K2.0049419
KK.0049354
Flexible cheese plate system for mounting the ERM External Radio Module, or a wireless video transmitter / receiver to the 19mm Rods or to the post of the TRINITY 2 / ARTEM...
K2.0048648
Cylindrical adapter into which an articulated arm with a 1/4 inch thread can be screwed. The adapter can be used in any bracket with clamps for 19mm rods. The adapter has a...
K2.0048645
Cylindrical adapter into which an articulated arm with a 1/4 inch thread can be screwed. The adapter can be used in any bracket with clamps for 15mm rods. The adapter has a...
K2.0031236
The set includes the counterweight consisting of two half shells and two Delrin adapters for the 1.8" and 1.5" center posts. The Delrin adapters make it possible to mount t...
K2.0037912
The SSB-3 bracket can be used to mount the Volt control box to the top stage of the artemis. Alternatively it can be used as a focus bracket which can be mounted at the art...
K2.0010446
Receiver mount for ARRI, cmotion, Aladin, Fox and Preston focus receivers. For all artemis systems. NOTE Additional adapters are needed for ARRI and Cmotion (K2.0010447) a...
K2.0010447
Adapter to mount ARRI or cmotion focus receivers to the ARTEMIS Focus Bracket. For the use with the ARTEMIS Focus Bracket (K2.0010446)
K2.0010448
Focus bracket adapter to mount Preston MDR2 or MDR3 focus receivers onto the ARTEMIS Focus Bracket NOTE The ARTEMIS Focus Bracket (K2.0010446) is needed to use the Univers...
K2.0010451
Incl. arm posts 5/8"/15.8 mm. Arm post length: 10"/254 mm and 3"/76 mm Fits all spring arms and gimbals which are compatible to 5/8"/15.8 mm arm posts
K2.0010452
Incl. arm posts 5/8"/15.8 mm. Arm post length: 12"/300 mm and 3"/76 mm Fits all spring arms and gimbals which are compatible to 5/8"/15.8 mm arm posts
K2.0010454
Arm post with a diameter of 5/8"/15.8 mm and a length of 3"/76 mm Fits all spring arms and gimbals which are compatible to 5/8"/15.8 mm arm posts
K2.0010453
Arm post with a diameter of 5/8"/15.8 mm and a length of 6"/152.4 mm Fits all spring arms and gimbals which are compatible to 5/8"/15.8 mm arm posts
K2.0010455
Arm post with a diameter of 5/8"/15.8 mm and a length of 10"/254 mm Fits all spring arms and gimbals which are compatible to 5/8"/15.8 mm arm posts
K2.0010456
Arm post with a diameter of 5/8"/15.8 mm and a length of 12"/300 mm Fits all spring arms and gimbals which are compatible to 5/8"/15.8 mm arm posts
K2.0010510
Spare arm post clamp ring Fits any 5/8"/15.8 mm arm post
K2.0042837
Clamping bridge that can be clamped onto the rods of the battery hanger of TRINITY 2 as well as TRINITY Gen.1 and artemis Gen.1. For ARTEMIS 2, artemis Gen.1, TRINITY 2, ...
K2.0043811
19 mm carbon rod Length: 76 mm/3", Diameter: 19 mm For MGT-2 to place the monitor mount
K2.0040790
1 pair of 19 mm carbon rods Length: 120 mm/4.7", Diameter: 19 mm For TRINITY 2, ARTEMIS 2
K2.0041327
1 pair of 19 mm carbon rods Length: 305 mm/12", Diameter: 19 mm For TRINITY 2, ARTEMIS 2
K2.0040791
1 pair of 19 mm carbon rods Length: 430 mm/16.9", Diameter: 19 mm For TRINITY 2, ARTEMIS 2
K2.0016088
One pair Ø 19 mm, stainless steel, lightweight
K2.0016090
K2.66270.0
K2.66269.0
K2.0001022
One pair Ø 19 mm, stainless steel.
K2.72028.0
