Attaches natively to: O'Connor 2060; O'Connor 2575; O'Connor 120EX; Sachtler Cine 30.
K2.0020427
The shortest of our Bottom Dovetail Plates fits very well on camera carts, car mounts, Steadicam or with any applications when balancing is not necessary, but the interface...
K2.0015896
The 300mm/12 inch Bottom Dovetail Plate is the standard for all prime lenses where minimal balancing is required. All ARRI Bottom Plates feature 3/8" and 1/4" Camloc® inser...
K2.0015950
The 450mm/18 inch Bottom Dovetail Plate fits perfectly with smaller and medium zoom lenses where a bit more balancing is required. All ARRI Bottom Plates feature 3/8" and 1...
K2.0015952
The 600mm/24 inch Bottom Dovetail Plate is the perfect solution when working with large and heavy zoom lenses where maximum balancing is required. An additional rod support...
KK.0005684
All ARRI Bottom Plates feature 3/8" and 1/4" Camloc® inserts.
KK.0005685
K2.0000437
An additional 15mm rod support when using long rods with heavy zoom lenses to prevent rods from flexing.
K2.0000440
An additional 19mm rod support when using long rods with heavy zoom lenses to prevent rods from flexing.
