ALEXA 35 Xtreme_Stage_Picture 2025
Thumbnail_250721_CameraSystems_ALEXA_35_Xtreme_PackshotLoopWebsite_Mobile_1x148
Motion meets emotion
0L0A4346-Edit_Expanded
More speed. Less data.
The ALEXA 35 Xtreme is a major revision of the industry’s trusted workhorse—ALEXA 35, known for its superior image quality, ease of use, and reliable operation. Building on its predecessor’s solid foundation, ALEXA 35 Xtreme introduces powerful new hardware, higher speeds for breathtaking slow-motion images, and the efficient ARRICORE codec.
Highlights
ALEXA 35 Xtreme continues a long tradition at ARRI of high-speed motion picture cameras. New hardware allows frame rates up to 330 fps while maintaining full dynamic range, and a new codec and Sensor Overdrive mode double the limit to 660 fps.
High Speed up to 660 fps
ARRI’s next-generation RGB codec makes the highest image quality more affordable by using cutting-edge image science to reduce data rates. The file sizes might be smaller, but maximum creative flexibility in postproduction remains.
ARRICORE_Highlights
ARRI is offering an upgrade that transforms any previously sold ALEXA 35 into an ALEXA 35 Xtreme. This extends the product life and the return on investment for customers, giving them access to future enhancements enabled by the state-of-the-art new processing unit.
Upgrade_Highlights
ALEXA 35 Xtreme_High Speed Picture
A35_Extreme_MobileWebsiteTextReel_Thumbnail_250729
Frame rates up to 660 fps
One camera for all speed requirements
Easy matching of high-speed shots in post
ALEXA 35 Xtreme removes the need to carry a separate high-speed camera on most shoots. This streamlines production workflows, saves time and money, and ensures that high-speed footage matches seamlessly with standard-speed shots in post. These benefits are enabled by the new main processor, equipped with more and faster on-board memory. Frame rates up to 330 fps retain the camera’s full 17 stops of dynamic range, while a Sensor Overdrive mode allows frame rates up to 660 fps at a dynamic range of 11 stops.
Slow motion
The new Sensor Overdrive mode unlocks higher maximum frame rates by reducing sensor read-out times. It is designed for situations where extreme slow-motion is required, prioritizing frame rate by making trade-offs with other image parameters: the camera’s dynamic range decreases by six stops in the highlights and its base sensitivity increases to EI 1600. Sensor Overdrive mode requires careful consideration of exposure settings and should only be used in controlled lighting environments.
Sensor Overdrive (2)
A35_Extreme_WebsiteImageReel_Thumbnail_250729
A35_Extreme_MobileWebsiteImageReel_Thumbnail_250729
ARRICORE Logo - NEG_blue_bright_1
Complementing ALEXA 35 Xtreme and included with both the Base and Premium models is ARRICORE, ARRI’s next-generation RGB codec. Designed to deliver the camera’s exceptional image quality at a more accessible cost by reducing data rates, ARRICORE also provides flexibility in post, since sensitivity, white balance, and tint are not baked in.
Switching to ARRICORE is easy because on-set and post workflows remain consistent with existing ALEXA 35 codecs and drives. The ALF4 ARRI Look File, ARRI Textures, metadata, audio, and the MXF wrapper will all behave in a familiar way. ARRICORE is launching in beta to actively engage users and drive rapid enhancement of its capabilities through direct feedback. Most third-party tools that already support the current ALEXA 35 codecs will also support ARRICORE.
ALEXA_35_Xtreme_Hardware
Powerful new hardware
ALEXA 35 Xtreme looks the same as ALEXA 35 on the outside, but inside there are some comprehensive hardware upgrades. A powerful new main processing board enables faster data processing and quicker access to the increased on-chip memory, while the redesigned cooling system ensures stable performance, even during continuous high-load operation.
Pre-recording times are five times longer, reaching up to five minutes, depending on the recording format. This simplifies high-speed capture for everyone and is essential for documentary filmmakers.
Pre-recording
As a result of its hardware and processing upgrades, the ALEXA 35 Xtreme consumes 10% less power than the ALEXA 35. Whether you're on location or in the studio, this improvement means more efficiency, less heat, and extended battery life—without compromising performance.
Power
Better wireless connectivity to accessories and tools like the ARRI Camera Companion App through compatibility with the WiFi 5 GHz band, WiFi roaming, and auto-reconnect to previously known networks.
