00 SkyPanel FW 4.5_M20
The Power of Software
ARRI’s mission is to deliver the best possible service and support for our community. L-Series Plus and SkyPanel Classic Firmware updates are for free and all about adding versatility and control - harnessing the awesome power of these lighting fixtures and putting that potential into the hands of the lighting technician, cinematographer, or console operator.
Features such as DMX Presets, and existing features such as custom RGBW White Point, x,y Coordinates Onboard Control, Extended Color Control, are available on a finger tab – for both, L-Series Plus and SkyPanel Classic.
DMX Presets
Bildschirm­foto 2022-12-15 um 12.21.51
Firmware 4 makes it possible to save your DMX settings in up to 10 different presets. To save a new preset, you have to select your DMX settings, and long-press the two buttons "Menu" and "Preset".
If you want to load a previously defined DMX Preset, you just short-press "Menu" and "Preset", and choose a DMX Preset from the displayed list. When getting into the specific preset, you will get a summary of what is recorded.
Feature-3
Custom RGBW White Point
Firmware 4 gives you access to RGBW Calibrated Mode with a white point that can be set anywhere from 2800 K to 10,000 K. Having a user selectable white point gives users the ability to customize their RGBW output to any other light source's white.
Feature-4
  • Easily find the perfect color with Extended Color Control
  • Intuitive and easy-to-use color adjustments
  • Eight parameters for precise color control
  • Onboard control panel or DMX
x,y Coordinate Onboard Control
x, y Coordinate mode has become a popular method for recreating an exact match to a color point measured with a spectrometer. In Firmware 4, this exciting color mode can be controlled via DMX and can also be adjusted using the onboard control panel. Matching the desired color point and storing it in a preset to access later has never been easier.
Bildschirmfoto 2022-12-09 um 11.35.39
Feature7
Ultimate DMX Mode
  • The Ultimate DMX Mode in Firmware 4 allows for any control method to be selected within one DMX mode.
  • Simply Pick the color method and the DMX parameters will adjust to allow for control of the selected method.
DMX Live Page
When receiving a DMX signal, L-Series Plus and SkyPanel Classic can display detailed DMX information directly on the control panel with Firmware 4. Not only can the DMX mode, address, and channel count be easily read, but the fixture displays lighting values for the DMX signal it is receiving. The luminaire even does the conversion from DMX values to real world light output values by calculating the math internally. This feature is a powerful tool when troubleshooting DMX issues.
Feature6
Light Engine DMX Control
  • Control each light engine individually
  • DMX modes offer more programming possibilities
  • Individual light engines act as their own mini SkyPanel with parameters like CCT & RGBW, HSI or x,y Coordinates
LumenRadio CRMX2 for S360-C
Bildschirm­foto 2022-12-15 um 12.24.41
CRMX2: more universes, automatic linking
Wireless connectivity in the S360-C. Choose between a classic LumenRadio CRMX pairing, or the improved CRMX2 protocol: a powerful and easy way to link automatically your S360-C units to a specific transmitter via a specific linking key. Fast, easy, and reliable.
Get to know more features
  • Live entertainment and theatrical performances require completely smooth dimming to zero which create natural lighting transitions for their live audiences. The Stage Mode in Firmware 4 is designed specifically to meet these demands and opens up new doors for the use in live entertainment. Activating Stage Mode allows to smoothly and seamlessly dim down to zero percent intensity without color jumps or noticeable intensity drop off.
  • The Web Portal is an easy way to make adjustments to L-Series Plus and Classic SkyPanel over an Ethernet or WiFi network. This Web Portal allows for fast navigation and comprehensive control interfaces offer complete control over all aspects of the fixture directly from any web browser. DMX functions are also monitored in detail.
