M20_SkyPanel_s30RP
SkyPanel S30-RP
Soft Lighting | Redefined
Extra brightness, amazing color
In addition to the fully tuneable color versions of the SkyPanel, remote phosphor versions are also available for the S30. To make white LEDs, phosphors are typically placed directly on a single blue LED. Remote phosphor technology uses many powerful blue LEDs to excite a panel coated in phosphors, which is positioned further away from the LEDs.
  • Near-perfect color rendition and outstanding light output.
  • Slightly brighter than the color versions.
  • Lower price point due to less complex electronics.
  • Different color temperature panels are available, including 2,700 K; 3,200 K; 4,300 K; 5,600 K; 6,500 K; and 10,000 K.
  • Available for greenscreen lighting.
0301-orbiter-on-set-headerr-m20-content-stage-1920x737-2xFew
Category
LED
Series
SkyPanel
Model
Lamphead Type
LED Soft Light
Optical System
Remote Phosphor Panel
Weight in kg / lbs net*
Manual Version: approx. 7.7 kg / 17.0 lbs
Pole Operated Version: approx. 9.5 kg / 20.9 lbs
Fixture only, incl. Diffusion: approx. 6.3 kg / 13.9 lbs
Manual Version: approx. 14 kg / 31 lbs
Pole Operated Version: approx. 16 kg / 34 lbs
Manual Version: 499 x 507 x 133 mm /19.6 x 19.9 x 5.2"
Pole Operated Version: 567 x 504 x 133 mm / 22.3 x 19.8 x 5.2"
Manual Version: 426 x 507 x 133 mm / 16.8 x 19.9 x 5.2"
Pole Operated Version: 452 x 504 x 133 mm / 17.8 x 19.8 x 5.2"
470 x 665 x 300 mm / 18.5 x 26.2 x 11.8"
Housing Color
Blue/Silver, Black
Power Consumption
200 W Maximum
Lamphead Voltage Input
48 V DC
355 x 300 mm
14.0 x 11.8"
Beam Angle
105° (Half Peak Angle)
Handling
Aluminium Yoke, High-Strength Tilt Lock / Steel Yoke, Pole Operation for Pan & Tilt
Mounting
16 mm / 28 mm Combo Pin (Baby 5/8" / Junior 1-1/8" Combo.Pin) / 28 mm Spigot (Junior Pin)
Tilt Angle
+/- 90°
Lamphead Power Connection
Battery Connector
Battery DC Voltage Range
23 to 36 V DC
Battery Mode Light Output
100 % of total output
Lamp Type
Blue LED Light Engine (for Remote Phosphor Panels)
White Light
Changeable Remote Phosphor Panels:
10,000 K & Chroma Green
Colored Light
Color Temperature Tolerance
4 to 5 SDCM
Color Rendition
2,700K: CRI > 98, TLCI > 98,
3,200K: CRI > 98, TLCI > 98,
4,300K: CRI > 97, TLCI > 96,
5,600K: CRI > 97, TLCI > 96,
6,500K: CRI > 96, TLCI > 94,
10,000K: CRI > 92, TLCI > 88
Green-Magenta Adjustment
Dimming
0 to 100 % continuous
Wireless Control
Not integrated, via SkyLink
Software / Mini-USB Interface
Ambient Temperature Operation
-20 to +45° C (-4 to +113° F)
Protection Class / IP Rating
III / IP 20
Estimated LED Lifetime (L70)
50,000 hours
+/- 5 %
Certifications
Power Supply Unit
S30 PSU
Power Supply Input Range
110 to 240 V ~, 50/60 Hz
Power Supply Output Range
48 V DC
Power Supply Power Input Connection
Power Supply Power Output Connection
Weight in kg
approx. 2 kg
Weight in lbs
approx. 4.6 lbs
Measurements (HxWxL) in mm*
91 x 115 x 388 mm
Measurements (HxWxL) in inch*
3.6 x 4.5 x 15.3"
On-Board On/Off Switch
Power Supply Mounting
Power Supply Certifications
CE, UKCA, CB, ENEC, cNRTLus, PSE
Matching accessories