Wifi
Evolving technology, unchanging excellence
While the Xtreme upgrade significantly expands the capabilities of the ALEXA 35 camera system, its core strengths remain unchanged: industry-leading image quality from the 4.6K Super 35 sensor, robust build, intuitive workflows, and trusted reliability. ALEXA 35 electronic and mechanical accessories, CODEX Compact Drive media, and the Live Production System LPS-1 all remain compatible with ALEXA 35 Xtreme.
Incredible dynamic range
Capturing an impressive 17 stops of dynamic range, the camera renders exceptionally filmic highlight roll-off and deep shadow detail. Built to handle any lighting situation with ease, it is the ultimate acquisition tool for HDR workflows and future-proof content, providing unparalleled flexibility in postproduction.
Find out more
A_0014C016_250717_191034_a1I7H.mxf_1.26.3
Enhanced sensitivity
As a high-sensitivity camera, ALEXA 35 Xtreme offers sensitivity settings from EI 160 to EI 6400 while maintaining low noise and exceptional color accuracy across all exposure levels. The Enhanced Sensitivity mode ensures even cleaner images in low-light environments and is an especially powerful tool when combined with in-camera Shadow ARRI Textures.
Find out more
A_0001C026_250620_223819_a1I7H.mxf_3.6.1
True-to-life colors
ARRI’s REVEAL Color Science renders skin tones naturally and beautifully, capturing the subtlest of tonal variations to enhance emotional depth and visual immersion. Despite its state-of-the-art innovations, the REVEAL workflow is simple and efficient, delivering stunning, worry-free results.
Explore REVEAL Color Science
B_0002C014_250701_165326_c1I7H.mxf_1.87.1
On-set creative control
ARRI Textures offer an evolving menu of in-camera looks that allow cinematographers to fine-tune the grain in the image and the amount of contrast at different levels of detail—almost like choosing a film stock. With textures, users can make decisions on set about how ALEXA 35 Xtreme “sees” the world.
Discover ARRI Textures
220513_Encounters_Germany_MarketingStills_1.5.1
240826_Camera_Showreel_2024_ALEXA_35_Mobile_ProRes_Rec709_24p_stereo24bit.mov_1.1.1
ALEXA 35 image quality. Trusted by the best.
Filmmakers on ALEXA 35 Xtreme
4-arri-alexa-35-xtreme-application-shot
Elias Maria BVK
Cinematographer
The ALEXA 35 Xtreme opens up new ways and new worlds. I started out in action sports with sailing and skiing, which both involve extreme lighting and contrast, so being able to shoot at 240 fps with the full 17 stops of dynamic range is an amazing new tool...By playing with different frame rates, you find that you’re creating depth through motion. You go beyond composition, blocking, and lighting to a place where the real depth comes from layering different speeds.
Quote Image Ayana Baraka and Team
Ayana Baraka
Cinematographer
For me, the ALEXA 35 Xtreme is the most complete camera system ARRI has ever delivered. It elevates the unparalleled ARRI color science and skin tone accuracy we rely on with next-gen capabilities that redefine what’s possible on set. Shooting at 240 fps with ARRICORE, I was blown away by the clarity, dimensionality, and emotional depth of the image. This camera doesn’t just capture a scene; it pulls you into it. The new high-efficiency codec and high-speed workflow make it a true powerhouse for modern productions.
StijnVdVeken_Quote_Image_01_VEYL2105
Stijn Van der Veken ASC, SBC
Director of photography
The ALEXA 35 was already my favorite camera because of its dynamic range, and the new ALEXA 35 Xtreme now also gives me super high frame rates. Shooting with the Xtreme was a real revelation, using different speeds to enhance peoples’ emotions on screen, all with the same camera.
Quote Image Jeff Berlin
Jeff Berlin
Cinematographer
As a DP in fashion and beauty, the ALEXA 35 is my go-to camera. Its images are lovely – painterly yet accurate color, pleasing skin tones and texture, all essential in this field. With the ALEXA 35 Xtreme’s higher frame rates, I can now linger in emotion and dreams in the image quality I’m known for.
Quote Image Alexa Salahi
Alex Salahi
The ALEXA 35 Xtreme’s slow-motion capabilities open up incredible possibilities to capture the dynamics of any action with the color science I love. Even in Sensor Overdrive mode, which reduces latitude, I felt I had solid control over exposure. It felt like I was getting more than the advertised 11 stops.
