K0.0001244
The most affordable accessory bundle for the AMIRA camera.
K0.0001245
Typical documentary style accessory bundle for the AMIRA camera.
K0.0001246
The most flexible accessory bundle for the AMIRA camera.
KK.0019639
The set offers essential support accessories for traditional cine rigging, such as the Compact Bridge Plate 19mm CBP-3 and low mode plate UAP-2.
KK.0019637
The Pro Cine Set for AMIRA prepares for all facets of film production, with the Compact Bridge Plate CBP-3 and its exclusive top mount, the Stabilizer Adapter Mount SAM-3 f...
K2.0018983
An LPL lens mount with an LBUS connector and reduced internal reflection properties to ensure the full contrast of the image from the lens reaches the sensor. Can be equipp...
K2.0016936
An adapter that can be used to attach PL mount lenses to a camera with an LPL mount. Equipped with reduced internal reflection properties to ensure the full contrast of the...
K2.0003216
Titanium mount for PL mount lenses. Includes LBUS connector for cforce-type lens motors. Fits both, ALEXA Mini and AMIRA, but only ALEXA Mini supports LBUS connector.
K2.0001107
PL LDS lens mount for PL mount lenses. Includes 12pin Hirose connector for ENG style lenses. Fits ALEXA Mini and AMIRA.
K2.0001237
B4 lens mount with optical, mechanical and electronic interfaces for B4 mount lenses. Fits ALEXA Mini and AMIRA.
K2.0001238
A mechanical and optical adapter that allows the use of B4 mount lenses on cameras with a PL mount. Fits ALEXA Mini and AMIRA.
K2.0001103
EF lens mount with interface for iris control. Fits ALEXA Mini and AMIRA.
K0.0019007
A set of three SanDisk Extreme PRO CFast 2.0 cards 512GB.
K2.0016648
The ARRI edition 512 GB SanDisk Extreme Pro CFast 2.0 card has been customized by SanDisk for optimum performance in ARRI cameras. The main difference from the retail versi...
K0.0019006
A set of three SanDisk Extreme PRO CFast 2.0 cards 256GB.
K2.0015640
The first SanDisk Extreme Pro CFast 2.0 cards were launched together with the ARRI AMIRA and have been a part of our certified selection ever since. SanDisk cards have an o...
K0.0019005
A set of three SanDisk Extreme PRO CFast 2.0 cards 128GB.
K2.0003623
K2.0021432
The Angelbird AV PRO AR 256 GB CFast card is available for order directly from the Angelbird website at https://www.angelbird.com/prod/av-pro-ar-256gb-2115/ or from most de...
K2.0024245
The Angelbird CFast 2.0 Card Reader is available for order directly from the Angelbird website at https://www.angelbird.com/prod/cfast-20-card-reader-2774/ or from most dea...
K2.0019580
The CBP-3 is a 19mm all-in-one baseplate well-matched to handheld work as well as tripod operation. The exclusive top-mount system allows swift transitions between configur...
K2.0019582
The CBP-4 is a 15mm all-in-one baseplate well-matched to handheld work as well as tripod operation. The exclusive top-mount system allows swift transitions between configur...
K2.0015896
The 300mm/12 inch Bottom Dovetail Plate is the standard for all prime lenses where minimal balancing is required. All ARRI Bottom Plates feature 3/8" and 1/4" Camloc® inser...
K2.75006.0
A camera base mount compatible to accessories like BP-8/BP-9 for 19/15mm rods etc.
K2.75000.0
ENG style camera base mount with new softer shoulder pad and wedge plate adapter. Compatible with Quick-Release-Plate.
K2.0000399
VCT-style broadcast plate compatible with the ARRI AMIRA camera, most of ARRI PCA support systems as well as ENG cameras.
K0.0001280
The UAP-2 set offers top-mounted accessories that optimize the AMIRA for use in a cine environment.
K2.0001221
The Universal Adapter Plate UAP-2 can be attached to the top and bottom dovetails of the AMIRA. Provides support for regular and low mode Steadicam use and features 15mm LW...
K2.0001297
An attachment that allows the AMIRA viewfinder to be mounted to two 15 mm lightweight rods above the lens, as can be found on the Universal Adapter Plate UAP-2 (K2.0001221)...
K2.72007.0
Attaches to the top of the ALEXA, ALEXA Plus, ALEXA Plus 4:3, ALEXA M body, ALEXA Studio, ALEXA XT, ALEXA XT M body, ALEXA XT Plus, ALEXA XT Studio, ALEXA SXT EV, ALEXA SX...
K2.0001016
Attaches to the Center Camera Handle (CCH-1) or any 3/8 inch-16 UNC threaded mounting point. Includes 3x 3/8 inch-16 UNC threaded mounting points.
