K2.0041117
The TAB-1 helps stabilizing the camera rigs in some configurations with ARRI CSS. The TAB-1 links top-mounted 15mm LWS camera rods to the top of CSS products such as SRH-3 ...
K2.0049835
Only the 15mm tubes can be used to connect the Top Attachment Bracket TAB-1 K2.0041117 to the camera at the front. However, if there are no 15mm tubes or if the center of g...
K2.0050825
The MMA-3 allows to mount a 5in monitor via the K2.0048510 VFA-4, Viewfinder Adapter to K2.0042837 1x CSS Clamp Bridge 52, 19mm, or K2.0049885 CCB-2, CSS Clamp Bridge-2, 52...
K2.0050573
The MMA-4 allows to mount a 5in monitor for low moder operation via the VFA-4, Viewfinder Adapter K2.0048510 to existing SSB-3, Stabilizer System Bracket K2.0037912. It is ...
K2.0049419
K2.0049885
The new CCB-2 is an inexpensive alternative to the CSS Clamp Bridge 52 K2.0042837, which is used on all ARTEMIS 2 and TRINITY 2 battery mountings. The CCB-2 can be used, fo...
K2.0049880
The SSB-9 performs two functions. 1. The well-known CSS counterweights, like the Counterweight, CW-1, 150 g K2.0033569, can be fastened to the SSB-9. The SSB-9 can th...
K2.0049637
The TRINITY Skater helps reduce the time required for balancing the TRINITY. It consists of a sturdy base support to which two wheels are attached. Both wheels are equipped...
KK.0051462
For a firm and vibration-free mounting of the camera and for an optimized balancing process, we strongly recommend this accessory set.
KK.0049586
KK.0049354
Flexible cheese plate system for mounting the ERM External Radio Module, or a wireless video transmitter / receiver to the 19mm Rods or to the post of the TRINITY 2 / ARTEM...
K2.0048648
Cylindrical adapter into which an articulated arm with a 1/4 inch thread can be screwed. The adapter can be used in any bracket with clamps for 19mm rods. The adapter has a...
K2.0048645
Cylindrical adapter into which an articulated arm with a 1/4 inch thread can be screwed. The adapter can be used in any bracket with clamps for 15mm rods. The adapter has a...
K2.0044225
The compact and lightweight Stabilizer System Bracket SSB-4 can be mounted at the top of the ring of the TRINITY 2 on both sides. The SSB-4 allows the following brackets to...
K2.0006186
The RMB-3 supports a single 19 mm rod (15 mm rod via reduction insert K2.66255.0) and is well suited to accessories such as lens motors or lightweight viewfinder mounts.
K2.65264.0
Can be mounted to several ARRI support accessories and offer optional front and rear or top mounted 15mm LWS rods.
K2.65020.0
Articulated accessory holder arm for attaching accessories with 3/8-16 UNC mounting points to cameras with 3/8-16 mounting points. 120 mm / 4.7 inch long, with two swivel b...
K2.41100.0
Articulated accessory holder arm for attaching accessories with 3/8-16 inch mounting points to cameras with 3/8-16 inch mounting points. 240mm / 9.4 inch long, with two swi...
K2.0020163
The Rod Mounting Bracket RMB-6 expands camera set-ups opportunities by offering strong support to rod-mounted camera accessories such as lens motors, image transmitters or ...
KK.0033710
The set consists of two different counterweights. The larger counterweight weighs 300 g/0.66 lb, the two smaller counterweights weigh 150 g/0.33 lb each. The larger counter...
K2.0033569
Additional compact counterweight. Weight: 150 g/0.33 lb For TRINITY 2, TRINITY Gen.1, SRH-3, SRH-360, MAXIMA
K2.0033574
Additional compact counterweight. Weight: 300 g/0.66 lb For TRINITY 2, TRINITY Gen.1, SRH-3, SRH-360, MAXIMA
K2.0043875
Additional compact counterweight. Weight: 50 g/0.110 lb For TRINITY 2, TRINITY Gen.1, SRH-3, SRH-360, MAXIMA
K2.0043876
Additional compact counterweight. Weight: 25 g/0.055 lb For TRINITY 2, TRINITY Gen.1, SRH-3, SRH-360, MAXIMA
K2.0042826
The 3/8" extension allows additional counterweights to be mounted on the TRINITY Pendulum Gen.2. Attaching counterweights to the side of the top and bottom stages TST-1, TS...
KK.0053621
This steel extenders with an outer diameter of 19mm allows a wide range of applications with the existing counterweights CW-2, CW-3, CW-4 in combination with rod mounting b...
K2.0031236
The set includes the counterweight consisting of two half shells and two Delrin adapters for the 1.8" and 1.5" center posts. The Delrin adapters make it possible to mount t...
K2.0042837
Clamping bridge that can be clamped onto the rods of the battery hanger of TRINITY 2 as well as TRINITY Gen.1 and artemis Gen.1. For ARTEMIS 2, artemis Gen.1, TRINITY 2, ...
K2.0033852
The Accessory Rail Cube ARC-1 can be used on the SMB and LMB Accessory Adapter as well as on the Accessory Rails ARC-1, ARC-2 and ARC-3. It can be locked off by turning the...
K2.0043811
19 mm carbon rod Length: 76 mm/3", Diameter: 19 mm For MGT-2 to place the monitor mount
K2.0040790
1 pair of 19 mm carbon rods Length: 120 mm/4.7", Diameter: 19 mm For TRINITY 2, ARTEMIS 2
K2.0041327
1 pair of 19 mm carbon rods Length: 305 mm/12", Diameter: 19 mm For TRINITY 2, ARTEMIS 2
K2.0040791
1 pair of 19 mm carbon rods Length: 430 mm/16.9", Diameter: 19 mm For TRINITY 2, ARTEMIS 2
K2.0016088
One pair Ø 19 mm, stainless steel, lightweight
K2.0016090
K2.66270.0
K2.66269.0
K2.0001022
One pair Ø 19 mm, stainless steel.
K2.72028.0
