KK.0044428
This set enables an artemis Gen.1 to be upgraded to ARTEMIS 2. NOTE To complete the initial order, at least one of the mandatory battery mounting, joystick, and monitor/...
K0.0044355
New and extremely flexible battery mounting system for ARTEMIS 2 and TRINITY 2. NOTE To complete the initial order, at least one of the mandatory battery mounting sets mus...
K0.0044356
K0.0044357
K2.0039443
24 V high-capacity camera power cable. Lemo 2B 7-pin to Lemo 2B 8-pin, 0.7 m/2.3' ALEXA 35, Mini, Mini LF, AMIRA For ARTEMIS 2 and TRINITY 2
K2.0039446
24 V high-capacity camera power cable. Lemo 2B 7-pin to Fischer 2-pin, 0.7 m/2.3' For ARTEMIS 2 and TRINITY 2
K2.0039447
12 V high-capacity camera power cable. Lemo 2B 7-pin to Lemo 2B 8-pin, 0.7 m/2.3' For ARTEMIS 2 and TRINITY 2
K2.0040329
12 V high-capacity camera power cable. Lemo 2B 7-pin to XLR 4-pin, 90° elbow, 0.7 m/2.3' For ARTEMIS 2 and TRINITY 2
K2.0039448
12 V high-capacity camera power cable. Lemo 2B 7-pin to XLR 4-pin, 0.7 m/2.3' For ARTEMIS 2 and TRINITY 2
K2.0039449
12 V high-capacity camera power cable. Lemo 2B 7-pin to Lemo 1B 6-pin, 0.7 m/2.3' For ARTEMIS 2 and TRINITY 2
K2.0039450
24 V high-capacity camera power cable. Lemo 2B 7-pin to Lemo 2B 4-pin, 0.7 m/2.3' For ARTEMIS 2 and TRINITY 2
K2.0039451
24 V high-capacity camera power cable. Lemo 2B 7-pin to XLR 4-pin, 0.7 m/2.3' For ARTEMIS 2 and TRINITY 2
K2.0044813
The DUB-2 is a connecting piece for cameras rigged for stabilizers such as Artemis 1 as well as Tiffen or GPi Pro stabilizers. The DUB-2 allows cameras to be swiftly mounte...
K2.0039861
The Dovetail Utility Base DUB-1 is a stable baseplate that allows cameras rigged for ARRI Camera Stabilizer Systems to be mounted on supports such as fluid heads and film c...
K2.0041201
The Stabilizer Adapter Mount SAM-Zero is the standard camera plate for most ARRI Camera Stabilizer systems products. The 254mm (10”) plate will allow most camera featuring...
K2.0018851
K2.0014215
KK.0016116
K2.0014630
K2.0033662
KK.0016114
K2.0039803
K2.0038536
KK.0038971
KK.0038972
K2.0014981
K2.0039089
K2.0038537
K2.0038618
K2.0040036
This baseplate fits to ALEXA Mini/Mini LF and is the common interface to the Compact Bridge Plate CBP-1/CBP-2 and Stabilizer Adapter Mount SAM-2. The BUD- 2 is available se...
K2.0044225
The compact and lightweight Stabilizer System Bracket SSB-4 can be mounted at the top of the ring of the TRINITY 2 on both sides. The SSB-4 allows the following brackets to...
KK.0033710
The set consists of two different counterweights. The larger counterweight weighs 300 g/0.66 lb, the two smaller counterweights weigh 150 g/0.33 lb each. The larger counter...
K2.0033569
Additional compact counterweight. Weight: 150 g/0.33 lb For TRINITY 2, TRINITY Gen.1, SRH-3, SRH-360, MAXIMA
K2.0043875
Additional compact counterweight. Weight: 50 g/0.110 lb For TRINITY 2, TRINITY Gen.1, SRH-3, SRH-360, MAXIMA
K2.0043876
Additional compact counterweight. Weight: 25 g/0.055 lb For TRINITY 2, TRINITY Gen.1, SRH-3, SRH-360, MAXIMA
K2.0042826
The 3/8" extension allows additional counterweights to be mounted on the TRINITY Pendulum Gen.2. Attaching counterweights to the side of the top and bottom stages TST-1, TS...