  • SkyPanel’s range of widely acclaimed lighting effects is expanding with SkyPanel Firmware 4. Explosion, welding, process, and fluorescent flicker have been added to the lineup for a new total of 17 pre-programmed lighting effects. Explosion is the perfect effect for muzzle flashes and explosion effects. Welding mimics the sparks of a high intensity welding source. Process sends light shooting down the surface of a SkyPanel to imitate the effect of a street light passing over a car - this effect works especially well with the S120. And finally, the fluorescent flicker effect recreates the hum and flutter of a malfunctioning fluorescent bulb. The customer favorite cop car effect has been augmented with five new color combinations.
    Discover all SkyPanel Effects
Updating your Fixture
To update your fixture choose one of the following methods.
    1. Use a USB stick that is USB version 1.0 or 2.0 and is formatted to FAT or FAT32.
    2. The update file (.upd) must be in the root directory of the drive.
    3. Make sure the USB Mode on the fixture is set to “Normal”. (Menu > Fixture Settings > USB Mode > Normal)
    4. Insert the USB stick into the fixture. The fixture will automatically look for the update files. When found, a list of update files will appear in the display.
    5. Highlight the update file and push the encoder knob. The update will begin.
    6. Do not remove the USB stick until the file is completely copied.
    1. Install the ALSM onto your Mac or PC. Download here
    2. Open the application and connect the SkyPanel® to the computer via Ethernet cable.
    3. The ALSM will automatically find your fixture once powered on and connected.
    4. Select the “Firmware Update” tab and then select the fixture you wish to update in thecolumn on the left side of the screen.
    5. Click “Update Firmware” to begin the update.
    6. Do not disconnect your fixture from the power source or from the computer until theupdate is complete.
Firmware History
Your benefit with our firmware updates
Like most digital devices, ARRI LED products provide the possibility of easy and fast firmware updates. With one simple step, your lighting fixture is enhanced with amazing new features. Also, with every update, many smaller improvements are made to create a better user experience and improve performance. Since the introduction of ARRI’s LED product line, we have been continuously offering free firmware updates and supporting software. Your ARRI LED product can be years old and completely up to date at the same time.
    • L-Series Plus Output Matching added (FW 4.5.3)
    • “Gateway” renamed to “DMX/RDM Gateway” and moved into the DMX menu (FW 4.5.3)
    • L-Series Plus DMX/RDM Gateway off by default (FW 4.5.1)
    • L-Series Plus initial firmware (FW 4.5)
    • Whole range of SkyPanel features including LAN support and LAN daisy chaining for L-Series Plus fixtures (FW 4.5)
    • DMX Presets via the display, RDM protocol, and / or USB import / export
    • LumenRadio CRMX2 implementation for S360-C wireless control
    • Deactivation / Activation of CRMX (Wireless DMX / RDM state)
    • Improved LE compensation
    • Improved webpage interaction
    • Renaming of LumenRadio wireless DMX / RDM from “WDMX” to “CRMX”
    • Renaming of “Master / Slave” function to “Host / Client”
    • ”Calibrated color” is now the RGBW color space by default
    • 4.3 is a compatibility extended version
    • SkyPanel Classic Light Engine Compensation (Output Matching)
    • Art-Net Node
    • Extended Color Control
    • Light Engine DMX Control
    • Additional Lighting Effects
    • Stage Mode
    • Ultimate DMX Mode
    • New SkyPanel Web Portal
    • DMX Live Page
    • Strobe DMX Channel
    • x,y Coordinates Onboard Control
    • Customer RGBW White Point
    • Other Enhancements
    • 12 Pre-programmed Lighting Effects
    • Source Matching
    • High Speed Mode
    • sACN Implementation
    • Preset DMX Channel
    • Onboard RGBW Mode
    • RGBW Calibrated Color Space
    • Frequency Selection
    • SkyPanel Web Server
    • Enabled Menu
    • Improved Cross Fade
    • Master/Slave Mode
    • Expanded Gel Mode
    • x,y Coordinate DMX Protocol
    • Low Battery Warning
    • Control Panel Lock
    • Large Display Text
Video Tutorials