I shot with anamorphic lenses in 4.6K Open Gate, with the full 17-stop dynamic range at 120 fps, capturing natural-looking slow motion with remarkable texture and detail. At 660 fps in Sensor Overdrive mode, I was able to capture incredibly unique moments with minimal effort. Freezing time at that speed revealed layers of emotion and movement otherwise invisible.
Quote Image Charles Bergquist
Charles Bergquist
Cinematographer
The ALEXA 35 Xtreme gives us a new perspective of what high-speed cinematography looks like. Almost every project I work on calls for high-speed work at some point—now I can do everything with a single camera and keep my image consistent through a variety of changing artistic needs. The richness of the ALEXA 35 sensor is retained at frame rates previously reserved for specialty cameras, creating the most versatile and adaptable image available.
Photo credit: Julio Erazo
JanMatthys_Quote_Image_01_VEYL2322
Jan Matthys
Director
These higher frame rates open up new possibilities to explore the inner world of the characters. The ALEXA 35 Xtreme ‘reads’ their emotions and thoughts to a next level, deepening subtlety and truthfulness.
EduardoVerttyAMC
Eduardo Vertty AMC
Having had the opportunity of shooting with the ALEXA 35 Xtreme for a tabletop setup, which is one of the areas I work in as a DP, I found I could shoot up to the maximum frame rate of 660 fps with all the image quality I need. The innovations in this camera, and the results obtained, allowed me to keep a uniform workflow with all the support of ARRI technology.
Fast and easy operation
ALEXA 35 Xtreme is a compact, lightweight, and fully featured production camera, packing impressive functionality and processing power into a Mini-sized body. User-friendly operation is assured through numerous refinements, a simple and intuitive menu structure, and streamlined recording formats across three different codecs that cover all your needs while maximizing efficiency. ALEXA 35 Xtreme is the best A-camera, B-camera, action camera, and high-speed camera on the market, all rolled into one.
Flexible purchase options
Combining unmatched image quality with the frame rates of a specialist high-speed camera, ALEXA 35 Xtreme is uniquely versatile, making it a cost-effective rental choice and a sound investment for owner-operators. It is sold in sets, either as the fully featured ALEXA 35 Xtreme Premium model or the lower-cost Base model, which has the same image quality and a core feature set. The Base model can be flexibly upgraded via temporary or permanent feature licenses.
Entry sets from €49,800
Extended features
The same feature licenses available for the ALEXA 35 Base can also be used to add specialist features to the ALEXA 35 Xtreme Base on a weekly, monthly, yearly, or permanent basis. They allow users to add specific functionality for a short-form job, a longer-term project, or a new career direction.
With the High Speed License installed, users get access to the maximum frame rates possible for all recording formats that are enabled in the camera.
The ARRIRAW License allows uncompressed, unencrypted ARRIRAW recording for all recording formats installed on the camera, providing maximum image flexibility in post.
For the ALEXA 35 Xtreme and ALEXA 35 Base models, and ALEXA 35 Live, the Open Gate/Anamorphic license enables all Open Gate recording formats as well as the anamorphic 3.3K 6:5 recording format and anamorphic de-squeeze for monitor paths. For the latter two cameras it also enables the 3K 1:1 and 2.7K 8:9 recording formats.
The Look License provides access to all ARRI Textures in the camera and on the ARRI website, the ARRI Look Library with 87 unique looks, and Custom Color Management for full control of the image processing path.
The Pre-record License equips the camera with a buffer that continually stores up to five minutes of images (with ALEXA 35 Xtreme), which are then added to the start of a clip once recording begins, allowing unpredictable events to be captured.
The Premium License is a bundle package that includes all five of the individual feature licenses detailed above: High Speed, ARRIRAW, Open Gate/Anamorphic, Look, and Pre-recording.
License details and prices
The ALEXA 35 Xtreme Base model offers an accessible path into the world of ARRI image quality. By adding the five individual licenses, the Base model becomes as fully featured as the Premium model. The Premium License achieves this in one hit by combining all five in a cost-effective bundle; in fact, the Base model plus a permanent Premium License costs the same as the Premium model.
Meet the ALEXA 35 Xtreme
0L0A4258
Upgrade your ALEXA 35 to ALEXA 35 Xtreme
The ALEXA 35 Xtreme is available either as a brand-new camera or as an upgrade for existing ALEXA 35 models, which will retain their installed licenses. Upgrades are carried out at selected ARRI Service Centers.