K2.0031236
The set includes the counterweight consisting of two half shells and two Delrin adapters for the 1.8" and 1.5" center posts. The Delrin adapters make it possible to mount t...
K2.0042837
Clamping bridge that can be clamped onto the rods of the battery hanger of TRINITY 2 as well as TRINITY Gen.1 and artemis Gen.1. For ARTEMIS 2, artemis Gen.1, TRINITY 2, ...
K2.0043811
19 mm carbon rod Length: 76 mm/3", Diameter: 19 mm For MGT-2 to place the monitor mount
K2.0040790
1 pair of 19 mm carbon rods Length: 120 mm/4.7", Diameter: 19 mm For TRINITY 2, ARTEMIS 2
K2.0041327
1 pair of 19 mm carbon rods Length: 305 mm/12", Diameter: 19 mm For TRINITY 2, ARTEMIS 2
K2.0040791
1 pair of 19 mm carbon rods Length: 430 mm/16.9", Diameter: 19 mm For TRINITY 2, ARTEMIS 2
K2.0016088
One pair Ø 19 mm, stainless steel, lightweight
K2.0016090
K2.66270.0
K2.66269.0
K2.0001022
One pair Ø 19 mm, stainless steel.
K2.72028.0
K2.0010433
Steel C-stand with detachable Turtle Base . Max. height 155 cm/61" NOTE To park the MAXIMA the Spider (K2.0010425) is needed For all ARTEMIS and TRINITY systems
K2.0041474
ARTEMIS carbon fiber telescopic center post, 1.8in, no-tool clamp, torsion-free guided 1.5in inner post, fine-trim adjustment. Length from 37 cm/14.56in to 46.5 cm/18.3in ...
K2.0041976
Modular center post extension to extent the 1.8" ARTEMIS center post by 21.6 cm/8.5". Diameter: 1.8" Length: 21.6 cm/8.5" Lemo 3B 16-pin For ARTEMIS 2 and TRINITY 2
K2.0014264
Modular center post extension to extent the 1.8" ARTEMIS center post by 21.6 cm/8.5". Diameter: 1.8" Length: 21.6 cm/8.5" Lemo 3B 10-pin For artemis Gen.1 and TRINITY G...
KK.0041404
The new Super Post, 1.8" Gen.2 is a replacement center post for the standard center post which comes with the system. The new Super Post enables the camera in the ARTEMIS a...
K2.0010569
Extends the length of the bent gimbal handle by 35 mm/1.37" NOTE Do not combine two extensions. For ARTEMIS 1.8" gimbals
K2.0014280
The Knurled Handle Gimbal Extension adds a second knurled handle to the upper side of the 1.8" ARTEMIS gimbal, giving more control and better handling when the rig is used ...
K2.0037707
The Battery Mounting System Gen.2, contains two key components: The Battery Mounting Base BMS-1 for TRINITY Gen.1. and the two additional battery mounts, which are availabl...
K2.0040285
New modular and extremely flexible battery mounting system. The interchangeable battery holders can be changed quickly and easily. The electrical contact to the battery bod...
K2.0040286
K2.0010470
12 V XLR high-capacity camera power cable, Lemo 1B 4-pin to XLR 4-pin, for video cameras, ARRIFLEX 16SR I, ARRI 16SR II, Aaton and other devices using a 4-pin XLR socket. L...
K2.0037771
High-capacity 12 V/24 V power cable to connect the Battery Hanger Module with the Top Stage or Bottom Stage Gen.2. Lemo 2B 7-pin to Lemo 2B 7-pin, 12 V/24 V For ARTEMIS 2...
K2.0038998
Power cable to power a Transvideo Starlite, or SmallHD 503 monitor from the Master Grip TRINITY 2. Lemo 0B 4-pin to Lemo 0B 2-pin, 24 V For MGT-1, MGT-2, TRINITY 2
K2.0038999
Power cable to power a ARRI Starlite monitor from the Master Grip TRINITY 2. Lemo 0B 4-pin to Lemo 0B 5-pin, 24 V For MGT-1, MGT-2, TRINITY 2
K2.0043861
Flexible joystick cable to connect Master Grip TRINITY with the TRINITY 2 head. Lemo 0B 4-pin to Lemo 0B 4-pin, 24 V, 75 cm/29.5" For TRINITY 2 only!
