Alura Studio Zoom in action.
Name
ARRI/FUJINON Alura Zoom 18-80
ARRI/FUJINON Alura Zoom 45-250
Lens Mount (1)
PL PL
Focal Length Wide
18
45
Focal Length Wide
80
250
Focal Length Ratio
4.4
5.6
Aperture
T2.6 - T22
T2.6 - T22
Close Focus (2)
0.7 m / 2
1.2 m / 3
Magnification Ratio (3)
1 : 5.5
1:4
Length (4)
285 mm / 11.2
370 mm / 14.6
Entrance Pupil (6)
at 18 mm
264.0 mm / 10.4"
at 45 mm
234.4 mm / 9.6"
at 50 mm
231.6 mm / 9.1"
at 150 mm
2.0 mm / 0.1"
at 80 mm
213.9 mm / 8.4"
at 250 mm
-101.5 mm / -4.0"
Angle of View H-V-D
Normal 35 (8)
ID = 27.20 mm (7)
at 18 mm
62.8° - 48.0° - 74.1°
at 45 mm
27.5° - 20.2° - 33.6°
at 50 mm
24.8° - 18.2° - 30.4°
at 150 mm
8.4° - 6.1° - 10.4°
at 80 mm
15.6° - 11.4° - 19.3°
at 250 mm
5.0° - 3.7° - 6.2°
Angle of View H-V-D
ALEXA/D-21 HD (9)
ID = 27.26 mm (7)
at 18 mm
66.8° - 40.7° - 74.3°
at 45 mm
29.6° - 16.9° - 33.7°
at 50 mm
26.7° - 15.2° - 30.5°
at 150 mm
9.1° - 5.1° - 10.4°
at 80 mm
16.9° - 9.5° - 19.3°
at 250 mm
5.4° - 3.1° - 6.2°
Angle of View H-V-D
ALEXA 2K (10)
ID = 29.08 mm (7)
at 18 mm
70.3° - 43.2° - 77.9°
at 45 mm
31.4° - 18.0° - 35.8°
at 50 mm
28.4° - 16.2° - 32.4°
at 150 mm
9.7° - 5.4° - 11.1°
at 80 mm
18.0° - 10.2° - 20.6°
at 250 mm
5.8° - 3.3° - 6.7°
Angle of View H-V-D
DIN Super 35 (11)
ID = 30.00 mm (7)
at 18 mm
67.4° - 53.1° - 79.6°
at 45 mm
29.9° - 22.6° - 36.9°
at 50 mm
27.0° - 20.4° - 33.4°
at 150 mm
9.1° - 6.9° - 11.4°
at 80 mm
17.1° - 12.8° - 21.2°
at 250 mm
5.5° - 4.1° - 6.9°
Maximum Housing Diameter
134 mm / 5.3
153 mm / 6
Front Diameter (5)
134 mm / 5.3
134 mm / 5.3
Weight (Kg)
4.7 kg / 10.4lb
7.5 kg / 16.lb
Item number meter
K2.47930.0
K2.47332.0
Item number feet
K2.47931.0
K2.47933.0
Operation Temperature: -10°C to +50°C / +14°F to +122°F
Storage/Transport Temperature: -20C to +60°C / -4°F to +140°F
(1) Positive locking 54 mm stainless steel lens mount
(2) Close focus is measured from the film/sensor plane
(3) Magnification ratio is the relationship of the size of an object on the film/sensor plane (first number) to the size of that object in real life (second number) at the close focus and the telephoto zoom setting
(4) Length is measured from the lens mount to the front of the lens housing
(5) Diameter of the lens/matte box interface
(6) The distance from the entrance pupil to the film/sensor plane. Positive numbers indicated an entrance pupil in front, negative numbers indicated an entrance pupil behind the film/sensor plane. The entrance pupil (often mistakenly called "nodal point") is the center of perspective; moving the camera/lens system around the center of the entrance pupil prevents parallax errors. While largerly irrelevant for live action, this measurement is important for special effects work.
(7) The image diameter (ID) is the diameter of the image circle needed for the respective format.
(8) Horizontal (H), vertical (V) and diagonal (D) angles of view for a Normal 35 Academy camera aperture (aspect ratio 1.37:1, dimensions 22 mm x 16 mm / 0.866" x 0.630")
(9) Horizontal (H), vertical (V) and diagonal (D) angles of view for the ALEXA/D-21 HD camera aperture (aspect ratio 1.78:1, 2880 x 1620 sensor pixels, dimensions 23.76 mm x 13.37mm / 0.935" x 0.526")
(10) Horizontal (H), vertical (V) and diagonal (D) angles of view for the ALEXA 2K camera aperture (aspect ratio 1.78:1, 3072 x 1728 sensor pixels, dimensions 25.34 mm x 14.26 mm / 0.998" x 0.561")
(11) Horizontal (H), vertical (V) and diagonal (D) angles of view for a DIN Super 35 Silent camera aperture (aspect ratio 1.33:1, dimensions 24 mm x 18 mm / 0.944" x 0.709")
