KK.0021211
Additional third wheel set for the DRW-1 Digital Remote Wheels, Two Wheels Set KK.0021212
KK.0039359
K2.0010427
With the CSS Mitchell mount, the MAXIMA equipped with the Spider (K2.0010425) can be attached to dollies and cranes, using the Euro mount. With the CSS Mitchell mount, the ...
KK.0040049
The external radio module offers reliable wireless communication over 2.4 GHz between the remote control and the Stabilized Remote Head SRH-3 and SRH-360. The range of up t...
KK.0040050
The external radio module offers reliable wireless communication over 900 MHz between the remote control and the Stabilized Remote Head SRH-3 and SRH-360. The range of up t...
KK.0040048
An ERM-2400 LCS set of radio modules basically extends an LCS/LBUS/EXT (CAN bus) cable connection over air. As such, it can connect ARRI and cmotion hand units to cameras a...
K0.0019595
Set of digital high-resolution controllers for adjusting focus via a focus wheel and zoom via a zoom rocker, based on the LBUS protocol. This allows users to control focus ...
K2.0039882
The Microforce Joystick is a high-resolution 2-axis controller for the SRH remote control. The Microforce Joystick offers a highly precise and tactile, optimized control of...
K2.0039881
The Broadcast Joystick is a high-resolution 3-axis controller for the SRH remote control. The Broadcast Joystick offers a highly precise and tactile, optimized control of t...
K2.0039880
Standard fully digital high-resolution 2-axis joystick for the SRH remote control. The Standard Joystick offers a highly precise and tactile, optimized control of the pan a...
K0.0012269
12 V and 24 V high-capacity camera power cables for SRH-3 and SRH-360 . For SRH-3 and SRH-360
K2.0021430
12 V high-capacity extension cable to connect a block battery with the SRH High-Capacity Battery Power Cable, 12 V/24 V, 0.5 m/1.64' (K2.0019306) 12 V high-capacity 4-pin ...
K2.0021429
24 V high-capacity extension cable to connect a block battery with the SRH High-Capacity Battery Power Cable, 12 V/24 V, 0.5 m/1.64' (K2.0019306) 24 V high-capacity 3-pin X...
Contact our technical service
