 mm Spigot (Junior Pin), Inline Switch, Integrated 5-Pin DMX In and Thru.
HANGING
versions include the following base configuration: 28 mm Spigot (Junior Pin), 1,5 m (5 ft) Cable with Bare Ends, Integrated 5-Pin DMX In and Thru.
POLE-OPERATED
versions include the following base configuration: Pole Operation for Pan, Tilt and Focus, 28 mm Spigot (Junior Pin), 1,5 m (5 ft) Cable with Bare Ends, Integrated 5-Pin DMX In and Thru.
Cool Burning and Cost Saving
Focus Knobs
Sliding Stirrup
Yoke
Tilt Lock
Pole Operation
DMX Control
On-Board Control
Familiar, but Revolutionary
Even Light Field
Focus Knobs
Sliding Stirrup
Yoke
Tilt Lock
Pole Operation
DMX Control
On-Board Control
Even Light Field
Focus Knobs
Sliding Stirrup
Yoke
Tilt Lock
Pole Operation
DMX Control
On-Board Control
Even Light Field
Category
LED
Series
L-Series
Model
L7-DT
Optical System
Focusable Fresnel
175 mm
7.0"
Beam Angle
15° to 50° Half Peak Angle
Weight in kg net*
Manual Version: approx. 9 kg
Pole Operated Version: approx. 10 kg
Weight in kg packed*
Manual Version: approx. 14 kg
Pole Operated Version: approx. 14 kg
Weight in lbs. net*
Manual Version: approx. 18 lbs
Pole Operated Version: approx. 22 lbs
Weight in lbs. Packed*
Manual Version: approx. 31 lbs
Pole Operated Version: approx. 31 lbs
Manual Version: 571 x 374 x 351 mm
Pole Operated Version: 582 x 357 x 351 mm
Manual Version: 438 x 374 x 351 mm
Pole Operated Version: 467 x 357 x 351 mm
Manual Version: 22.5 x 14.7 x 13.8"
Pole Operated Version: 22.9 x 14.0 x 13.8"
Manual Version: 17.2 x 14.7 x 13.8"
Pole Operated Version: 18.4 x 14.0 x 13.8"
540 x 500 x 380 mm
21.3 x 19.7 x 15.0"
Handling
Mounting
Tilt Angle
+/- 90°
Lamphead Voltage Input
100 to 250 V ~, 50/60 Hz
Power Consumption
180 W Nominal, 220 W Maximum
Power Connection
Battery Connector
Battery DC Voltage Range
White Light
5,000 K to 6,500 K continuously variable correlated color temperature
Colored Light
Color Temperature Tolerance
Color Rendition
CRI Average > 92
Green-Magenta Adjustment
Dimming
0 to 100 % continuous
Wireless Control
Not integrated, via SkyLink
Software / Mini-USB Interface
Housing Color
Blue/Silver, Black
Ambient Temperature Operation
-20 to +45° C (-4 to +113° F)
Protection Class / IP Rating
I / IP20
Estimated LED Lifetime (L70)
50,000 hours
+/- 5 %
Certifications
CE, CB, GS, cNRTLus, FCC, PSE
