K0.0043086
This expansion set offers owners of an ALEXA 35 Lightweight Set all components required to rig their camera as an ALEXA 35 Production Set (Studio 19mm).
K0.0043085
This expansion set offers owners of an ALEXA 35 Lightweight Set all components required to rig their camera as an ALEXA 35 Production Set (Studio 15mm).
KK.0041530
This expansion set offers owners of an ALEXA 35 Production Set all components required to rig their camera as an ALEXA 35 Lightweight Set.
KK.0051696
KK.0041535
This set contains the support components in the ALEXA 35 Production Set 19 mm (K0.0041726) that attach to the base of the camera. The included CBP-5 accepts 15 mm LWS and 1...
KK.0041536
This set contains the support components in the ALEXA 35 Production Set 15 mm (K0.0041725) that attach to the base of the camera. The included CBP-6 accepts 15 mm LWS and 1...
KK.0041533
This set contains the support components in the ALEXA 35 Production Sets (K0.0041726 or K0.0041725) that attach to the top of the camera, including the Viewfinder Mounting ...
KK.0041534
This set contains the support components in the ALEXA 35 Production Sets (K0.0041726 or K0.0041725) that attach to the side of the camera's side.
KK.0041539
This set contains the support components in the ALEXA 35 Lightweight Set (K0.0041722) that attach to the camera's bottom.
KK.0041537
This set contains the support components in the ALEXA 35 Lightweight Set (K0.0041722) that attach to the camera's top, including the Viewfinder Cross Pipe for viewfinder mo...
KK.0041538
This set contains the support components in the ALEXA 35 Lightweight Set (K0.0041722) that attach to the camera's side.
KK.0043836
The Vertical Format Set allows shooting with the ALEXA 35 on its side for portrait shooting (9:16).
KK.0034527
The VMB-5 is a medium length viewfinder mounting bracket with fast and comfortable adjustment. The VMB-5 attaches to the Square Accessory Sleeve SAS-2. The SAS-2 attaches t...
K2.0048510
The VFA-4 optimizes handheld operating with on-board monitors by profiting from the adjustability of classic ARRI viewfinder mounts such as ARRI VMB-3, MVB-1 or VMB-5. The ...
K2.0023519
The Centre Camera Handle CCH-5 is a full-size production top handle for the ALEXA 35 that can be quickly attached and removed from the LMS-4 without tools. Featuring a wide...
K2.0024066
The Lightweight Camera Handle LCH-1 is a lightweight carbon-fiber top handle for carrying the ALEXA 35 and for mounting accessories. It can be quickly attached to or remove...
K2.0023948
The LWS-6 holds two 15 mm lightweight support rods. It is designed as an option to add lightweight rods to the Lightweight Camera Handle LCH-1 or to the Universal Adapter P...
K2.0050467
The LWS-7 is a robust 15mm LWS console designed to fit most Stabilizer Adapter Mounts (SAM) and ARRI CSS support plates. The LWS-7 fits M4 threaded interface distant 20mm a...
K2.0033573
The Camera Side Bracket CSB-1L allows mounting of accessories to the left side of the ALEXA 35 without obstructing the user buttons. It features an ARRI rosette for hand gr...
K2.0024062
The Top Extension Bracket TEB-1 extends the Low Mode Support LMS-4 or Universal Adapter Plate UAP-3, so more accessories, including the Rear Accessory Bracket RAB-2 and Art...
K2.0033571
The Camera Side Bracket CSB-1R allows mounting of accessories to the right side of the ALEXA 35 without obstructing the user buttons. It features an ARRI rosette for hand g...
K2.0034189
The Camera Side Bracket CSB-1R Extension is an extension to the Camera Side Bracket CSB-1R, providing additional attachment points. It features multiple 1/4-20, 3/8-16 and ...
K2.0034178
The Low Mode Support LMS-4 is a fully featured top plate for the ALEXA 35. A new quick release mechanism allows the CCH-5 top handle to be easily removed, without tools, wh...
K2.0034554
The Balance Harness Adapter BHA-1 allows the secure attachment and rapid balancing of the ALEXA 35 when using various camera suspension harnesses. The BHA-1 slips over the ...
K2.0034183
The Rear Accessory Bracket RAB-2 allows accessories to be mounted behind the ALEXA 35. This can be done for organizational reasons or to better balance the camera. It requi...
K2.0034180
The thin and lightweight Balance Utility Dovetail BUD-1 attaches to the underside of the ALEXA 35's, where its dovetail allows the camera to be securely and quickly attache...
K2.0034179
The Universal Adapter Plate UAP-3 is a small and flat staging platform for the ALEXA 35 top accessories, including the Lightweight Camera Handle LCH-1 and Center Camera Han...
K2.0024745
The BPA-6 combines a small shoulder pad with optically centered 15 mm lightweight rod clamps for small and lightweight camera builds. Interfacing directly with the wide dov...
K2.0024161
The CSP-2 is a very light, flat shoulder pad with a long Visco pad for the ALEXA 35. Its four feet allow the camera to be safely seated on a flat surface when not on the op...
K2.0042610
The Vertical Format Baseplate allows shooting with the ALEXA 35 on its side for portrait shooting (9:16) and attaches to the ALEXA 35's right side and interfaces with Compa...
K2.0043666
The Vertical Top Plate attaches to the ALEXA 35's left side and acts as a top plate to support the Lightweight Camera Handle LCH-1.
K2.0023549
The CBP-5 is a compact and lightweight baseplate that combines the functionalities of a sliding studio bridge plate with a comfortable Visco shoulder pad. The top of the CB...
K2.0051926
This upgrade sets comprises all elements to turn a CBP-5LW into a CBP-5. The set includes a bridge plate and 4x screws with thread locking compound applied to their ends.
