K2.0033761
Spare ERM Power Cable for ERM-2400 & ERM-900 Length: 30 cm/11.8in
K2.0036900
Adapter cable to connect the ERM LCS to the WCU-4, SXU-1 UMC-4 and ALEXA Plus camera via the LCS socket. Recommended and required optional extension cables: SRH FS CAN Bus ...
K2.0036903
Adapter cable to connect the ERM LCS to Master Grips, OCU-1, DRW-1 and DEH-1 via the LBUS socket. Recommended and required optional extension cables: SRH FS CAN Bus Cable,...
K2.0036901
Adapter cable to connect the ERM LCS to ALEXA Mini, ALEXA Mini LF and AMIRA via the EXT. socket. Recommended and required optional extension cables: SRH FS CAN Bus Cable, ...
K2.0036902
Power cable D-Tap to 2-pin Lemo 0B. Length: 1 m/3.2ft For ERM SRH, ERM LCS
K2.0052050
The IP box allows TCP-IP communication between the stabilisation systems: SRH-360, 360 EVO, TRINITY 2, TRINITY 2 with Pan Axis Module, as well as the remote control RCP-2, ...
KK.0040049
The external radio module offers reliable wireless communication over 2.4 GHz between the remote control and the Stabilized Remote Head SRH-3 and SRH-360. The range of up t...
KK.0040050
The external radio module offers reliable wireless communication over 900 MHz between the remote control and the Stabilized Remote Head SRH-3 and SRH-360. The range of up t...
KK.0040048
An ERM-2400 LCS set of radio modules basically extends an LCS/LBUS/EXT (CAN bus) cable connection over air. As such, it can connect ARRI and cmotion hand units to cameras a...
K2.0037428
Single 2.4 GHz ERM module for SRH. NOTE Only for ERM-2400 for SRH
K2.0037425
Single 900 MHz ERM module. NOTE Only for ERM-900 for SRH
K2.0037440
Single 2.4 GHz ERM module for LCS. NOTE Only for ERM-2400 LCS
K2.0033763
Spare rubber duck antenna For ERM-2400 (K2.0033763) and RF-2400 Radio Module 2400 MHz FHSS (KK.0039984)
K2.0033765
Spare rubber duck antenna For ERM-900 (K2.0033758) only!
