M20_SkyPanel_s120
SkyPanel S120-C
Soft Lighting | Redefined
The sky just got bigger
  • The ARRI SkyPanel S120-C is an impressive soft light fixture, whether for horizontal or vertical use.
  • Twice the length as the S60-C with a larger light aperture for superior lighting.
  • Consumes less than 400 watts and provides a high efficacy of 90 lumens/watt.
0301-orbiter-on-set-headerr-m20-content-stage-1920x737-2xF2
Category
LED
Series
SkyPanel
Model
Lamphead Type
LED Soft Light
Optical System
Swappaple Soft Diffusion Panel
Weight in kg / lbs net*
Manual Version: approx. 16.5 kg / 36.4 lbs
Pole Operated Version: approx. 20.5 kg / 44.2 lbs
Fixture only, incl. Diffusion: approx. 12.9 kg / 28.4 lbs
Manual Version: approx. 26 kg / 57 lbs
Pole Operated Version: approx. 29 kg / 65 lbs
Center Mount Version approx.: 24 kg / 53 lbs
Manual Version: 588 x 1467 x 133 mm / 23.1 x 57.7 x 5.2"
Pole Operated Version: 615 x 1439 x 133 mm / 24.2 x 56.6 x 5.2"
Manual Version: 473 x 1467 x 133 mm / 18.6 x 57.7 x 5.2"
Pole Operated Version: 500 x 1439 x 133 mm / 19.7 x 56.6 x 5.2"
500 x 1500 x 300 mm / 19.7 x 59.1 x 11.9"
Housing Color
Blue/Silver, Black
Power Consumption
400 W Maximum
Lamphead Voltage Input
48 V DC
1290 x 300 mm
50.8 x 11.8"
Beam Angle
105° (Half Peak Angle)
Handling
Aluminium Yoke, High-Strength Tilt Lock / Steel Yoke, Pole Operation for Pan & Tilt / Center Mount Yoke
Mounting
28 mm Spigot (Junior Pin)
Tilt Angle
+/- 90°
Lamphead Power Connection
Battery Connector
Battery DC Voltage Range
23 to 36 V DC
Battery Mode Light Output
50 % of total output
Lamp Type
RGBW LED Light Engine
White Light
Colored Light
Color Temperature Tolerance
Color Rendition
CRI Average > 95, TLCI Average > 90
Green-Magenta Adjustment
Dimming
0 to 100 % continuous
Wireless Control
Not integrated, via SkyLink
Software / Mini-USB Interface
Ambient Temperature Operation
-20 to +45° C (-4 to +113° F)
Protection Class / IP Rating
III / IP 20
Estimated LED Lifetime (L70)
50,000 hours
+/- 5 %
Certifications
Power Supply Unit
S60/S120 PSU
Power Supply Input Range
100 to 240 V ~, 50/60 Hz
Power Supply Output Range
48 V DC
Power Supply Power Input Connection
Power Supply Power Output Connection
Weight in kg
approx. 4 kg
Weight in lbs
approx. 7.7 lbs
Measurements (HxWxL) in mm*
91 x 191 x 383 mm
Measurements (HxWxL) in inch*
3.6 x 7.5 x 15.1"
On-Board On/Off Switch
Power Supply Mounting
Power Supply Certifications
CE, UKCA, CB, ENEC, cNRTLus, PSE
Note *Weight and dimensions are rounded values. **Center Mount
ARRI Advertorial 4_2019_ Romantic night time indoor Behind the Scenes 2_IMG_0808
data (1) 1
202302-arri-lighting-bardo-13-IMG_5664
Matching accessories
User content for S120-C
If you would like to receive further information and offers, or you have a specific request regarding Classic SkyPanel, fill in the form and we will get back to you.
Get in touch