K2.0043975
Flexible joystick cable to connect the Master Grip TRINITY to the TRINITY 2 head when the rig is fully extended or when using a Super Post. Lemo 0B 4-pin to Lemo 0B 4-pin, ...
K2.0043884
Analog joystick cable to connect the analog TRINITY Gen.1 Joystick with TRINITY 2. Lemo 1B 8-pin to Lemo 0B 7-pin, no video, 12 V TRINITY 2 only!
K2.0042631
Flexible standard main cable to connect the outer ring of the TRINITY 2 to the inner ring. High-capacity 12 V/24 V, data, 1 x 12G video, LBUS, CAN Bus, tally Length: 0.65 m...
K2.0042681
Extra long flexible main cable to connect the outer ring of the TRINITY 2 to the inner ring. High-capacity 12 V/24 V, data, 1 x 12G video, LBUS, CAN Bus, tally Length: 0.75...
K2.0040332
Main cable for ARTEMIS 2 and TRINITY 2. High-capacity 12 V/24 V, data, 2 x 12G video, LBUS, CAN Bus, tally Lemo 3B 16-pin to Lemo 3B 16-pin For ARTEMIS 2 and TRINITY 2 ...
K2.0041161
Super Post main cable for ARTEMIS 2 and TRINITY 2. High-capacity 12 V/24 V, 2 x 12G video, LBUS, CAN Bus, tally Lemo 3B 16-pin to Lemo 3B 16-pin For ARTEMIS 2 and TRINITY...
K2.0043883
Power and data cable to connect the RCP-3 remote control to the TRINITY 2 system. Fischer 4-pin to Fischer 4-pin, 12 V Length: 25 cm/10" For TRINITY 2, RCP-3
K2.0001637
Cable RS 24V Fischer-type 3pin (male) to PWR IN/RS Fischer-type 3pin (female). Provides power and RUN/STOP function. Can be used to power a WVT-1, WVR-1 or UMC-4 from a cam...
KK.0020657
Equipped with two Gold-Mount battery mounts. Note: The KK set will come with a foam inserts which will fit into the SKB 3i-2317-14BE case. The SKB Case K2.0016275 is not ...
K2.0010466
Rain and dust protection for the lower sled and battery hanger assembly. For all ARTEMIS and TRINITY systems
K2.0041117
The TAB-1 helps stabilizing the camera rigs in some configurations with ARRI CSS. The TAB-1 links top-mounted 15mm LWS camera rods to the top of CSS products such as SRH-3 ...
K2.0020638
Designed by Mike Johnson in the US, the Top Point Kit adds stability to all stabilizer rigs requiring good resistance to vibrations and flex. The kit is not limited to ARRI...
K2.0015385
The Multi Support Plate MSP-1 for the TRINITY 2 and Gen.1 allows the use of the TRINITY head as a standalone, handheld, two-axis, fully stabilized gimbal. The MSP-1 include...
K2.0010427
With the CSS Mitchell mount, the MAXIMA equipped with the Spider (K2.0010425) can be attached to dollies and cranes, using the Euro mount. With the CSS Mitchell mount, the ...
K2.0010333
Highly adjustable and modular vest. Only the most comfortable and modern fabrics are used for the ARTEMIS vest. Fits any operator with a height from 1.5 m up to 2.1 m/4.9' ...
KK.0020296
The ARTEMIS carbon spring arms offer a lightweight and optimized, state-of-the-art design. The absolutely friction-free ball bearings placed in the extremely stiff and tors...
KK.0020297
KK.0020298
KK.0039452
K2.0010500
Complete spring set made up of two spring sets, one for each arm segment. Capacity: 19 kg/41.8 lb For all ARTEMIS spring arms
K2.0010501
Complete spring set made up of two spring sets, one for each arm segment. Capacity: 23 kg/50.7 lb For all ARTEMIS spring arms
K2.0010502
Complete spring set made up of two spring sets, one for each arm segment. Capacity: 26 kg/57.3 lb For all ARTEMIS spring arms
K2.0037438
Complete spring set made up of two spring sets, one for each arm segment. Capacity: 30 kg/66 Ib For all ARTEMIS spring arms
Motion beyond limits
Pure stability
