K2.0010433
Steel C-stand with detachable Turtle Base . Max. height 155 cm/61" NOTE To park the MAXIMA the Spider (K2.0010425) is needed For all ARTEMIS and TRINITY systems
K2.0010489
ARTEMIS carbon fiber telescopic center post, 1.8", no-tool clamp, torsion-free guided 1.5" inner post, fine-trim adjustment Length from 43 cm to 72 cm/16.9" to 28.3" For ...
K0.0048623
This special carbon post is required to use the M2 Volt (trademark) Gimbal with ARTEMIS 2 and older artemis systems, like the Cine Broadcast and the EFP HD. In order to pr...
K2.0041474
ARTEMIS carbon fiber telescopic center post, 1.8", no-tool clamp, torsion-free guided 1.5" inner post, fine-trim adjustment. Length from 37 cm/14.56" to 46.5 cm/18.3" For...
K2.0041976
Modular center post extension to extent the 1.8" ARTEMIS center post by 21.6 cm/8.5". Diameter: 1.8" Length: 21.6 cm/8.5" Lemo 3B 16-pin For ARTEMIS 2 and TRINITY 2
KK.0041404
The new Super Post, 1.8" Gen.2 is a replacement center post for the standard center post which comes with the system. The new Super Post enables the camera in the ARTEMIS a...
KK.0041403
K2.0010569
Extends the length of the bent gimbal handle by 35 mm/1.37" NOTE Do not combine two extensions. For ARTEMIS 1.8" gimbals
K2.0014280
The Knurled Handle Gimbal Extension adds a second knurled handle to the upper side of the 1.8" ARTEMIS gimbal, giving more control and better handling when the rig is used ...
K2.0042716
The improved monitor mount Gen.2 offers a wider distance between the rods, so that it can be fixed better and more compactly on the carriage or under table. The improved ro...
K2.0042717
K2.0042710
The improved monitor mount Gen.2 offers a larger distance between the rods, so that it can be fixed better and more compactly on the carriage or under table. The improved r...
K2.0042711
K2.0042713
Upgrade kit that allows the SmallHD 703 monitor to be mounted in existing 6" and 8" ARTEMIS monitor brackets. SmallHD 703 For existing 6" and 8" ARTEMIS monitor brackets
K0.0040291
This set of adapter inserts allows the 1.8" ARTEMIS gimbal (K2.0010493) to be used on the Volt or M2 Post. For Volt Post and M2 Post
K2.0039300
The Battery Mounting System generation 2 contains two key components: The Battery Mounting Base BMS-2 for ARTEMIS and TRINITY generation 2, or BMS-1 for TRINITY generation ...
K2.0040284
New modular and extremely flexible battery mounting system. The interchangeable battery holders can be changed quickly and easily. The electrical contact to the battery bod...
K0.0044358
K2.0040286
