Discontinued_Alura_Lightweight_Zooms_Anwendung
Name
ARRI/FUJINON Alura Zoom 15.5-45
ARRI/FUJINON Alura Zoom 30-80
Lens Mount(1)
PL LDS-1
PL LDS-1
Focal Length Wide
15.5
30
Focal Length Long
45
80
Focal Length Ratio
2.9
2.7
Aperture
T2.8 - T22
T2.8 - T22
Close focus(2)
0.6 m / 2'0"
0.6 m / 2'0"
Magnification ratio(3)
1 : 8.1
1 : 4.9
Length(4)
228 mm / 9.0"
228 mm / 9.0"
Angle of view H - V - D
at 15.5 mm: 70.7° - 54.6° - 82.5°
at 30 mm 43.2° - 25.1° - 48.9°
DIN Super 35(11)
at 25 mm: 50.8° - 29.9° - 57.2°
at 50 mm 26.7° - 15.2° - 30.5°
ID = 30.00 mm(7)
at 45 mm: 29.6° - 16.9° - 33.7°
at 80 mm 16.9° - 9.6° - 19.3°
at 15.5 mm: 78.5° - 49.4° - 86.3°
at 30 mm 45.8° - 26.7° - 51.7°
ALEXA/D-21 HD(9)
at 25 mm: 53.8° - 31.8° - 60.4°
at 50 mm 28.4° - 16.2° - 32.4°
ID = 27.26 mm(7)
at 45 mm: 31.4° - 18° - 35.8°
at 80 mm 18° - 10.2° - 20.6°
at 15.5 mm: 75.5° - 60.3° - 88.1°
at 30 mm 43.6° - 33.4° - 53.1°
ALEXA 2K(10)
at 25 mm: 51.3° - 39.6° - 61.9°
at 50 mm 27° - 20.4° - 33.4°
ID = 29.08 mm(7)
at 45 mm: 29.9° - 22.6° - 36.9°
at 80 mm 17.1° - 12.8° - 21.2°
at 30 mm 40.3° - 29.9° - 48.8°
Normal 35(8)
at 50 mm 24.8° - 18.2° - 30.4°
ID = 27.20 mm(7)
at 80 mm 15.7° - 11.4° - 19.3°
Entrance pupil(6)
at 15.5 mm: 237.0 mm / 9.3"
at 30 mm 219.3 mm / 8.6"
at 25 mm: 230.9 mm / 9.1"
at 50 mm 201.0 mm / 7.9"
at 45 mm: 222.6 mm / 8.8"
at 80 mm 187.4 mm / 7.4"
Maximum Housing Diameter
Front diameter(5)
114 mm / 4.5"
114 mm / 4.5"
Weight (Kg)
2.2 kg / 4.9lb
2.2 kg / 4.9lb
Item number meter
K2.47934.0
K2.47936.0
Item number feet
K2.47935.0
K2.47937.0
(1) Close focus is measured from the film plane.
(2) Horizontal angle of view for an ANSI Super 35 Silent camera aperture
(aspect ratio 1:1.33, dimensions 24.9 mm x 18.7 mm / 0.980" x 0.7362").
