K2.0036623
The BGA-2 adapter comes with an ARRI Rosette and offers the possibility to securely attach common bicycle grips with a standard inner diameter of 22 mm/ 0.87" and a length ...
K2.45886.0
K2.0016317
Lightweight and durable ergonomic handgrip without electronic components. It perfectly complements the K2.0009493 Master Grip Right Rocker MRR-1. With its ARRI rosette it c...
K2.0016318
Lightweight and durable ergonomic handgrip without electronic components. It perfectly complements the K2.0009363 Master Grip Left Wheel MLW-1. With its ARRI rosette it can...
K2.0024965
The Wooden Handgrip is known from ARRI´s SXU-1. Compatible with Sony Venice Ext. Unit Side Bracket (left and right) and Side Bracket for Sony a7sII.
KK.0005674
This handgrip configuration can be used with any camera, fitting to 15 mm lightweight support rods.
KK.0005676
Lightweight and durable handgrip set based on ARRI rosettes. Can be attached to 15mm LWS rods.Triggers run functionality on cameras fitted with 3-pin RS run signals, such a...
KK.0005675
This handgrip configuration can be used with any camera, fitting to 15 or 19 mm studio rods or 15 mm lightweight support rods.
KK.0005677
Can be attached to 15mm LWS rods as well as 15mm and 19mm studio rod systems. Triggers run functionality on cameras fitted with 3-pin RS run signals, such as ALEXA, AMIRA a...
K2.0001021
Extremely durable and ergonomically formed articulating handgrip for right camera side that attaches to the rosette of any ARRI camera. Includes REC button and short built-...
K2.47861.0
only for mechanical use - without RS cable
K2.47862.0
with RS 3-Pin connector; cables with other connectors available
K2.66278.0
The handgrip with integrated cable for triggering the Sony F5/F55 and Panasonic VariCam 35/HS, using the 4-pin Hirose connector could be used on ARRI standard rosette inter...
KK.0005710
Lightweight and durable ergonomic handgrip based on ARRI rosettes. Can be attached to rod bridge supports such as UBS-2 and LBS-2 or directly to the camera native rosette m...
KK.0005821
Heavy duty handgrip set. The handles offset is adjustable. Can be attached via short extensions and rosette offset brackets directly to the camera native rosette mounts. Tr...
K0.0012991 | KK.0013223
Stainless steel handgrip extension compatible with rosette-based systems, such as Master Grips.
K0.0012992 | KK.0013224
K0.0012993 | KK.0013220
K2.0012913
K2.0012911
K2.0012917
K2.47863.0
To extend handgrip parallel to camera body. (measurement from end to end: 195 mm)
K2.47648.0
An extension that attaches between the camera body and the handgrip to move the handgrip further away (forward) from the camera body. (measurement from end to end: 100 mm)
K2.0012921
Facilitates cable management around Master Grips and lens motors. Clips on 15mm camera rods and Master Grips extensions.
K2.0012920
Adjustable clamp arm that links Master Grips and the ZMU-4 with a Rosette Adapter RA-7 to fluid head pan handles up to 32mm tube diameter.
K2.0012918
Pivotable clamp arm to attach Master Grips and the ZMU-4 with a Rosette Adapter RA-7 to fluid head pan handles with 18mm tube diameter.
K2.0012919
Pivotable clamp arm to attach Master Grips and the ZMU-4 with a Rosette Adapter RA-7 to fluid head pan handles with 20mm tube diameter.
K2.47136.0
A short aluminum rod that attaches between camera body and handgrip to move the handgrip further away (left or right) from the camera body.
K2.0013615
Offsets ARRI rosettes. The Extension Spacer can be locked on the camera rig without a tool.
K2.66275.0
ARRI inchs Lightweight Bridge support LBS-2 comes with hard-mounted rosettes, offering support for handheld set.
K2.0002355
The LBS-3 offers a single rosette connection for one handgrip. In comparison to the still existing LBS-2 it is more than 50% lighter (100g).
K2.0013320
ARRI’s Universal Bridge Support UBS-3 offers compatibility with 19 mm studio, 15 mm studio and 15 mm lightweight rods and comes with hard-mounted rosettes with a total weig...
K2.47093.0
The handgrip set S-4 can be attached directly to the bottom of most classic ARRI cameras, the ALEXA via the bridge plate adapter BPA-1/2 and also the AMIRA via its baseplat...
K2.66209.0
Easily clamps to 15mm LWS rods. Ships with both straight and curved foam pads.
K2.0006807
This shoulder pad clamps on 15 mm LWS rods forward or backwards of the baseplate and can be adjusted to suit best balance on the shoulder. The camera rig is able to rest on...
