K0.0044361
The Pendulum TPD-2 is one of the most important components of the TRINITY system, with its inconspicuous mode of operation. You could also call it the drop-down generator o...
K2.0048654
The side-to-side fine adjustment upgrade for TRINITY Gen. 1 can only be performed in conjunction with the DUB-3 (K2.0040347). Note: If the TRINITY was manufactured before J...
K2.0039977
The new ARTEMIS 2 bottom stage combines a very compact design with extremely high overall rigidity and a future-proof modular design. The conversion to the SAM dovetail pla...
K2.0010433
Steel C-stand with detachable Turtle Base . Max. height 155 cm/61" NOTE To park the MAXIMA the Spider (K2.0010425) is needed For all ARTEMIS and TRINITY systems
K2.0041474
ARTEMIS carbon fiber telescopic center post, 1.8in, no-tool clamp, torsion-free guided 1.5in inner post, fine-trim adjustment. Length from 37 cm/14.56in to 46.5 cm/18.3in ...
K2.0041976
Modular center post extension to extent the 1.8" ARTEMIS center post by 21.6 cm/8.5". Diameter: 1.8" Length: 21.6 cm/8.5" Lemo 3B 16-pin For ARTEMIS 2 and TRINITY 2
KK.0041404
The new Super Post, 1.8" Gen.2 is a replacement center post for the standard center post which comes with the system. The new Super Post enables the camera in the ARTEMIS a...
K2.0010569
Extends the length of the bent gimbal handle by 35 mm/1.37" NOTE Do not combine two extensions. For ARTEMIS 1.8" gimbals
K2.0014280
The Knurled Handle Gimbal Extension adds a second knurled handle to the upper side of the 1.8" ARTEMIS gimbal, giving more control and better handling when the rig is used ...
K2.0039300
The Battery Mounting System generation 2 contains two key components: The Battery Mounting Base BMS-2 for ARTEMIS and TRINITY generation 2, or BMS-1 for TRINITY generation ...
K2.0040285
New modular and extremely flexible battery mounting system. The interchangeable battery holders can be changed quickly and easily. The electrical contact to the battery bod...
K2.0040286
K2.0038704
Mechanical adapter to mount the RF-2400 Radio Module 2400 MHz at the TRINITY 2 head. For TRINITY 2
