K0.0019228
A large-format (36.70 x 25.54 mm sensor size) digital camera with an electronic viewfinder and three sensor modes: LF Open Gate, LF 16:9, LF 2.39:1. Also includes built-in ...
K0.71030.0
K2.0038613
The B-Mount Adapter ALEXA BMM-24-ALEX attaches to the back of the ALEXA, ALEXA Plus, ALEXA Plus 4:3, ALEXA M body, ALEXA Studio, ALEXA HD, ALEXA HD Plus, ALEXA XT, ALEXA XT...
K2.0019453
The BAB-HV battery adapter attaches to the back of the ALEXA, ALEXA Plus, ALEXA Plus 4:3, ALEXA M body, ALEXA Studio, ALEXA HD, ALEXA HD Plus, ALEXA XT, ALEXA XT M body, AL...
K2.0019456
The BAB-HG battery adapter attaches to the back of the ALEXA, ALEXA Plus, ALEXA Plus 4:3, ALEXA M body, ALEXA Studio, ALEXA HD, ALEXA HD Plus, ALEXA XT, ALEXA XT M body, AL...
K2.0019383
This "Reel Power - Camera Fitting ALEXA (RP-CFA1)" attaches to the back of the ALEXA, ALEXA Plus, ALEXA Plus 4:3, ALEXA M body, ALEXA Studio, ALEXA HD, ALEXA HD Plus, ALEXA...
K2.72002.0
Attaches to the bottom of the front foot of ALEXA, ALEXA Plus, ALEXA Plus 4:3, ALEXA M body, ALEXA XT, ALEXA XT M body, ALEXA XT Plus. ALEXA SXT EV, ALEXA SXT Plus, ALEXA S...
K2.66172.0
Renders all generations of ALEXA models and the plate for Canon C100/300/500 compatible with ARRI cine bridge plates such as BP-8 or BP-9. Not needed for ALEXA Studio.
K2.0031436
The BP-8 helps to optimize camera rig balance when combined with the range of ARRI bottom plates. It brings compatibility with studio 19 mm rod systems to an increasing num...
K2.0031435
The BP-9 helps optimize camera rig balance when combined with the range of ARRI bottom plates. It brings compatibility with studio 15 mm rod systems to an increasing number...
K2.72017.0
Attaches to the bottom of the back foot of ALEXA, ALEXA Plus, ALEXA Plus 4:3, ALEXA M body, ALEXA XT, ALEXA XT M, ALEXA XT Plus, ALEXA SXT EV, ALEXA SXT Plus, ALEXA SXT W o...
K2.72083.0
Attaches with velcro to the shoulder arch at the bottom of the ALEXA, ALEXA Plus, ALEXA Plus 4:3, ALEXA Studio, ALEXA XT, ALEXA XT M Body, ALEXA XT Plus, ALEXA XT Studio, A...
K2.72102.0
With the UAP-1 the camera can be quickly moved from a traditional ARRI cine-style bridge plate (including BP-3, 5, 8 or 9) to a Steadicam dovetail plate. It attaches to the...
K2.72023.0
A low mode plate with numerous 3/8-16 mounting points, two tape hooks and optional feet. Compatible with ALEXA, ALEXA Plus, ALEXA Plus 4:3, ALEXA Studio (EVF-1 only), ALEXA...
K2.72007.0
Attaches to the top of the ALEXA, ALEXA Plus, ALEXA Plus 4:3, ALEXA M body, ALEXA Studio, ALEXA XT, ALEXA XT M body, ALEXA XT Plus, ALEXA XT Studio, ALEXA SXT EV, ALEXA SX...
K2.0001016
Attaches to the Center Camera Handle (CCH-1) or any 3/8 inch-16 UNC threaded mounting point. Includes 3x 3/8 inch-16 UNC threaded mounting points.
K2.72015.0
Attaches to the Center Camera Handle (CCH-1) or any 3/8 inch-16 UNC threaded mounting point. When attached to the front of the Center Camera Handle (CCH-1), the tape hook i...
K2.0001017
Attaches to the ALEXA Center Camera Handle (CCH-1) or any 3/8 inch-16 UNC threaded mounting point. Includes 3x 3/8 inch-16 UNC threaded mounting points.
K2.0001222
An adapter with an ARRI viewfinder dovetail on one side and one 3/8 inch and one 1/4 inch mounting point on the other side. This adapter can be used to mount the AMIRA or A...
K2.72026.0
A raincover custom designed for ALEXA, ALEXA Plus, ALEXA Plus 4:3, ALEXA Studio, ALEXA XT, ALEXA XT Plus, ALEXA XT Studio, ALEXA SXT EV, ALEXA SXT Plus and ALEXA SXT Studio...
K2.0015098
A carrying and shipping case that holds one ALEXA LF or ALEXA SXT W body with Electronic Viewfinder EVF-1 or EVF-2, viewfinder mounting bracket, Center Camera Handle CCH-1 ...
K2.0018790
A filter set for ALEXA LF cameras with LPL lens mount. The full filter set includes the LF IFM Optical Clear, LF FSND filters 0.3, 0.6, 0.9, 1.2, 1.5, 1.8, 2.1 and 2.4, the...
K2.72144.0
A depth gauge for making sure that a lens will not touch the IFM-1/FSND filters when inserted into the camera. The same gauge can also be used to check if lenses are compat...
K4.0007656
A tool with an M3 thread on one end for removing ALEXA Studio, ALEXA XT Studio, ALEXA SXT Studio, ARRICAM Studio and ARRICAM Lite ground glasses as well as ALEXA Studio and...
