Omnibar FAQ
Omnibar FAQs
Everything you need to know about Omnibar
Got questions? We’ve got answers!
Welcome to our FAQ section, where you’ll find everything you need to know about the Omnibar. From setup and mounting options to power solutions and connectivity, we’ve compiled the most commonly asked questions to help you get the most out of your lighting setup.
Browse through the categories below or search for specific topics to find quick and clear answers. If you need further assistance, feel free to reach out to our support team!
  • Yes. Omnibar includes integrated fixing points for cable or zip ties, enabling secure mounting without obstructing the light‑emitting surface.
  • Yes. Third-party accessories for Omnibar are already available. For example, DoPchoice and Chimera offer dedicated solutions such as Snapbags and other accessories designed to fit the Omnibars very well.
  • Yes. Omnibar supports seamless bar-to-bar connection via Omnigrip, allowing multiple fixtures to be joined while maintaining a visually continuous source. This is ideal for pixel effects and pixel mapping.
  • Yes. Omnibar supports power/data in and through from Omnibase, enabling multi-bar daisy-chaining and reducing cable runs compared with individual fixture feeds. NOTE: Universal Power Supply / Charger only supports one Omnibar at a time and should not be used when daisy chaining.
  • Yes. Omnibar 2 and Omnibar 4 are both available as individual sets, in addition to the larger kits.
  • Yes. All Omnibar optics – Flat Diffusion, Round Diffusion, and Intensifier – are also available separately.
  • Omnibar has an integrated battery, with battery capacities of 49 Wh for Omnibar 2 and 98 Wh for Omnibar 4. Air-travel regulations may vary depending on the airline, country, and whether the product is transported in carry-on or checked baggage, so users should always check the applicable rules with their carrier before travelling.
  • Yes. Omnibar can be used with the optics removed, depending on the application, and it is designed to work with suitable third-party modifiers where appropriate. Omnibar remains IP65 when used open face.
  • Yes. Omnibar is designed as a serviceable fixture, with key components such as the battery intended to be replaceable by rental houses and authorized service partners, helping reduce downtime.
  • Yes. Omnibar includes integrated magnets for fast, flexible mounting on metal surfaces.
  • Yes. Eyebolts are available as a safety accessory and can also be used as a hanging or mounting option.
  • Omnibar is designed for real-world outdoor use and harsh environments. Specific operating configurations should always follow the product guidelines, but IP65 weather protection is a core part of the system design.
  • Yes. Omnibar supports Bluetooth Mesh networking, which is how the Omnibar Control app communicates with fixtures. Bluetooth Mesh allows control signals to be relayed between Omnibars, helping extend range and improve connection stability across larger setups.
  • Yes. Omnibar includes LumenRadio TimoTwo CRMX as part of its professional control ecosystem.
  • Yes. Omnibar supports three interchangeable optics designed for fast switching via a magnetic attachment system: Round Diffusion, Flat Diffusion, and Intensifier.
  • Omnibar supports multiple control workflows, including onboard control, app-based control, wired DMX, and wireless CRMX.
  • The optics are designed to be removed and reattached in seconds using a magnetic attachment concept.
  • Omnibar is designed for smooth dimming to very low output levels. Depending on the operating mode and setup, dimming down to 0.1% is supported, enabling subtle lighting adjustments and low-level effects.
  • Omnibase supports up to six DMX universes, one per output port.
  • Depending on the configuration, Omnibase supports up to 6 × Omnibar 4 or 12 × Omnibar 2, or any combination of Omnibars with a total length of up to 24 ft. Ports 1 & 2 support up to 3 × Omnibar 4 or 6 × Omnibar 2 per port (up to 12 ft), while ports 3–6 support up to 1 × Omnibar 4 + 1 × Omnibar 2 per port (up to 6 ft total).
  • Omnibar is designed for high-resolution pixel effects and pixel mapping:
    • Omnibar 2: 16 pixel zones
    • Omnibar 4: 32 pixel zones
  • No. Omnibar is designed for a wide range of users and applications, from high-end film and broadcast productions to content creators, small teams, live/event applications, and owner-operators looking for fast setup and professional light quality.
  • Yes. Omnibar is IP65-rated, designed to perform reliably in wet and dusty environments.
  • No. The Creator Set is currently available in blue/silver only.
  • Yes. Omnibar is supported by the dedicated Omnibar Control app. The app is available in the Apple App Store and the Google Play Store. Please refer to the Omnibar app page for further details and download information.
