We have prepared an overview of photometric and technical data for the various configurations of the SkyPanel X modular system X21, X22, and X23.
Tech data & downloads
Detailed technical and photometric overviews
SkyPanel X21 | SkyPanel X22 | SkyPanel X23 | |
Power | 800 W | 1,600 W | 2,400 W |
Format size | 2 : 1 (horizontal) | 2 : 2 (square) | 2 : 3 (vertical) |
Light engines | 4 | 8 | 12 |
Pixel zones | 8 max | 16 max | 24 max |
Max. output (lux) | 4,800 lux @ 10 m, 5,600 K (native hard) | 9,600 lux @ 10 m, 5,600 K (native hard) | 14,400 lux @ 10 m, 5,600 K (native hard) |
Max. output (lumen) | 51,809 lumen (native open-face) | 103,618 lumen (native open-face) | 155,427 lumen (native open-face) |
Included items | 1x X21 Dome | 2x X21 Dome | 3x X21 Dome |
Connectors | 2x AC (In and Through), max. 20A, TRUE1 TOP | 4x AC (In and Through), max. 20A, TRUE1 TOP | 6x AC (In and Through), max. 20A, TRUE1 TOP |
1x DC (In) 48V for battery use | 2x DC (In) 48V for battery use | 3x DC (In) 48V for battery use | |
2x DMX (In and Out), XLR-5pin | 4x DMX (In and Out), XLR-5pin | 6x DMX (In and Out), XLR-5pin | |
2x LAN / Ethernet, RJ45, EtherCON compatible | 4x LAN / Ethernet, RJ45, EtherCON compatible | 6x LAN / Ethernet, RJ45, EtherCON compatible | |
1x USB Type C | 2x USB Type C | 3x USB Type C | |
1x LEMO for ALL-WEATHER Control Panel | 2x LEMO for ALL-WEATHER Control Panel | 3x LEMO for ALL-WEATHER Control Panel | |
Rigging systems | X21 Manual Yoke, bent, quick-lock, 28 mm spigot
| X Modular frames for X22, X Modular System for X22 & X23, Twin Quick-Lock bracket for | X Modular frames for X23, X Modular System for X22 & X23, Twin Quick-Lock bracket for |
Dimensions | fixture only: | n.a. | n.a. |
Weight | fixture only: | fixtures only | fixtures only: |
AC Voltage | 100 - 240 VAC, 50/60Hz | ||
PSU | Integrated | ||
LED engine | Full Spectrum, 6-color RGBACL LED | ||
Native quality | Hard (HyPer Optic), Soft (X21 Dome or S60 Adapter), Open-face | ||
CCT range | 1,500 K - 20,000 K | ||
CRI | 90 min. / 99 max. (High CRI VariFan mode) | ||
TLCI | 93 typical (High CRI VariFan mode) | ||
Camera sensor matching | Yes, via ARRI ALEXA Modes | ||
Dimming performance | Flicker free, high-res low end dimming | ||
Native beam angle | 11º (Hard), 106º (Soft), 120º (Open-face) | ||
Diffuser options | X21 Dome, Beam Enhancer filter, S60-C diffusers | ||
Accessory compatibility | All SkyPanel S60-C accessories via S60 Adapter | ||
Type of display | Removable ALL-WEATHER Control Panel with LiOS3 | ||
Operational modes | Standard (Low noise), High Output, VariFan, ARRI ALEXA Modes | ||
Color modes | CCT, HSI, RGBW, RGBACL, Effects, XY, Gel, Source Matching | ||
DMX Presets | Yes, via ALL-WEATHER Control Panel, RDM and DMX-512A | ||
Legacy DMX modes | Compatible with S60-C Mode 1 and 6 | ||
Multi-array setup | Yes (up to 3 units in just one single DMX profile) | ||
IP-Rating | IP66 (High-pressure jet cleaning, rain, heavy storms, high humidity) | ||
Cooling system | Passive + Active cooling system with double heat sink | ||
Integrated wired control | DMX-512A, RDM, Art-Net 4, sACN LAN (Web-control, ALSM, mDNS Bonjour, PTP, NTP) | ||
Integrated wireless control | CRMX Classic, CRMX2, W-DMX G3 / G4 / G4S / G5, BLE, Native Bluetooth 5.0 | ||
Daisy-chain modularity | Yes, via True1 TOP (power) and EtherCON / RJ45 (data) | ||
Pre-programmed effects | 15 Pixel Macros, 15 effects | ||
Warranty | 3 years | ||
Max. ambient temperature | 40ºC | ||
Certifications | CE, UKCA, CB, ENEC, cNRTLus, FCC, ICES, KC, TRA, ETA, ENACOM, RCM, R-NZ, NBRC, NTC, IFT, PSE | ||
Preliminary technical data. All specifications are typical values. Subject to change without notice. |
Find and download relevant technical information, useful manuals, product certificates, and more on this page. Most documents are available in different languages. Use the filters to find the document in the language you need.
If you would like to receive further information and offers, or you have a specific request regarding SkyPanel X, fill in the form and we will get back to you.
