Build your flexible Omnibar setup
As a modular and scalable lighting system, Omnibar meets a wide variety of professional requirements. From magnetically attached front optics that can be swapped in seconds to cost-effective rigging solutions and third-party accessories, the Omnibar ecosystem offers unrivalled flexibility.
Light Output
What they're saying
The light output is already astonishing with the rounded diffusers, but when paired with the flat intensifier, it delivers an even beam free of hot spots, with impressive output for a battery-powered source.
Andrea Abate
Andrea Abate
Gaffer
I especially appreciate the ability to switch to a flat diffusion for a more directional source, reducing the need for crates and improvised tape solutions that are often required with other units.
Logan Schneider
Logan Schneider
DP
The interchangeable optical accessories are a smart and genuinely useful design. Combined with the light quality, they make the Omnibar feel unmistakably ARRI.
Dou Dou
Mr. Dou Dou
Gaffer
  • Omnigrip & Omnipin
    The black aluminum Omnigrip can be positioned anywhere along the Omnibar’s rail system. It allows bars to be seamlessly connected end-to-end for continuous illumination, or can be combined with the silver steel Omnipin for rapid setup with traditional rigging solutions. The Omnipin clicks into place and locks with a positive grip, remaining securely attached to the Omnigrip without risk of unscrewing. Each Omnibar set includes one Omnigrip and Omnipin per fixture for precise and stable mounting.
    Thumbnail-Omnigrip-Omnipin
  • Omniclip
    The Omniclip is a versatile mounting solution made from tough but lightweight black plastic. Its innovative design allows fixtures to be securely placed on the ground, or attached to walls, at 0°, 45°, and 90° angles. The clip's spacious design accommodates the 90° ARRI power connector without obstruction. Each Omnibar set includes two clips per fixture, providing stability and adaptability for professional lighting setups.
    Thumbnail-Omniclip
  • Built-in magnets
    Integrated into the Omnibar’s sleek rear profile are built-in magnets that provide fast, flexible rigging options while keeping the form factor compact. With no need for external magnets or clamps, the fixture mounts directly to metal housings, beams, or scaffolding in any orientation, maintaining a secure hold without adding bulk.
    Thumbnail-Magnets
  • Eyebolt
    Made of high-quality silver and steel, the Eyebolt adapter is a robust and essential safety component for securing lighting fixtures, providing exceptional durability and strength. Each adapter features a customized 3/8" screw design, allowing it to be securely mounted on both sides of the Omnibar for optimal fixture stability. Two Eyebolts are provided per fixture, per set, enhancing both safety and flexibility.
    Thumbnail-Eyebold
  • Mini Tripod
    The Mini Tripod is an adaptable support solution designed to keep your Omnibar steady and secure. It features four adjustable height levels, allowing precise positioning for diverse lighting needs. The tripod is equipped with dual mounting points on both sides of the bar, accommodating 3/8" screws and customized eyebolts for secure and flexible fixture attachments. One tripod is provided per fixture, per set.
    Thumbnail-Mini-Tripod
What they're saying
The rigging options on the Omnibar are a game-changer. Car setups are notoriously difficult due to limited space, but the intuitive mounting hardware made the whole process fast and seamless. It’s gear that actually works with you, not against you.
Luca Rieger
Luca Rieger
Gaffer
The flexible ways of hanging, installing, attaching, and combining the Omnibar are excellent. From the first look, it already feels very ARRI.
Zhang Xi Gui
Mr. Zhang Xi Gui
DP
The combination of magnetic design, waterproof performance, and replaceable accessories and batteries sets the Omnibar apart from other bar lights on the market.
Sam Zhang
Mr. Sam Zhang
CEO, Shanghai PG Culture
Power & data cables
Scaling up your Omnibar setup? Harness the power of the Omnibase and choose your cable lengths.
Many partners have already produced accessories for the Omnibar, including DoPchoice, caligri, Chimera Lighting, Honeycrates, and LIGHTSOCK. If you're manufacturer of lighting modifiers or accessories we'd love you to get involved - you can reach out at lightingproductmanagement@arri.de.
