KK.0015124
Comprehensive set of mechanical accessories for ALEXA Mini allowing varied operating configurations such as handheld shots, lightweight gimbal stabilizers, stabilizer syste...
KK.0015123
KK.0016264
The Studio Upgrade Set adresses users of an existing set of ARRI accessories for ALEXA Mini who wish to complete their existing accessory set with the main elements from th...
KK.0015126
This set comprises the original classic mechanical accessories for ALEXA Mini, as well as a set of cables and a battery adapter plate.
KK.0015125
KK.0015128
Accessory set based on the Broadcast plate for ALEXA Mini and its counterpart, the quick release plate QRP-1. This set allows quick transition from handheld to tripod confi...
KK.0015127
K2.0018983
An LPL lens mount with an LBUS connector and reduced internal reflection properties to ensure the full contrast of the image from the lens reaches the sensor. Can be equipp...
K2.0016936
An adapter that can be used to attach PL mount lenses to a camera with an LPL mount. Equipped with reduced internal reflection properties to ensure the full contrast of the...
K2.0003216
Titanium mount for PL mount lenses. Includes LBUS connector for cforce-type lens motors. Fits both, ALEXA Mini and AMIRA, but only ALEXA Mini supports LBUS connector.
K2.0001107
PL LDS lens mount for PL mount lenses. Includes 12pin Hirose connector for ENG style lenses. Fits ALEXA Mini and AMIRA.
K2.0019965
An EF lens mount with an LBUS connector and reduced internal reflection properties to ensure the full contrast of the image from the lens reaches the sensor. This EF Mount ...
K2.0001237
B4 lens mount with optical, mechanical and electronic interfaces for B4 mount lenses. Fits ALEXA Mini and AMIRA.
K2.0001238
A mechanical and optical adapter that allows the use of B4 mount lenses on cameras with a PL mount. Fits ALEXA Mini and AMIRA.
K2.0006334
Lightweight adapter plate offering 3/8 inch and ¼” centered threads, as well as interfaces for the Mini Side Bracket MSB-1 and Rod Mounting Bracket RMB-3. Fits ALEXA Mini /...
K2.0023839
The MAP-2A is the evolution of the Mini Adapter Plate MAP-2, featuring an improved rod clamping mechanism
K2.0006348
Side brackets featuring sturdy rosettes as well as 3/8 inch and 1/4 inch industry - standard threads for the mounting of handles and accessories. Fits ALEXA Mini, and ALEXA...
K2.0014957
The Mini Side Bracket MSB-2 offers support for lens motor in configurations that require lightweight baseplates with no rod support, such as lightweight stabilizer systems ...
K0.0013590 | KK.0013622
The SAB-1 allows users to position accessories towards the rear of the ALEXA Mini/Mini LF in order to optimize balance and bulk. The RMB-3 used in combination to the SAB-...
K2.0012692
The Side Accessory Bracket fits to the Mini Adapter plates MAP-1 and MAP-2/ MAP-2A, as well as the Broadcast Plate for ALEXA Mini/Mini LF and Compact Bridge Plate CBP-1. Th...
K2.0006140
Allows the MVF-1 and MVF-2 viewfinders to attach to ALEXA Mini/ Mini LF via 15mm LWS rods and viewfinder mount. Requires the Mini Adapter Plate MAP-2A or other 15mm rod sup...
K2.0014894
The CBP-1 is a baseplate compatible with the ALEXA Mini/ Mini LF. The CBP-1 offers the advantage of a sliding studio bridge plate without the added weight. The quick-releas...
K2.0019441
The CBP-2 is a baseplate compatible with the ALEXA Mini/ Mini LF. The CBP-2 offers the advantage of a sliding studio bridge plate without the added weight. The quick-releas...
K2.0019773
This lightweight rod adapter offers 15mm LWS standards to the Compact Bridge lates CBP-1 (19mm) and CBP-2 (15mm) baseplates for ALEXA Mini/ Mini LF. Lens motors, follow foc...
K2.0033726
19 mm studio rod support for bottom plates designed to offer support to long rods and avoid flex with heavy lenses. This support bracket is designed for Compact Bridge Plat...
K2.0033724
15 mm studio rod support for bottom plates, designed to offer support to long rods and avoid flex with heavy lenses. This support bracket is designed for Compact Bridge Pla...
K2.0015896
The 300mm/12 inch Bottom Dovetail Plate is the standard for all prime lenses where minimal balancing is required. All ARRI Bottom Plates feature 3/8" and 1/4" Camloc® inser...
K2.0008509
The broadcast plate for ALEXA Mini/ ALEXA Mini LF is an adjustable baseplate for documentary-style filming. The broadcast plate features an advanced shoulder pad adjustment...
K2.73002.0
Compatible with all generations ALEXA M, ALEXA Mini, AMIRA through the use of adapter plate UAP-2 and many third party cameras equipped with ARRI PCA. For a “closed” CCH-2...
