Discontinued_LDS_Anwendungsbild
Name
LDS Ultra Prime 12
LDS Ultra Prime 14
LDS Ultra Prime 16
LDS Ultra Prime 20
Lens Mount(1)
PL LDS-1
PL LDS-1
PL LDS-1
PL LDS-1
Aperture
T2.0 to T22
T1.9 to T22
T1.9 to T22
T1.9 to T22
Close focus(2)
0.30 m / 11.8"
0.22 m / 8.7"
0.25 m / 9.8"
0.28 m / 11"
Length(4)
140 mm / 5.5"
112 mm / 4.4"
94 mm / 3.7"
91 mm / 3.6"
Horizontal Angle of view
Normal 35(8)
ID = 27.20 mm(7)
85.2°
75.6°
70.8°
58.4°
DIN Super 35(9)
ID = 30.00 mm(7)
90.2°
80.6°
73.0°
62.8°
ANSI Super 35(10)
ID = 31.14 mm(7)
92.6°
82.6°
75.2°
65.0°
Entrance pupil(6)
113.4 mm / 4.4”
91.3 mm / 3.5”
85.1 mm / 3.3”
73.3 mm / 2.8”
Maximum Housing Diameter
Front diameter(5)
156 mm / 6.1"
114 mm / 4.5"
104 mm / 4.1"
104 mm / 4.1"
Weight
2.2 Kg / 4.8 lb
1.8 Kg / 4.0 lb
1.5 Kg / 3.3 lb
1.5 Kg / 3.3 lb
Item number meter
K2.52198.0
K2.52111.0
K2.52112.0
K2.52113.0
Item number feet
K2.52199.0
K2.52123.0
K2.52124.0
K2.52125.0
Name
LDS Ultra Prime 24
LDS Ultra Prime 28
LDS Ultra Prime 32
LDS Ultra Prime 40
Lens Mount(1)
PL LDS-1
PL LDS-1
PL LDS-1
PL LDS-1
Aperture
T1.9 to T22
T1.9 to T22
T1.9 to T22
T1.9 to T22
Close focus(2)
0.30 m / 11.8"
0.28 m / 11"
0.35 m / 13.8"
0.38 m /15"
Length(3)
91 mm / 3.6"
91 mm / 3.6"
91 mm / 3.6"
91 mm / 3.6"
Normal 35(8)
ID = 27.20 mm(7)
50.2°
43.2°
38.2°
30.6°
DIN Super 35(9)
ID = 30.00 mm(7)
54.2°
46.8°
41.6°
33.2°
ANSI Super 35(10)
ID = 31.14 mm(7)
55.8°
48.4°
43.0°
34.7°
Entrance pupil(6)
67.4 mm / 2.6”
67.3 mm / 2.6”
61.1 mm / 2.4”
59.2 mm / 2.3”
Front diameter(5)
104 mm / 4.1"
104 mm / 4.1"
104 mm / 4.1"
104 mm / 4.1"
Weight
1.3 Kg / 2.9 lb
1.5 Kg / 3.3 lb
1.4 Kg / 2.1 lb
1.4 Kg / 2.1 lb
Item number meter
K2.52114.0
K2.52115.0
K2.52116.0
K2.52117.0
Item number feet
K2.52126.0
K2.52127.0
K2.52128.0
K2.52129.0
Name
LDS Ultra Prime 50
LDS Ultra Prime 65
LDS Ultra Prime 85
LDS Ultra Prime 100
Lens Mount(1)
PL LDS-1
PL LDS-1
PL LDS-1
PL LDS-1
Aperture
T1.9 to T22
T1.9 to T22
T1.9 to T22
T1.9 to T22
Close focus(2)
0.60 m / 23.6"
0.65 m / 25.6
0.90 m / 35.4"
1.00 m / 39.4"
Length(3)
91 mm / 3.6"
91 mm / 3.6"
91 mm / 3.6"
91 mm / 3.6"
Normal 35(8)
ID = 27.20 mm(7)
24.0°
19.2°
15.2°
12.6°
DIN Super 35(9)
ID = 30.00 mm(7)
26.2°
21.0°
16.5°
13.7°
ANSI Super 35(10)
ID = 31.14 mm(7)
27.2°
21.8°
17.1°
13.9°
Entrance pupil(6)
13.4 mm / 0.5”
19.0 mm / 0.7”
3.5 mm / 0.1”
12.4 mm / 0.4”
Front diameter(5)
104 mm / 4.1"
104 mm / 4.1"
104 mm / 4.1"
104 mm / 4.1"
Weight
1.2 Kg / 2.6 lb
1.4 Kg / 2.1 lb
1.5 Kg / 3.3 lb
1.5 Kg / 3.3 lb
Item number meter
K2.52118.0
K2.52200.0
K2.52119.0
K2.52120.0
Item number feet
K2.52130.0
K2.52201.0
K2.52131.0
K2.52132.0
Name
LDS Ultra Prime 135
LDS Ultra Prime 180
Lens Mount(1)
PL LDS-1
PL LDS-1
Aperture
T1.9 to T22
T1.9 to T22
Close focus(2)
1.50 m / 59.1"
2.60 m / 102.4"
Length(3)
119 mm / 4.7"
166 mm / 6.5"
Normal 35(8)
ID = 27.20 mm(7)
9.3°
7.0°
DIN Super 35(9)
ID = 30.00 mm(7)
10.2°
7.6°
ANSI Super 35(10)
ID = 31.14 mm(7)
10.5°
7.9°
Entrance pupil(6)
-56.9 mm / -2.2”
-19.7 mm / -0.7”
Front diameter(5)
104 mm / 4.1"
114 mm / 4.5"
Weight
2.0 Kg / 4.4 lb
2.8 Kg / 6.2 lb
Item number meter
K2.52121.0
K2.52202.0
Item number feet
K2.52133.0
K2.52203.0
Operation Temperature: -20°C to +40°C / -4°F to +104°F
Storage/Transport Temperature: -40C to +70°C / -40°F to +158°F
(1) Positive locking (PL) 54 mm stainless steel lens mount with Lens Data System (LDS) contacts
(2) Close focus is measured from the film/sensor plane
(3) Magnification ratio is the relationship of the size of an object on the film/sensor plane (first number) to the size of that object in real life (second number) at the close focus setting
(4) Lens length is measured from the lens mount to the front of the lens housing
(5) Diameter of the lens/matte box interface
(6) The distance from the entrance pupil to the film/sensor plane. Positive numbers indicated an entrance pupil in front, negative numbers indicated an ent rance pupil behind the film/sensor plane. The entrance pupil (often mistakenly called "nodal point") is the center of perspective; moving the camera/lens system around the center of the entrance pupil prevents parallax errors. While largerly irrelevant for live action, this measurement is important for special effects work.
(7) The image diameter (ID) is the diameter of the image circle needed for the respective format. These lenses are designed for the largest ID given here.
(8) Horizontal angles of view for a Normal 35 Academy camera aperture (aspect ratio 1.37:1, dimensions 22mm x 16mm / 0.8661" x 0.6299")
(9) Horizontal angles of view for a DIN Super 35 Silent camera aperture (aspect ratio 1.33:1, dimensions 24mm x 18mm / 0.944" x 0.7087")
(10) Horizontal angles of view for an ANSI Super 35 Silent camera aperture (aspect ratio 1.33:1, dimensions 24.9mm x 18.7mm / 0.980" x 0.7362")
