K2.0041201
The Stabilizer Adapter Mount SAM-Zero is the standard camera plate for most ARRI Camera Stabilizer systems products. The 254mm (10”) plate will allow most camera featuring...
K2.0018851
K2.0014215
KK.0016116
K2.0014630
KK.0016114
K2.0033662
K2.0024508
The Stabilizer Adapter Mount SAM-6 is a low-profile sliding dove tail plate that connects the ALEXA 35 to ARRI CSS products, such as ARRI TRINITY and SRH-3/360
K2.0048425
The SAM-6 355mm is well-suited to medium-sized camera set-ups such as ALEXA 35 and a 24-75mm Signature Zoom. Lenses can be supported by the compact lens support CLS-1 and t...
K2.0039405
The Stabilizer Adapter Mount SAM-6 450 mm/18 in. is a long, low-profile sliding dove tail plate that connects the ALEXA 35 to ARRI CSS products such as SRH-3/360 and suppor...
K2.0039803
K2.0038536
KK.0038971
KK.0038972
K2.0014981
K2.0039089
K2.0038537
K2.0038618
K2.0039861
The Dovetail Utility Base DUB-1 is a stable baseplate that allows cameras rigged for ARRI Camera Stabilizer Systems to be mounted on supports such as fluid heads and film c...
