K2.0049835
Only the 15mm tubes can be used to connect the Top Attachment Bracket TAB-1 K2.0041117 to the camera at the front. However, if there are no 15mm tubes or if the center of g...
K2.0041117
The TAB-1 helps stabilizing the camera rigs in some configurations with ARRI CSS. The TAB-1 links top-mounted 15mm LWS camera rods to the top of CSS products such as SRH-3 ...
K2.0020638
Designed by Mike Johnson in the US, the Top Point Kit adds stability to all stabilizer rigs requiring good resistance to vibrations and flex. The kit is not limited to ARRI...
K2.0015385
The Multi Support Plate MSP-1 for the TRINITY 2 and Gen.1 allows the use of the TRINITY head as a standalone, handheld, two-axis, fully stabilized gimbal. The MSP-1 include...
K2.0010427
With the CSS Mitchell mount, the MAXIMA equipped with the Spider (K2.0010425) can be attached to dollies and cranes, using the Euro mount. With the CSS Mitchell mount, the ...
