KK.0039359
KK.0041936
KK.0038971
KK.0038972
K2.0018851
KK.0016116
K2.0014215
K2.0014630
K2.0033662
K2.0038536
K2.0039803
K2.0014981
K2.0040036
This baseplate fits to ALEXA Mini/Mini LF and is the common interface to the Compact Bridge Plate CBP-1/CBP-2 and Stabilizer Adapter Mount SAM-2. The BUD- 2 is available se...
K2.0039089
K2.0019295
Reinforced dovetail plate using the SAM dovetail width. Length: 200 mm/7.87" Weight: 190 g/6.70 oz For TRINITY 2, ARTEMIS 2, TRINITY Gen.1, SRH-3, SRH-360, MAXIMA
K2.0019294
Reinforced dovetail plate using the SAM dovetail width. Length: 315 mm/12.4" Weight: 250 g/6.7 oz For TRINITY 2, ARTEMIS 2, TRINITY Gen.1, SRH-3, SRH-360, MAXIMA
K2.0033425
Reinforced dovetail plate using the SAM dovetail width. Length: 450 mm/17.7" Weight: 457 g/16 oz For TRINITY 2, ARTEMIS 2, TRINITY Gen.1, SRH-3, SRH-360, MAXIMA
KK.0033710
The set consists of two different counterweights. The larger counterweight weighs 300 g/0.66 lb, the two smaller counterweights weigh 150 g/0.33 lb each. The larger counter...
K2.0019727
Small bracket which allows users to add additional brackets and mounts at the top center of the inner ring of the Stabilized Remote Head SRH-3 and SRH-360. For SRH-3 and S...
K2.0033426
Additional rod support bracket for the top of the SRH, which allows users to mount 15 mm rods. The rod support bracket can also be mounted to the front of the basic CSS dov...
K2.0019293
Adapter plate to mount the SRH remote control panel on a tripod quick release plate. For SRH-3 and SRH-360
K2.0019296
Cheese plate-like accessory mounting bracket which allows users to add additional accessories, like transmitters, to the right side of the SRH. For SRH-3 and SRH-360
K2.0019289
Small side feet, which can be attached laterally to the rosettes of the SRH remote control panel. For SRH-3 and SRH-360
K2.0010446
Receiver mount for ARRI, cmotion, Aladin, Fox and Preston focus receivers. For all artemis systems. NOTE Additional adapters are needed for ARRI and Cmotion (K2.0010447) a...
K2.0010447
Adapter to mount ARRI or cmotion focus receivers to the ARTEMIS Focus Bracket. For the use with the ARTEMIS Focus Bracket (K2.0010446)
K2.0010448
Focus bracket adapter to mount Preston MDR2 or MDR3 focus receivers onto the ARTEMIS Focus Bracket NOTE The ARTEMIS Focus Bracket (K2.0010446) is needed to use the Univers...
K2.0024658
The SRH Modular Low Mount Rack enables the Stabilized Remote Head SRH-3 and SRH-360 to be positioned very low. The modular design also allows the use of the heads on the ho...
K2.0019298
Special Mitchell mount to mount the Stabilized Remote Head SRH-3 and SRH-360 into heads and dampers with restricted height clearance. The round base plate offers two mounti...
K2.0024106
To speed up the assembly of the stabilized remote head to the BLACK ARM by Flowcine, a second SRH castle nut should be permanently placed in the mount of the BLACK ARM. To ...
K2.0041922
K2.0024108
Spare SRH Mitchell mount collar for the Stabilized Remote Head SRH-3 and SRH-360. Length: 40 mm/1.57in NOTE Metric thread For SRH-3 and SRH-360
K2.0019291
The digital focus wheel is an additional high-resolution digital controller for the SRH remote control panel. In general, it is used to control focus via LBUS with cforce m...
K2.0019292
The digital zoom rocker is an additional high-resolution digital controller for the SRH remote control panel. In general, it is used to control zoom via LBUS with cforce mi...
K2.0019297
Longer SRH Mitchell mount collar for the Stabilized Remote Head SRH-3 and SRH-360. Very useful for special cranes. Length: 45 mm/1.77" NOTE Metric thread For SRH-3 and S...
K2.0033763
Spare rubber duck antenna For ERM-2400 (K2.0033763) and RF-2400 Radio Module 2400 MHz FHSS (KK.0039984)
K2.0033765
Spare rubber duck antenna For ERM-900 (K2.0033758) only!
K2.0037205
Specially cranked short right-angled Allen key For SRH-3 and SRH-360
K2.0037208
Spare tool for the SRH Mitchell mount castle nut (K2.0024106). Only for SRH-3 and SRH-360.
K2.0037206
