K2.0044813
The DUB-2 is a connecting piece for cameras rigged for stabilizers such as Artemis 1 as well as Tiffen or GPi Pro stabilizers. The DUB-2 allows cameras to be swiftly mounte...
K2.0039861
The Dovetail Utility Base DUB-1 is a stable baseplate that allows cameras rigged for ARRI Camera Stabilizer Systems to be mounted on supports such as fluid heads and film c...
K2.0041201
The Stabilizer Adapter Mount SAM-Zero is the standard camera plate for most ARRI Camera Stabilizer systems products. The 254mm (10”) plate will allow most camera featuring...
K2.0018851
K2.0014215
KK.0016116
K2.0014630
K2.0033662
KK.0016114
K2.0039803
K2.0038536
K2.0033425
Reinforced dovetail plate using the SAM dovetail width. Length: 450 mm/17.7" Weight: 457 g/16 oz For TRINITY 2, ARTEMIS 2, TRINITY Gen.1, SRH-3, SRH-360, MAXIMA
KK.0038971
KK.0038972
K2.0014981
K2.0039089
K2.0038537
K2.0038618
K2.0040036
This baseplate fits to ALEXA Mini/Mini LF and is the common interface to the Compact Bridge Plate CBP-1/CBP-2 and Stabilizer Adapter Mount SAM-2. The BUD- 2 is available se...