K2.0049300
The CBP-LW bridge plates are lightweight alternatives to the classic ALEXA 35 CBP. They operate on ARRI Bottom Plates as classic bridge plates and retain rod support for li...
K2.0050524
This upgrade sets comprises all elements to turn a CBP-5 into a lighter CBP-5LW. The set includes a bridge plate and 4x screws with thread locking compound applied to their...
K2.0023836
The CBP-6 is a compact and lightweight baseplate that combines the functionalities of a sliding studio bridge plate with a comfortable Visco shoulder pad. The top of the CB...
K2.0051930
This upgrade sets comprises all elements to turn a CBP-6LW into a CBP-6. The set includes a bridge plate and 4x screws with thread locking compound applied to their ends.
K2.0049301
K2.0050523
This upgrade sets comprises all elements to turn a CBP-6 into a lighter CBP-6LW. The set includes a bridge plate and 4x screws with thread locking compound applied to their...
K2.0024572
The Stabilizer Adapter Mount SAM-5 is a low-profile sliding dove tail plate that connects the ALEXA 35 to a MōVI Pro or MōVI M15.
K2.0024508
The Stabilizer Adapter Mount SAM-6 is a low-profile sliding dove tail plate that connects the ALEXA 35 to ARRI CSS products, such as ARRI TRINITY and SRH-3/360
K2.0048425
The SAM-6 355mm is well-suited to medium-sized camera set-ups such as ALEXA 35 and a 24-75mm Signature Zoom. Lenses can be supported by the compact lens support CLS-1 and t...
K2.0039405
The Stabilizer Adapter Mount SAM-6 450 mm/18 in. is a long, low-profile sliding dove tail plate that connects the ALEXA 35 to ARRI CSS products such as SRH-3/360 and suppor...
K2.0024511
The Stabilizer Adapter Mount SAM-7 is a low-profile sliding dove tail that connects the ALEXA 35 to ARRI Artemis and GPi PRO Stabilizers.
K2.0044479
The Stabilizer Adapter Mount SAM-8 is a low-profile sliding dove tail plate that connects the ALEXA 35 to Tiffen Steadicam products, such as M1 and M2.
K2.0041949
The Stabilizer Adapter Mount SAM-9 is a low-profile sliding dove tail that connects the ALEXA 35 to DJI Ronin 2.
K2.0049873
The new ARRI SAM-10 is a featherweight but rock-solid tool for rigging ALEXA 35 and ALEXA Mini LF cameras to ultra-telephoto lenses such as the Canon CN20x50. The SAM-10 wa...
K2.0034205
The EPA-1 allows a camera mounted to a stabilizer rig to be externally powered by a block battery instead of the stabilizer batteries during breaks in shooting. As the came...
K2.0034204
A battery adapter that attaches to the back of the ALEXA 35 and accepts any 24 V power solution that can attach to the back of the ALEXA LF. The BAB-LF can also be mounted ...
K2.0024101
The Power Distribution Module PDM-1 is an optional, low-profile accessory that attaches to the back of the ALEXA 35 and adds seven power outputs (4x 24 V, 2x 12 V, 1x 12 V ...
K2.0023751
A low-profile battery adapter that attaches to the back of the ALEXA 35 and accepts any B-Mount battery. The B-Mount Battery Adapter can also be attached to the Power Distr...
K2.0034182
The Articulated Mounting Plate AMP-1 is a hinged plate that allows accessories to be mounted in locations that would have previously prevented access to various camera port...
K2.0033859
The Viewfinder Mounting Bracket VMB-5 offers a longer reach than traditional viewfinder brackets and is the most flexible and comfortable method to attach a viewfinder to a...
K2.0047906
The SAS-2 is a modernization of the original SAS-1 that can be attached pointing rearward at the front of the handle CCH-5, optimizing space with short lenses set-ups.
K2.0024181
The Adjustable Top Plate for MōVI connects any top accessory plate with two 3/8-16 or two 1/4-20 attachment points quickly to a MōVI Pro or M15 rig.
K2.0023907
The Rod Mounting Bracket RMB-7 provides support for a single 19 mm support rod (or 15 mm with reduction insert K2.66255.0). Often used with lens motors, the RMB-7 is optimi...
K2.0049530
The Rod Mounting Bracket RMB-9 allows lens motors to be mounted on short 19mm rods without the need for long rods support on the camera. Fits all SAM plates for ALEXA 35 an...
K2.0023750
The Audio Extension Module AEM-1 adds a high-quality audio interface and extra accessory power outputs to the ALEXA 35. Featuring two ultra-low noise microphone preamplifie...
K2.0040234
The Case for ALEXA 35 support the camera in various rigging configurations and has cut-outs that fits specific support accessories, recording media and media readers. The c...
K2.0043674
The UAP-4 is an accessory plate that can be used as a universal stabilizer plate for ALEXA 35 and ALEXA Live with BUD-1, as well as ALEXA Mini/Mini LF with BUD-3. The UAP-4...
K2.0051099
The LLA-1 Control Module mounts to the ARRI Large Lens Adapter LLA-1 and connects to large box lenses, enabling all axis control from ARRI camera via Hirose 12-pin connecto...
KK.0050890
This set includes the lightweight Compact Bridge Plate CBP-5LW and a 300mm Bottom Dovetail Plate. The CBP-5LW fits to ALEXA 35 and ALEXA 35 Live with BUD-1 base and ALEXA M...
KK.0050891
This set includes the lightweight Compact Bridge Plate CBP-6LW and a 300mm Bottom Dovetail Plate. The CBP-5LW fits to ALEXA 35 and ALEXA 35 Live with BUD-1 base and ALEXA M...
Choose the right set
Raising the bar
Contact our technical service
