M20_SkyPanel_s30
SkyPanel S30-C
Soft Lighting | Redefined
small & compact
  • ARRI SkyPanel S30-C: Half the length of the S60-C, ideal for mobile applications.
  • Lightweight and compact size makes it easy to use on-the-go.
  • Great brightness and color tuning capabilities, plus accessories.
  • Perfect for feature films or creating content for social media.
0301-orbiter-on-set-headerr-m20-content-stage-1920x737-2xF.jpg2
Category
LED
Series
SkyPanel
Model
Lamphead Type
LED Soft Light
Optical System
Swappaple Soft Diffusion Panel
Weight in kg / lbs net*
Manual Version: approx. 7.7 kg / 17.0 lbs
Pole Operated Version: approx. 9.5 kg / 20.9 lbs
Fixture only, incl. Diffusion: approx. 6.3 kg / 13.9 lbs
Manual Version: approx. 14 kg / 31 lbs
Pole Operated Version: approx. 16 kg / 34 lbs
Manual Version: 499 x 507 x 133 mm / 19.6 x 19.9 x 5.2"
Pole Operated Version: 567 x 504 x 133 mm / 22.3 x 19.8 x 5.2"
Manual Version: 426 x 507 x 133 mm / 16.8 x 19.9 x 5.2"
Pole Operated Version: 452 x 504 x 133 mm / 17.8 x 19.8 x 5.2"
470 x 665 x 300 mm / 18.5 x 26.2 x 11.8"
Housing Color
Blue/Silver, Black
Power Consumption
200 W Maximum
Lamphead Voltage Input
48 V DC
355 x 300 mm
14.0 x 11.8"
Beam Angle
105° (Half Peak Angle)
Handling
Aluminium Yoke, High-Strength Tilt Lock / Steel Yoke, Pole Operation for Pan & Tilt
Mounting
16 mm / 28 mm Combo Pin (Baby 5/8" / Junior 1-1/8" Combo.Pin) / 28 mm Spigot (Junior Pin)
Tilt Angle
+/- 90°
Lamphead Power Connection
Battery Connector
Battery DC Voltage Range
23 to 36 V DC
Battery Mode Light Output
100 % of total output
Lamp Type
RGBW LED Light Engine
White Light
Colored Light
Color Temperature Tolerance
Color Rendition
CRI Average > 95, TLCI Average > 91
Green-Magenta Adjustment
Dimming
0 to 100 % continuous
Wireless Control
Not integrated, via SkyLink
Software / Mini-USB Interface
Ambient Temperature Operation
-20 to +45° C (-4 to +113° F)
Protection Class / IP Rating
III / IP 20
Estimated LED Lifetime (L70)
50,000 hours
+/- 5 %
Certifications
Power Supply Unit
S30 PSU
Power Supply Input Range
110 to 240 V ~, 50/60 Hz
Power Supply Output Range
48 V DC
Power Supply Power Input Connection
Power Supply Power Output Connection
Weight in kg
approx. 2 kg
Weight in lbs
approx. 4.6 lbs
Measurements (HxWxL) in mm*
91 x 115 x 388 mm
Measurements (HxWxL) in inch*
3.6 x 4.5 x 15.3"
On-Board On/Off Switch
Power Supply Mounting
Power Supply Certifications
CE, UKCA, CB, ENEC, cNRTLus, PSE
0301-orbiter-on-segt-header-m20-content-stage-1920x737-2xFm26
Fit the SkyPanel into tight locations
SkyPanel lighting fixtures are highly versatile and can be placed right up against a wall while producing high-quality light. They are ideal for situations where space is limited or precise lighting control is necessary. Choose SkyPanel S30-C for the perfect lighting setup without compromising on quality or space.
Matching accessories
If you would like to receive further information and offers, or you have a specific request regarding Classic SkyPanel, fill in the form and we will get back to you.
Get in touch