  • Omnigrip and Omnipin are key mounting accessories for fast, professional rigging. Together, they enable quick attachment to stands, clamps, grip heads, and other compatible rigging solutions.
  • Omnibar uses a five-color RGBMA light engine: Red, Green, Blue, Mint, and Amber.
  • The Omnibar 2 Set includes:
    • 1 × Omnibar 2
    • 1 × Round Diffusion 2 ft
    • 1 × Flat Diffusion 2 ft
    • 1 × Intensifier 2 ft
    • 1 × Omnigrip
    • 1 × Omnipin
    • 2 × Omniclip
    • 1 × Mini Tripod
    • 2 × Eyebolt
    • 1 × Universal Power Supply / Charger
  • The Omnibar 4 Set includes:
    • 1 × Omnibar 4
    • 1 × Round Diffusion 4 ft
    • 1 × Flat Diffusion 4 ft
    • 1 × Intensifier 4 ft
    • 1 × Omnigrip
    • 1 × Omnipin
    • 2 × Omniclip
    • 1 × Mini Tripod
    • 2 × Eyebolt
  • The Omnibar Combo Kit includes:
    • 4 × Omnibar 2
    • 4 × Omnibar 4
    • 8 × Omnigrip
    • 9 × Omnipin
    • 16 × Omniclip
    • 8 × Mini Tripod
    • 16 × Eyebolt
    • 4 × Flat Diffusion 2 ft
    • 4 × Flat Diffusion 4 ft
    • 4 × Round Diffusion 2 ft
    • 4 × Round Diffusion 4 ft
    • 4 × Intensifier 2 ft
    • 4 × Intensifier 4 ft
    • 1 × Omnibase
    • 8 × Power & Data cable 1.3 m
    • 1 × Omnibar Case
    • 1 × Assembly Gauge Clip
    Not included: mains cable for Omnibase, Single PSU.
  • The Omnibar Creator Set includes:
    • 1 × Omnibar 2 (blue/silver)
    • 1 × Omnigrip
    • 1 × Omnipin
    • 2 × Omniclip
    • 1 × Mini Tripod
    • 2 × Eyebolt
  • The Omnibar Production Kit includes:
    • 6 × Omnibar 4
    • 6 × Omnigrip
    • 7 × Omnipin
    • 12 × Omniclip
    • 6 × Mini Tripod
    • 12 × Eyebolt
    • 6 × Flat Diffusion 4 ft
    • 6 × Round Diffusion 4 ft
    • 6 × Intensifier 4 ft
    • 1 × Omnibase
    • 6 × Power & Data cable 1.3 m
    • 1 × Omnibar Case
  • Omnibar is a compact, battery-powered, multi-color linear LED light designed for fast rigging, scalable setups, and professional control workflows. It is built for film, broadcast, content creation, and live/event applications, including outdoor use.
  • Omnibase is the central hub for wired power and data workflows. It is designed for robust installations, scalable setups, and simplified routing/control options.
  • Omniclip is a lightweight mounting accessory that supports flexible fixture positioning on floors, walls, and other surfaces. It allows different mounting angles and can also be used in certain floor-stand applications.
  • The Mini Tripod is designed for vertical applications and offers four adjustable height positions for precise fixture placement. For added stability, it includes through‑holes for fixing the tripod directly to a surface, as well as a ¼‑20 thread for attaching a spigot.
  • Omnibar starts at €615 for the Omnibar 2 fixture. It is available both as an individual set and in larger kit configurations, depending on the application and workflow.
  • Omnibar is available in two sizes: Omnibar 2 (2 ft) and Omnibar 4 (4 ft).
  • Runtime depends on output level and operating mode. At full output, Omnibar is designed for a minimum runtime of more than two hours. At lower output levels, significantly longer runtimes are possible – up to 24 hours, depending on the setup and brightness level.
  • Please contact your local ARRI dealer, ARRI sales representative, or participating rental house for current ordering and availability information in your region.
  • Omnibar 2 and Omnibar 4 are available in blue/silver and black. The Creator Set is available in blue/silver only.
  • Built-in magnets are designed to make mounting faster and more flexible on metal surfaces. They allow quick attachment without additional hardware and help keep the fixture profile clean and compact. For non-magnetic surfaces and more traditional rigging workflows, dedicated accessories such as Omniclip, Omnigrip, and Omnipin are available.