Choose your set
The ALEXA 35 Xtreme is available in a choice of eight Base sets and three Premium sets that all bring accessory savings. The Base Entry Sets offer the most affordable way to acquire a lightweight, ready-to-shoot camera package and put the ALEXA 35 Xtreme at a price point comparable to the original ALEXA Mini. Owner operators and sports productions will be drawn to the Operator Sets, while the Production Sets are suited to high-end narrative productions and include accessories that would come as standard from a rental house.
  • Base Entry Sets
    • Most affordable way to get a lightweight, ready-to-shoot camera package
    • Comparable to ALEXA Mini set prices
    • Includes an ALEXA 35 Xtreme camera with a Base license (ARRICORE and ProRes recording with basic 16:9 spherical recording formats in frame rates up to 60 fps), LPL Mount (with PL-to-LPL Adapter), lightweight accessories, and CCM-1 onboard monitor
    • Optionally with 3x Compact Drive Express 1TB and 1x USB-C Reader
  • Base Operator Sets
    • Universal sets designed for owner-operators and sports productions
    • Includes an ALEXA 35 Xtreme camera with a Base license (ARRICORE and ProRes recording with basic 16:9 spherical recording formats in frame rates up to 60 fps), LPL Mount (with PL-to-LPL Adapter), Touchdown base plate system, and MVF-2 viewfinder
    • Optionally with PL Mount (Hirose) instead of LPL for sports market
  • Base Production Sets
    • Designed to suit the workflow of a traditional camera department
    • Includes an ALEXA 35 Xtreme camera with a Base license (ARRICORE and ProRes recording with basic 16:9 spherical recording formats in frame rates up to 60 fps), LPL Mount (with PL-to-LPL Adapter), MVF-2 viewfinder, production accessories, and Power Distribution Module PDM-1
    • Fully compatible with most rental packages for high-end narrative productions
    • Optionally for 15 mm or 19 mm studio rods
  • Premium Operator Sets
    • Includes an ALEXA 35 Xtreme camera with a Premium license (frame rates up to 660 fps, ARRICORE, ARRIRAW and ProRes recording, all Open Gate-width and anamorphic recording formats, in-camera anamorphic de-squeeze, pre-recording, and look [ARRI Textures, ARRI Look Library, and Custom Color Management]), LPL Mount (LBUS), PL-to-LPL Adapter, Touchdown base plate system, and MVF-2 viewfinder
  • Premium Production Sets
    • Includes an ALEXA 35 Xtreme camera with a Premium license (frame rates up to 660 fps, ARRICORE, ARRIRAW and ProRes recording, all Open Gate-width and anamorphic recording formats, in-camera anamorphic de-squeeze, pre-recording, and look [ARRI Textures, ARRI Look Library, and Custom Color Management]), LPL Mount (LBUS), PL-to-LPL Adapter, MVF-2 viewfinder, production accessories, and Power Distribution Module PDM-1
Model
Sensor Type
Super 35 format ARRI ALEV 4 CMOS sensor with Bayer pattern color filter array
Sensor Maximum Number of Photosites and Size
4608 x 3164
27.99 x 19.22 mm / 1.102 x 0.757"
Ø 33.96 mm / 1.337"
Sensor Frame Rates
0.75 - 660 fps*
Weight
∼3.0 kg / 6.6 lbs (camera body with three antennas and LPL Mount (LBUS))
Photosite Pitch
6.075 μm
Sensor Active Image Area (photosites)
4.6K 3:2 Open Gate: 4608 x 3164*
4.6K 16:9: 4608 x 2592*
