K2.0048481
This external power cord allows the TRINITY 2 head to be powered when used as a standalone stabilizer mounted on the MSP-1 (K2.0015385) through the Battery Hanger Module (B...
K2.0051086
12G HD SDI BNC Cable Length: 1,3m/51,2in For ARTEMIS 2, TRINITY 2
K2.0039443
24 V high-capacity camera power cable. Lemo 2B 7-pin to Lemo 2B 8-pin, 0.7 m/2.3' ALEXA 35, Mini, Mini LF, AMIRA For ARTEMIS 2 and TRINITY 2
K2.0039446
24 V high-capacity camera power cable. Lemo 2B 7-pin to Fischer 2-pin, 0.7 m/2.3' For ARTEMIS 2 and TRINITY 2
K2.0039447
12 V high-capacity camera power cable. Lemo 2B 7-pin to Lemo 2B 8-pin, 0.7 m/2.3' For ARTEMIS 2 and TRINITY 2
K2.0040329
12 V high-capacity camera power cable. Lemo 2B 7-pin to XLR 4-pin, 90° elbow, 0.7 m/2.3' For ARTEMIS 2 and TRINITY 2
K2.0039448
12 V high-capacity camera power cable. Lemo 2B 7-pin to XLR 4-pin, 0.7 m/2.3' For ARTEMIS 2 and TRINITY 2
K2.0039449
12 V high-capacity camera power cable. Lemo 2B 7-pin to Lemo 1B 6-pin, 0.7 m/2.3' For ARTEMIS 2 and TRINITY 2
K2.0039450
24 V high-capacity camera power cable. Lemo 2B 7-pin to Lemo 2B 4-pin, 0.7 m/2.3' For ARTEMIS 2 and TRINITY 2
K2.0039451
24 V high-capacity camera power cable. Lemo 2B 7-pin to XLR 4-pin, 0.7 m/2.3' For ARTEMIS 2 and TRINITY 2
K2.0010470
12 V XLR high-capacity camera power cable, Lemo 1B 4-pin to XLR 4-pin, for video cameras, ARRIFLEX 16SR I, ARRI 16SR II, Aaton and other devices using a 4-pin XLR socket. L...
K2.0037771
High-capacity 12 V/24 V power cable to connect the Battery Hanger Module with the Top Stage or Bottom Stage Gen.2. Lemo 2B 7-pin to Lemo 2B 7-pin, 12 V/24 V For ARTEMIS 2...
K2.0038998
Power cable to power a Transvideo Starlite, or SmallHD 503 monitor from the Master Grip TRINITY 2. Lemo 0B 4-pin to Lemo 0B 2-pin, 24 V For MGT-1, MGT-2, TRINITY 2
K2.0038999
Power cable to power a ARRI Starlite monitor from the Master Grip TRINITY 2. Lemo 0B 4-pin to Lemo 0B 5-pin, 24 V For MGT-1, MGT-2, TRINITY 2
K2.0043861
Flexible joystick cable to connect Master Grip TRINITY with the TRINITY 2 head. Lemo 0B 4-pin to Lemo 0B 4-pin, 24 V, 75 cm/29.5" For TRINITY 2 only!
K2.0043975
Flexible joystick cable to connect the Master Grip TRINITY to the TRINITY 2 head when the rig is fully extended or when using a Super Post. Lemo 0B 4-pin to Lemo 0B 4-pin, ...
K2.0043884
Analog joystick cable to connect the analog TRINITY Gen.1 Joystick with TRINITY 2. Lemo 1B 8-pin to Lemo 0B 7-pin, no video, 12 V TRINITY 2 only!
K2.0042631
Flexible standard main cable to connect the outer ring of the TRINITY 2 to the inner ring. High-capacity 12 V/24 V, data, 1 x 12G video, LBUS, CAN Bus, tally Length: 0.65 m...
K2.0042681
Extra long flexible main cable to connect the outer ring of the TRINITY 2 to the inner ring. High-capacity 12 V/24 V, data, 1 x 12G video, LBUS, CAN Bus, tally Length: 0.75...
K2.0040332
Main cable for ARTEMIS 2 and TRINITY 2. High-capacity 12 V/24 V, data, 2 x 12G video, LBUS, CAN Bus, tally Lemo 3B 16-pin to Lemo 3B 16-pin For ARTEMIS 2 and TRINITY 2 ...
K2.0041161
Super Post main cable for ARTEMIS 2 and TRINITY 2. High-capacity 12 V/24 V, 2 x 12G video, LBUS, CAN Bus, tally Lemo 3B 16-pin to Lemo 3B 16-pin For ARTEMIS 2 and TRINITY...
K2.0043883
Power and data cable to connect the RCP-3 remote control to the TRINITY 2 system. Fischer 4-pin to Fischer 4-pin, 12 V Length: 25 cm/10" For TRINITY 2, RCP-3
K2.0001637
Cable RS 24V Fischer-type 3pin (male) to PWR IN/RS Fischer-type 3pin (female). Provides power and RUN/STOP function. Can be used to power a WVT-1, WVR-1 or UMC-4 from a cam...
K2.0006749
LBUS cable (Le 4p, Le 4p). Length: 0.2m/8 inch.
K2.0006750
LBUS cable (Le 4p, Le 4p). Length: 0.3m/1ft.
K2.0006751
LBUS cable (Le 4p, Le 4p). Length: 0.5m/1.5ft.
K2.0006752
LBUS cable (Le 4p, Le 4p). Length: 0.8m/2.6ft.
K2.0006753
LBUS cable (Le 4p, Le 4p). Length: 1.5m/5ft.
K2.0006754
LBUS cable (Le 4p, Le 4p). Length: 3m/10ft.