K2.0001017
Attaches to the ALEXA Center Camera Handle (CCH-1) or any 3/8 inch-16 UNC threaded mounting point. Includes 3x 3/8 inch-16 UNC threaded mounting points.
K2.0014088
Attaches to the side of the AMIRA camera and provides 3/8" and 1/4" threads, as well as M4 threads for ARRI accessories such as the Rod Mounting Bracket RMB-3.
K2.75005.0
Bracket to attach a on-camera microphone to the camera handle. Includes 3/8 inch and 1/4' knurled fasteners.
K0.0013013 | KK.0013225
Single rod bracket for 19mm rods (15mm rods with supplied insert) mounting to AMIRA body (top/right). Optimized for camera stabilizer systems and lens motors. Compatible wi...
K2.0013007
Single rod bracket for 19mm rods (15mm rods with optional insert) mounting to AMIRA body (top/right). Optimized for camera stabilizer systems and lens motors. Compatible wi...
K2.66255.0
The 15 mm reducing insert can be fitted to any 19 mm rod mount to allow compatibility with 15 mm rods.
KK.0016114
K2.0014630
K2.0010247
The Multicam monitor mount is attached to the AMIRA handgrip and allows to use Sony PVM 740/741 OLED monitors as camera monitor in a pedestal like setup. The set comes with...
K2.0022951
Pair of adapters to use between the AMIRA Multicam Monitor Mount for PVM-741 and the TV Logic Monitor LVM-75A
K2.0001222
An adapter with an ARRI viewfinder dovetail on one side and one 3/8 inch and one 1/4 inch mounting point on the other side. This adapter can be used to mount the AMIRA or A...
K2.0004024
AMIRA Onboard Microphone set: TinyMike set is a small and light solution from Ambient including microphone, suspension, foam windshield, XLR cable and windgag. It suits pe...
K0.0010097
The Camera Control Panel CCP-1 is a small control panel that connects to the viewfinder port of ALEXA Mini or AMIRA. It can be used as a control device when no optical view...
K0.0039106
The 10 inch LCD monitor connects directly to the camera viewfinder interface or can be daisy chained with the CCP-1. It has controls for Contrast, Color, Backlight and Peak...
K2.75002.0
Attaches to the back of the AMIRA camera and accepts V-lock on-board batteries.
K2.75001.0
Attaches to the back of the AMIRA camera and accepts Gold mount on-board batteries.
K2.0038614
The B-Mount adapter allows 24V B-Mount batteries to power all AMIRA models.
K2.0008763
For V-lock batteries. The audio slot allows a direct integration for wireless audio receivers. It includes a buffer battery for up to 30 sec buffering for changing batterie...
K2.0008762
For Gold Mount AB Batteries. The audio slot allows a direct integration for wireless audio receivers. It includes a buffer battery for up to 30 sec buffering for changing b...
K2.0007750
Connects the AMIRA Viewfinder MVF-1 to the MVF socket on the camera (spare part).
K2.0007751
Connects the AMIRA Viewfinder MVF-1 to the MVF socket on the camera (spare part). For a longer distance between viewfinder and camera.
K2.0009003
Connects the AMIRA Viewfinder MVF-1 to the MVF socket on the camera (spare part). For the longest distance between viewfinder and camera.
K2.72021.0
Connects the ETHERNET socket (Lemo 10 pin) on the ALEXA Mini, ALEXA Mini LF, ALEXA Classic, ALEXA XT, ALEXA SXT and ALEXA LF to any standard RJ-45 Ethernet socket for updat...
K2.0008663
This cable has a straight connector instead of an angled one. This cable works with AMIRA or with BAP-2 mounted to the right hand side of the camera.
K2.0007642
The General Purpose IO Box GPB-1 is a break-out box that works with ALEXA Mini, ALEXA Mini LF and AMIRA. It allows users to build custom button interfaces and electronic c...
K2.0001268
For ENG type lenses for power and data connection
K2.0001269
To connect an on-board camera stereo microphone to the stereo XLR input A.
K2.0001270
To connect an on-board camera mono microphone to the stereo XLR input A (left channel)
K2.0001271
To connect an on-board camera mono microphone to the mono XLR inputs B or C.
K2.0012228
0,5m (19 inch) cable to connect AMIRA to CCP-1.
K2.0012223
0,75m (29 inch) cable to connect AMIRA to CCP-1.
K2.0012235
1,5m (59 inch) cable to connect AMIRA to CCP-1.
K2.0001239
AMIRA camera case (Peli 1510 carry on case, cabin size, foam fitted for AMIRA & MVF, ARRI AMIRA branded)
K2.0001240
ARRI AMIRA branded soft carry bag. For AMIRA camera with MVF-1, camera adapter and zoom lens.
K2.0004025
proven camRade raincover to protect AMIRA against heavy rain and more
