K2.0038536
K2.0038537
K2.0038618
K2.0018851
K2.0014215
K2.0014630
K2.0033662
KK.0016116
KK.0016114
K2.0019295
Reinforced dovetail plate using the SAM dovetail width. Length: 200 mm/7.87" Weight: 190 g/6.70 oz For TRINITY 2, ARTEMIS 2, TRINITY Gen.1, SRH-3, SRH-360, MAXIMA
K2.0019294
Reinforced dovetail plate using the SAM dovetail width. Length: 315 mm/12.4" Weight: 250 g/6.7 oz For TRINITY 2, ARTEMIS 2, TRINITY Gen.1, SRH-3, SRH-360, MAXIMA
K2.0033425
Reinforced dovetail plate using the SAM dovetail width. Length: 450 mm/17.7" Weight: 457 g/16 oz For TRINITY 2, ARTEMIS 2, TRINITY Gen.1, SRH-3, SRH-360, MAXIMA
K2.0034512
Quick lock plate for broadcast cameras with V-mount locking mechanism using the SAM dovetail width. For TRINITY 2, ARTEMIS 2, TRINITY Gen.1, SRH-3, SRH-360, MAXIMA
KK.0039359
KK.0033710
The set consists of two different counterweights. The larger counterweight weighs 300 g/0.66 lb, the two smaller counterweights weigh 150 g/0.33 lb each. The larger counter...
K2.0035956
This compact and lightweight Stabilizer System Bracket can be mounted at the top of the ring of the TRINITY or the MAXIMA. The SSB-1 can be also mounted at the front and b...
K2.0037912
The SSB-3 bracket can be used to mount the Volt control box to the top stage of the artemis. Alternatively it can be used as a focus bracket which can be mounted at the art...
K2.0019727
Small bracket which allows users to add additional brackets and mounts at the top center of the inner ring of the Stabilized Remote Head SRH-3 and SRH-360. For SRH-3 and S...
K2.0033426
Additional rod support bracket for the top of the SRH, which allows users to mount 15 mm rods. The rod support bracket can also be mounted to the front of the basic CSS dov...
K2.0019296
Cheese plate-like accessory mounting bracket which allows users to add additional accessories, like transmitters, to the right side of the SRH. For SRH-3 and SRH-360
K2.0019293
Adapter plate to mount the SRH remote control panel on a tripod quick release plate. For SRH-3 and SRH-360
K2.0019289
Small side feet, which can be attached laterally to the rosettes of the SRH remote control panel. For SRH-3 and SRH-360
K2.0024658
The SRH Modular Low Mount Rack enables the Stabilized Remote Head SRH-3 and SRH-360 to be positioned very low. The modular design also allows the use of the heads on the ho...
K2.0019297
Longer SRH Mitchell mount collar for the Stabilized Remote Head SRH-3 and SRH-360. Very useful for special cranes. Length: 45 mm/1.77" NOTE Metric thread For SRH-3 and S...
Contact our technical service