4K 16:9: 4096 x 2304
3.8K 16:9: 3840 x 2160
3.8K 2.39:1: 3840 x 1608
3.3K 6:5: 3328 x 2790*
2K 16:9 S16: 2048 x 1152
HD 16:9 S16: 1920 x 1080
Sensor Active Image Area (dimensions)
4.6K 3:2 Open Gate: 28.0 x 19.2 mm / 1.102 x 0.756"
4.6K 16:9: 28.0 x 15.7 mm / 1.102 x 0.618"
4K 16:9: 24.9 x 14.0 mm / 0.980 x 0.551"
3.8K 16:9: 23.3 x 13.1 mm / 0,918 x 0.516"
3.8K 2.39:1: 23.3 x 9.8 mm / 0.918 x 0.386"
3.3K 6:5: 20.22 x 16.95 mm / 0.796 x 0.693"
2K 16:9 S16: 12.4 x 7.0 mm / 0.490 x 0.276"
HD 16:9 S16: 11.7 x 6.6 mm / 0.461 x 0.260"
Recording File Container Size (pixel)
4.6K 3:2 Open Gate: 4.6K (4608 x 3164)
4.6K 16:9: 4.6K (4608 x 2592)
4K 16:9: 4K (4096 x 2304)
3.8K 16:9: UHD (3840 x 2160)
3.8K 2.39:1: 3.8K (3840 x 1608)
3.3K 6:5: 3.3K (3328 x 2790), 4K (4096 x 1716)
2K 16:9 S16: 2K (2048 x 1152)
HD 16:9 S16: HD (1920 x 1080)
Recording File Image Content (pixel)
Identical to Recording File Container Size
Dynamic Range
17 stops
Exposure Index
Adjustable from EI 160 - 6400 in 1/3 stops
Shutter
Electronic shutter, 1.0°- 356° or 1s - 1/8000s
Recording Formats
MXF/ARRIRAW*
MXF/ARRICORE
MXF/Apple ProRes 4444 XQ
MXF/Apple ProRes 422 HQ
Codex Compact Drive 1TB (CA08-1024)
Codex Compact Drive 2TB (CB16-2048)
Codex Compact Drive Express 1TB (CP08-1024)
Recording Frame Rates
ARRIRAW 4.6K 3:2 Open Gate: 35 / 80 fps
ARRIRAW 4.6K 16:9: 45 / 95 fps
ARRIRAW 4K 16:9: 55 / 125 fps
ARRIRAW 3.8K 16:9: 65 / 140 fps
ARRIRAW 3.8K 2.39:1: 85 / 190 fps
ARRIRAW 3.3K 6:5 - 3.3K: 55 / 120 fps
ARRIRAW 2K 16:9 S16: 230 / 330 fps
ARRIRAW HD 16:9 S16: 260 / 330 fps
ARRICORE 4.6K 3:2 Open Gate: 80 / 120 / 165* fps
ARRICORE 4.6K 16:9: 100 / 150 / 200* fps
ARRICORE 4K 16:9: 125 / 150 / 210* fps
ARRICORE 3.8K 16:9: 145 / 150 / 240* fps
ARRICORE 3.8K 2.39:1: 195 / 240 fps
ARRICORE 3.3K 6:5 - 3.3K: 120 / 120 / 210* fps
ARRICORE 2K 16:9 S16: 330 / 330 / 660* fps
ARRICORE HD 16:9 S16: 330 / 330 / 660* fps
Apple ProRes 4444 4.6K 3:2 Open Gate: 90 / 120 fps
Apple ProRes 4444 4.6K 16:9: 110 / 150 fps
Apple ProRes 4444 4K 16:9: 135 / 150 fps
Apple ProRes 4444 3.8K 16:9: 150 / 150 fps
Apple ProRes 4444 3.8K 2.39:1: 210 / 240 fps
Apple ProRes 4444W 3.3K 6:5 - 3.3K: 120 / 120 fps
Apple ProRes 4444 2K 16:9 S16: 330 / 330 fps
Apple ProRes 4444 HD 16:9 S16: 330 / 330 fps
Compact Drive 1TB / 2TB, *with Sensor Overdrive
Recording Modes
Standard real-time recording
Pre-recording*
Viewfinder Type
Multi Viewfinder MVF-2 with 4" flip-out touchscreen monitor
Viewfinder Technology
OLED viewfinder display
LCD flip-out monitor
Viewfinder Resolution (pixel)
OLED: 1920 x 1080
Viewfinder Diopter
Adjustable from -5 to +5 diopters
Color Output
1. ARRI Color Management Display Render Transforms:
- Rec 709
- Rec 2020
- Rec 2100 PQ
- Rec 2100 HLG
2. LogC4
3. Custom Color Management*
Look Control
ARRI Look File ALF-4:
- Import of custom 3D LUT
- ASC CDL parameters (slope, offset, power, saturation)
ARRI Look Library*
ARRI Textures*
White Balance
Manual and auto white balance, adjustable from 2000K to 11000K in 10K steps
Color correction adjustable range from -16 to +16 CC
Filters
Four position built-in motorized ND filter: Clear, 0.6, 1.2, 1.8
Image Outputs
2x VF custom CoaXPress connectors for MVF-2 viewfinder
2x 12G SDI (BNC): 422 1.5G HD, 422 3G HD, 444 3G HD, 422 6G UHD, 422 12G UHD, 444 12G UHD