K2.0038176
The CCH-2 Support offers the possibility to convert the CCH-2 from an open to a closed camera top handle by using one of the five different Handle Extensions (HEX-1 to HEX-...
K2.0017270
The CCH-4 is a completely closed top handle and is compatible with most of the ARRI PCA top plates (not compatible with the top plate for RED, C300 MkII, Sony A7 and MAP-1 ...
K2.0013937
The Rear Accessory Bracket RAB-1 offers lightweight and flexible attachment options for power solutions. Fits ALEXA Mini / Mini LF
K2.0023406
The Clamp 2 for RAB-1 offers a strong and reliable connection to the Rear Accessory Bracket RAB-1. The Clamp 2 features a safety lock to prevent the battery plate dismounti...
K2.0006186
The RMB-3 supports a single 19 mm rod (15 mm rod via reduction insert K2.66255.0) and is well suited to accessories such as lens motors or lightweight viewfinder mounts.
K2.66255.0
The 15 mm reducing insert can be fitted to any 19 mm rod mount to allow compatibility with 15 mm rods.
K2.0006807
This shoulder pad clamps on 15 mm LWS rods forward or backwards of the baseplate and can be adjusted to suit best balance on the shoulder. The camera rig is able to rest on...
K2.0008408
This bracket is designed to optimise handheld camera operating when using a compact baseplate such as the Adapter Plate MAP-2/ MAP-2A. For use with bridge plate adapter BPA...
K2.0006352
This spacer allows standard bridge plates to be mounted to the Mini Adapter Plate MAP-2/ MAP-2A. The BPA-4 also features centered 3/8 inch and 1/4 inch threads for standard...
K2.0001222
An adapter with an ARRI viewfinder dovetail on one side and one 3/8 inch and one 1/4 inch mounting point on the other side. This adapter can be used to mount the AMIRA or A...
K2.0014981
K2.0039803
K2.0038536
KK.0038972
KK.0038971
K2.0022842
The adapter allows quick transition between tripod / shoulder and DJI Ronin 2 stabilizer for ALEXA Mini and ALEXA Mini LF with Compact Bridge Plates CBP-1 (19 mm studio) an...
KK.0019829
The Vertical format Adapter set is required to use the ALEXA Mini with the sensor orientated portrait ("vertically"). The set is compatible with most existing ARRI camera a...
K2.0019442
The Vertical Format Adapters allow the ALEXA Mini/Mini LF to be used with the sensor vertical, 9/16 format. All ARRI baseplates for ALEXA Mini/ Mini LF can be used in that ...
K2.0019443
Allows the viewfinder MVF-1 to be rotated 90° on ist optical axis, in order to frame footage shot vertically.
K2.0024114
The B-Mount 24V Power Splitting Box is a proven battery solution featuring various industry standard 12V and 24V accessory power connectors, as well as an 8-pin Lemo connec...
K2.0014532
The Power Splitting box is a proven battery solution featuring various industry standard accessory power connectors, as well as a 8-pin Lemo connector for battery input aim...
K2.0014530
K2.0024116
The Power Splitting Box provides hot-swap between two Micro V-Mount batteries. The device features various industry standard accessory power connectors, as well as an 8-pin...
K2.0024115
The Power Splitting Box provides hot-swap between two Micro Gold-Mount batteries. The device features various industry standard accessory power connectors, as well as an 8-...
K2.0024113
Battery adapter for ALEXA Mini / Mini LF. The B-Mount 24V Adapter Plate features an 8-pin Lemo connector for powerinput aimed at cables such as the ARRI KC-50 as well as tw...
K2.0014533
Solid battery adapter made of aluminum for ALEXA Mini/ Mini LF. The Adapter Plate Mk II features a 8-pin Lemo connector for battery input aimed at cables such the ARRI KC-...
K2.0006471
The battery plate allows industry standard battery mounts such as V-mount and Gold Mount to fit to 15mm LWS rods. The battery plate can be offset in order to clear rear car...
K2.0023942
The BAP-2A is a side mounted battery plate offering compatibility to the Compact Bridge Plates CBP-1 and CBP-2. The BAP-2A features mounting interfaces to common battery p...
K2.0015840
The Smart APU benefits fast-paced filming by keeping camera and accessories powered during battery changes. The advanced hot swap camera power supply is a compact unit ava...
K2.0015859
The Smart APU benefits fast-paced filming by keeping camera and accessories powered during battery changes. The advanced hot swap camera power supply is a compact unit av...
K2.0015863
2-pin Lemo to 8-vpin Lemo power cable for V-mount and Gold-mount battery plate with hot-swap buffer (K2.0015840 and K2.0015859).
K2.0019486
The RAB-1 Adapter for Smart APU connects the Smart APU hot-swap solution to the RAB-1 Clamp.
K2.0034493
Indoor power supply with ARRI camera power connector. Max. power ~280W, 24V, 11.7A. Compatible with all ARRI digital cameras. Requires camera-specific power cable, to be or...
K2.75007.0
Connects the power input of AMIRA, ALEXA Mini or ALEXA Mini LF to a battery power output with an XLR 3 pin connector.
