ALEXA_35_SUP1.3.0_header_uhd
ALEXA 35 SUP 1.3.0
July 1, 2024
This latest software update for the ALEXA 35 contains a new, often requested recording format (ProRes 3.8K 16:9) and improvements to the AEM-1 (output monitoring) as well as enhancements to WiFi performance and to frame-by-frame metadata. As always, this SUP includes numerous bug fixes and stability improvements.
Updating
ALEXA 35 SUP 1.3.0 can be installed on all previously shipped ALEXA 35 cameras, and we recommend updating from any previous ALEXA 35 SUP to SUP 1.3.0. However, we do not recommend updating to a new SUP in the middle of a production. Please read through the release notes, which contain detailed update instructions, before you update your camera.
Please note that CCM-1 SUP 5.5.1 is not compatible with ALEXA 35 SUP 1.3.0. Either update the CCM-1 first or perform the updates independently.
Downdating
It is possible to downdate from this SUP to an older SUP. However, MVF-2 viewfinders with serial numbers above 6849 and Compact Drive 2TB units with serial numbers starting with ‘273xxxxx’ require ALEXA 35 SUP 1.0.4 or newer. Since ALEXA 35 SUP 1.x requires a different sensor calibration from any of the field test SUPs (0.8.x), please do not downdate the camera from SUP 1.x to any of the field test SUPs.
Registration 
If you have not done so already, please make sure you register your camera using our online customer registration. Your registration ensures that you receive information about future software updates as soon as they are available. If you register your new camera within one month of purchase, you will get a one-year extended warranty for free. You can find the registration here.
End User License Agreement
    1. Definitions. "Software" means (a) all of the contents of the files provided under this Agreement, including but not limited to (i) Software as provided together with this licence agreement for download at the ARRI website, or provided to you whether on disk, in read only memory or any other media or in any other form (ii) any related files to the Software and (iii) related explanatory written materials or files or oral information ("Documentation"); and (b) upgrades, modified versions, updates, bug fixes, additions, and copies of the Software, if any, licensed to you by ARRI, unless they are accompanied by a separate licence or licence agreement (collectively, "Updates"). "Use" or "Using" means to access, install, download, copy, use or otherwise benefit from using the functionality of the Software in accordance with the Documentation. "Free Functionality" means any free functionality which the Software provides automatically without the need for a License Key; "Paid for Functionality" means any functionality of the Software other than Free Functionality, which must be paid for or otherwise requires a License Key; "Licence Key" means a license key which activates and enables use of the Software or any Paid-For Functionality within the Software, for a defined period of time. The scope of the rights and permissions granted by any License Key and its duration will be as specified by ARRI at the time you order and purchase the same from ARRI or are otherwise supplied with the same; "Permitted Number" means one (1) unless otherwise indicated under a valid license (e.g. volume license) granted by ARRI. "Device" means a camera system, accessories and/or any other product manufactured by ARRI, identified by a specific ARRI serial number and internal product code, that is intended, prepared or dedicated for use with the Software and specified in the Software or the order form. "ARRI" means Arnold & Richter Cine Technik GmbH & Co Betriebs KG, Herbert-Bayer-Str. 10, 80807 München.
    2. Software License.
    4. Restrictions.
    5. NO WARRANTY. The Software is being delivered to you "AS IS" and ARRI makes no warranty as to its use, capabilities or performance. ARRI AND ITS SUPPLIERS DO NOT AND CANNOT WARRANT THE PERFORMANCE OR RESULTS YOU MAY OBTAIN BY USING THE SOFTWARE. EXCEPT FOR ANY WARRANTY, CONDITION, REPRESENTATION OR TERM TO THE EXTENT TO WHICH THE SAME CANNOT OR MAY NOT BE EXCLUDED OR LIMITED BY LAW APPLICABLE TO YOU IN YOUR JURISDICTION, ARRI AND ITS SUPPLIERS MAKE NO WARRANTIES CONDITIONS, REPRESENTATIONS, OR TERMS (EXPRESS OR IMPLIED WHETHER BY STATUTE, COMMON LAW, CUSTOM, USAGE OR OTHERWISE) AS TO ANY MATTER INCLUDING WITHOUT LIMITATION NONINFRINGEMENT OF THIRD PARTY RIGHTS, MERCHANTABILITY, INTEGRATION, SATISFACTORY QUALITY, OR FITNESS FOR ANY PARTICULAR PURPOSE. IF APPLICABLE LAW REQUIRES ANY WARRANTIES WITH RESPECT TO THE FREE FUNCTIONALITY OF THE SOFTWARE, ALL SUCH WARRANTIES ARE LIMITED IN DURATION TO NINETY (90) DAYS FROM THE DATE OF DELIVERY. IF APPLICABLE LAW REQUIRES ANY WARRANTIES WITH RESPECT TO THE PAID FOR FUNCTIONALITY OF THE SOFTWARE, ALL SUCH WARRANTIES ARE LIMITED IN DURATION TO ONE YEAR FROM THE DATE OF DELIVERY. NO ORAL OR WRITTEN INFORMATION OR ADVICE GIVEN BY ARRI OR ITS EMPLOYEES SHALL CREATE A WARRANTY OR IN ANY WAY INCREASE THE SCOPE OF ANY WARRANTY PROVIDED HEREIN. You must inspect the Software immediately upon its receipt and must notify ARRI in writing of any apparent defects within one week. ARRI must be notified of hidden defects in writing within two weeks of their emergence. In the event that the customer has notified ARRI of defects in a timely manner and is thus eligible to make a claim for re-performance, ARRI shall have the right, at its own cost, either to remedy the defect or to redeliver. Any warranty explicit given by ARRI or constructed under any law theory does not apply if the Software (i) has been altered, except by ARRI, (ii) has been subject to abnormal physical or electrical stress, misuse, negligence or accident or (iii) is used in hazardous activities. The provisions of Section 5 and Section 6 shall survive the termination of this Agreement, howsoever caused, but this shall not imply or create any continued right to Use the Software after termination of this Agreement.
SUP Download Archive