Lens Squeeze Factors
1.00, 1.25, 1.30, 1.33, 1.50, 1.65, 1.80, 1.85, 2.00*
Exposure and Focus Tools
False Color
Zoom
Aperture and Color Peaking
Audio Input
1x LEMO 6pin balanced stereo line in with 12V power output
(line input max. level +24 dBu correlating to 0 dBFS)
Two built-in microphones for scratch audio
With Audio Extension Module AEM-1: additional 3x TA3 connectors (MIC/Line, +48 V, AES)
With LPS-1 Fiber Camera Adapter FCA-1: additional 2x TA3 connectors (MIC/Line, +48 V, AES)
Audio Output
SDI (embedded)
3,5mm stereo headphone jack (on MVF-2)
Audio Recording
4 channel linear PCM, 24 bit 48 kHz
Remote Control Options
MVF-2 viewfinder as wired remote control with 10m/33ft cable
ARRI Electronic Control System (ECS)
Web-based remote control via Ethernet & WiFi (beta version)
Camera Access Protocol (CAP) via Ethernet & WiFi
GPIO interface for integration with custom control interfaces
Skaarhoj Remote Control Panel
Interfaces
1x LBUS (LEMO 4-pin) for lens motors, daisy chainable
1x SERIAL (LEMO 4-pin) for distance measuring accessories
1x TC (LEMO 5-pin) for timecode In/Out
1x ETH (LEMO 10-pin) for remote control and service
1x SYNC IN (BNC) for Genlock synchronization
1x RET IN (BNC, switchable on SDI 2)
1x USB-C for user setups, look files etc.
1x Rear Interface (18-pin Pogo) for connection of modules and battery adapters
Wireless Interfaces
Built-in WiFi module (IEEE 802.11a/ac/b/g/n/k/r/v)
Built-in White Radio for ARRI ECS lens and camera remote control
Lens Mounts
ARRI LPL Mount (LBUS)
ARRI PL-to-LPL Adapter
ARRI PL Mount (LBUS)
ARRI PL Mount (Hirose)
Leitz M Mount for ARRI
Flange Focal Depth
LPL mount: 44 mm
PL mount: 52 mm
Power Input
1x PWR (LEMO 8-pin)
1x BAT (camera rear interface / battery adapter)
20.5 - 33.6 V DC
Power Consumption
~ 81 W (Camera body and MVF-2)
Power Outputs
1x RS (Fischer 3-pin) for 24 V accessory power out, start/stop and shutter pulse
1x 12 V (LEMO 2-pin) for 12 V accessory power out
1x LBUS (LEMO 4-pin) for lens motors & 24 V power out, daisy-chainable
1x AUDIO (LEMO 6-pin) for balanced stereo line in and 12 V accessory power out
1x ETH (LEMO 10-pin) for remote control, service and 24 V accessory power out
With Power Distribution Module PDM-1: additionally 4x 24 V, 2x 12 V and 1x D-Tap
With LPS-1 Fiber Camera Adapter: additionally 1x 24 V and 3x 12 V
Measurements (HxWxL)
147 x 152.5 x 203 mm / 5.8 x 6.0 x 8.0"
(camera body with LPL lens mount)
Operating Temperature
General:
'-20° C to +45° C / -4° F to +113° F
When using more than 120 fps or more than 90 fps in 4.6K and 3.3K Sensor Modes:
'-20° C to +40° C / -4° F to +113° F
both @ 95% relative humidity max, non condensing, splash and dust proof through sealed electronics, IP 51
Storage Temperature
-30° C to +70° C / -22° F to +158° F
Sound Level
< 20 dB(A) at 30fps, recording 4K 16:9, Apple ProRes 4444 XQ, ≤ +30° ambient temperature
Software Licenses
ALEXA 35 Xtreme Premium License
ALEXA 35 Xtreme Look License
ALEXA 35 Xtreme ARRIRAW License
ALEXA 35 Xtreme Open Gate/Anamorphic License
ALEXA 35 Xtreme Highspeed License
ALEXA 35 Xtreme Pre-record License
ALEXA 35 Xtreme Multicam License (optional)
*Feature requires licensing and is not initially activated in the ALEXA 35 with Base License