K2.44693.0
Connects the 24 V BAT (2 pin Fischer) power input of the ARRICAM, ARRIFLEX, ALEXA, ALEXA XT, ALEXA SXT and ALEXA LF cameras to a battery power output with an XLR 3 pin conn...
K2.0009367
50cm (19 inch) cable to connect the MVF-1 viewfinder to ALEXA Mini, CCP-1 to MVF-1 or CCP-1 to AMIRA. This cable has an ALEXA Mini EVF connector on one end and an AMIRA EVF...
K2.0008135
75cm (29 inch) cable to connect the MVF-1 viewfinder to ALEXA Mini, CCP-1 to MVF-1 or CCP-1 to AMIRA. This cable has an ALEXA Mini EVF connector on one end and an AMIRA EVF...
K2.0009169
1,5m (59 inch) cable to connect the MVF-1 viewfinder to ALEXA Mini, CCP-1 to MVF-1 or CCP-1 to AMIRA. This cable has an ALEXA Mini EVF connector on one end and an AMIRA EVF...
K2.0006170
Short adapter cable that connects to the EXT connector of the ALEXA Mini and ALEXA Mini LF and provides a 3-pin RS connector.
K2.72021.0
Connects the ETHERNET socket (Lemo 10 pin) on the ALEXA Mini, ALEXA Mini LF, ALEXA Classic, ALEXA XT, ALEXA SXT and ALEXA LF to any standard RJ-45 Ethernet socket for updat...
K2.0006171
1m audio cable with ALEXA Mini 5-pin audio connector on one end and open leads at the other.
K2.0008662
This is the cable that ships with the Starlite HD5-ARRI monitor and is provided as a spare or replacement.
K2.0013145
EDB-2 is a signal distribution box especially designed for the ALEXA Mini and ALEXA Mini LF EXT Sync feature. The box connects to an ALEXA Mini or ALEXA Mini LF EXT connect...
K2.0009051
1.5m (59 inch) cable designed to be used with the ALEXA Mini and ALEXA Mini LF EXT Sync feature. Connects ALEXA Mini and ALEXA Mini LF cameras to EDB-2 (K2.0013145) or dire...
K2.0007642
The General Purpose IO Box GPB-1 is a break-out box that works with ALEXA Mini, ALEXA Mini LF and AMIRA. It allows users to build custom button interfaces and electronic c...
K2.0007736
750 mm cable to connect GPB-1 to AMIRA, ALEXA Mini or ALEXA Mini LF.
K2.0010053
The camRade wetSuit for ALEXA Mini/ Mini LF is a rain cover that protects your camera against the elements. It is made of water-resistant fabric with a soft lining and mini...
K2.0001241
ARRI branded Peli 1510 Carry On case for accessories, cabin size with flexible dividers.
K2.0001016
Attaches to the Center Camera Handle (CCH-1) or any 3/8 inch-16 UNC threaded mounting point. Includes 3x 3/8 inch-16 UNC threaded mounting points.
K2.0001017
Attaches to the ALEXA Center Camera Handle (CCH-1) or any 3/8 inch-16 UNC threaded mounting point. Includes 3x 3/8 inch-16 UNC threaded mounting points.
KK.0037820
The Handle Extensions follow the design of the Camera Center Handle CCH-4. The number of each HEX refers to the number of 3/8”-16 interfaces on the top (HEX-1 has one and H...
K2.0019791
The HEX-1 is the shortest part of ARRI´s Handle Extension family. It follows the design of the Camera Center Handle CCH-4 and offers 3/8”-16 and RMB-3 interfaces. The diffe...
K2.0019792
The HEX-2 is part of ARRI´s Handle Extension family. It follows the design of the Camera Center Handle CCH-4 and offers a number of 3/8”-16 and RMB-3 interfaces. The differ...
K2.0019797
The HEX-3 is part of ARRI´s Handle Extension family. It follows the design of the Camera Center Handle CCH-4 and offers a number of 3/8”-16 and RMB-3 interfaces. The differ...
K2.0019798
The HEX-4 is part of ARRI´s Handle Extension family. It follows the design of the Camera Center Handle CCH-4 and offers a number of 3/8”-16 and RMB-3 interfaces. The differ...
K2.0036917
The HEX-5 is the longest part of ARRI´s Handle Extension family. It follows the design of the Camera Center Handle CCH-4 and offers a number of 3/8”-16 and RMB-3 interfaces...
K2.0019810
The HEX-90 is part of ARRI´s Handle Extension family. It can be used to extend the handle system behind the camera or battery downwards to build a so-called "Hollywood Hand...
K2.0037131
The Wooden Shell is part of ARRI´s Handle Extension family. It improves the haptic and can be attached directly to the HEX-5 or HEX-4. It can also be combined with the shor...
K2.0037132
The Plastic Shell is part of ARRI´s Handle Extension Family. It improves the haptic and can be attached directly to the HEX-5 or HEX-4 but also to combined shorter HEX thro...
