Discontinued_Ultra_Primes_anwendung
Name
Ultra Prime T2.8/8R
Ultra Prime T2/12 mm
Ultra Prime T1.9/14 mm
Ultra Prime T1.9/16 mm
Type
Distagon T*
Distagon T*
Distagon T*
Distagon T*
Aperture
T2.8 to T22
T2 to T22
T1.9 to T22
T1.9 to T22
Close focus(5)
0.35m / 1 1/4'
0.3m / 1'
0.22m / 3/4'
0.25m / 1'
Length (lens mount to front)
130mm / 5.1"
140mm / 5.5"
112mm / 4.4"
94mm / 3.7"
Horizontal angle of view
ANSI Super 35(1)
l'=12.45mm(4)
114.0°
92.6°
82.6°
75.2°
DIN Super 35(2)
l'=12.45mm(4)
112.0°
90.2°
80.6°
75.6°
Normal 35 3)
l'=11.00mm(4)
107.0°
85.2°
75.6°
70.8°
Maximum Housing Diameter
Front diameter
134mm / 5.3"
156mm / 6.1"
114mm / 4.5"
95mm / 3.7"
Weight
2.0kg / 4.4lbs
2.0kg / 4.4lbs
1.8kg / 4.0lbs
1.2kg / 2.6lbs
Item number meter
K2.47613.0
K2.47378.0
K2.47311.0
K2.47312.0
Item number feet
K2.47612.0
K2.47380.0
K2.47323.0
K2.47324.0
Name
Ultra Prime T1.9/20 mm
Ultra Prime T1.9/24 mm
Ultra Prime T1.9/28 mm
Ultra Prime T1.9/32 mm
Type
Distagon T*
Distagon T*
Distagon T*
Distagon T*
Aperture
T1.9 to T22
T1.9 to T22
T1.9 to T22
T1.9 to T22
Close focus(5)
0.28m / 1'
0.3m / 1'
0.28m / 1'
0.35m / 1 1/4'
91mm / 3.6"
91mm / 3.6"
91mm / 3.6"
91mm / 3.6"
ANSI Super 35(1)
l'=12.45mm(4)
65.0°
55.8°
48.4°
43.0°
DIN Super 35(2)
l'=12.45mm(4)
62.8°
54.2°
46.8°
41.6°
Normal 35(3)
l'=11.00mm(4)
58.4°
50.2°
43.2°
38.2°
Front diameter
95mm / 3.7"
95mm / 3.7"
95mm / 3.7"
95mm / 3.7"
Weight
1.2kg / 2.6lbs
1.0kg / 2.2lbs
1.0kg / 2.2lbs
1.1kg / 2.4lbs
Item number meter
K2.47313.0
K2.47314.0
K2.47315.0
K2.47316.0
Item number feet
K2.47325.0
K2.47326.0
K2.47327.0
K2.47328.0
Name
Ultra Prime T1.9/40 mm
Ultra Prime T1.9/50 mm
Ultra Prime T1.9/65 mm
Ultra Prime T1.9/85 mm
Type
Distagon T*
Planar T*
Planar T*
Planar T*
Aperture
T1.9 to T22
T1.9 to T22
T1.9 to T22
T1.9 to T22
Close focus(5)
0.38m / 1 1/4'
0.6m / 2'
0.65m / 2 1/4'
0.9m / 3'
91mm / 3.6"
91mm / 3.6"
91mm / 3.6"
91mm / 3.6"
ANSI Super 35(1)
l'=12.45mm(4)
34.7°
27.2°
21.8°
17.1°
DIN Super 35(2)
l'=12.45mm(4)
33.2°
26.2°
21.0°
16.5°
Normal 35(3)
l'=11.00mm(4)
30.6°
24.0°
19.2°
15.2°
Front diameter
95mm / 3.7"
95mm / 3.7"
95mm / 3.7"
95mm / 3.7"
Weight
1.0kg / 2.2lbs
1.0kg / 2.2lbs
1.1kg / 2.4lbs
1.2kg / 2.6lbs
Item number meter
K2.47317.0
K2.47318.0
K2.47377.0
K2.47319.0
Item number feet
K2.47329.0
K2.47330.0
K2.47379.0
K2.47331.0
Name
Ultra Prime T1.9/100 mm
Ultra Prime T1.9/135 mm
Ultra Prime T1.9/180 mm
Type
Sonnar T*
Sonnar T*
Sonnar T*
Aperture
T1.9 to T22
T1.9 to T22
T1.9 to T22
Close focus(5)
1m / 3 1/4'
1.5m / 5'
2.6m / 8 1/2'
91mm / 3.6"
119mm / 4.7"
166mm / 6.5"
ANSI Super 35(1)
l'=12.45mm(4)
13.9°
10.5°
7.9°
DIN Super 35(2)
l'=12.45mm(4)
13.7°
10.2°
7.6°
Normal 35(3)
l'=11.00mm(4)
12.6°
9.3°
7.0°
Front diameter
95mm / 3.7"
95mm / 3.7"
114mm / 4.5"
Weight
1.2kg / 2.6lbs
1.6kg / 3.5lbs
2.6kg / 5.7lbs
Item number meter
K2.47320.0
K2.47321.0
K2.47381.0
Item number feet
K2.47332.0
K2.47333.0
K2.47382.0
(1) Horizontal angle of view for an ANSI Super 35 Silent camera aperture (aspect ratio 1:1.33, dimensions 24.9mm x 18.7mm / 0.980" x 0.7362"). Ground glasses available for ARRICAM, ARRIFLEX 235 and all 435 and 535 models.
(2) Horizontal angle of view for a DIN Super 35 Silent camera aperture (aspect ratio 1:1.33, dimensions 24mm x 18mm / 0.944" x 0.7087"). Ground glasses available for ARRIFLEX 235 and all 435 and 535 models.
(3) Horizontal angle of view for a Normal 35 Academy camera aperture (aspect ratio 1:1.37, dimensions 22mm x 16mm / 0.8661" x 0.6299"). Ground glasses available for ARRICAM, ARRIFLEX 235 and all 435 and 535 models.
(4) l' is the radius of the image circle needed for the respective format. It is the same as the distance from the image center to a corner. '
(5) Close focus is measaured from the film plane.
T* is the trademark for the special Zeiss anti-reflex lens coating that reduces veiling glare and other reflections
